  4. npm ERR! code EBADPLATFORM reactor 20022
2 Posts 2 Posters 1.4k Views 1 Watching
  • ElcidE Offline
    ElcidE Offline
    Elcid
    wrote on last edited by Elcid
    i get the following error when i run
    ~/reactor $ npm i --no-save --omit dev
    Reactor is running and i see no ill effects so far
    Thought i would report for info.
    npm ERR! notsup Unsupported platform for inotify@1.4.6: wanted {"os":"linux","arch":"any"} (current: {"os":"android","arch":"arm"})
    npm ERR! notsup Valid OS:    linux
    npm ERR! notsup Valid Arch:  any
    npm ERR! notsup Actual OS:   android
    and here is log for more info
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/data/data/com.termux/files/usr/bin/node',
    1 verbose cli   '/data/data/com.termux/files/usr/bin/npm',
    1 verbose cli   'i',
    1 verbose cli   '--no-save',
    1 verbose cli   '--omit',
    1 verbose cli   'dev'
    1 verbose cli ]
    2 info using npm@6.14.10
    3 info using node@v14.15.4
    4 verbose npm-session e65bf5b70b2ee3fd
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 200 https://registry.npmjs.org/dev 1079ms
    8 http fetch GET 200 https://registry.npmjs.org/dev/-/dev-0.1.3.tgz 161ms
    9 silly pacote tag manifest for dev@latest fetched in 1336ms
    10 timing stage:loadCurrentTree Completed in 2965ms
    11 silly install loadIdealTree
    12 silly install cloneCurrentTreeToIdealTree
    13 timing stage:loadIdealTree:cloneCurrentTree Completed in 11ms
    14 silly install loadShrinkwrap
    15 timing stage:loadIdealTree:loadShrinkwrap Completed in 316ms
    16 silly install loadAllDepsIntoIdealTree
    17 silly resolveWithNewModule dev@0.1.3 checking installable status
    18 http fetch GET 200 https://registry.npmjs.org/inotify 788ms
    19 http fetch GET 200 https://registry.npmjs.org/inotify/-/inotify-1.4.6.tgz 796ms
    20 silly pacote range manifest for inotify@>= 0.1.6 fetched in 1636ms
    21 silly resolveWithNewModule inotify@1.4.6 checking installable status
    22 timing stage:rollbackFailedOptional Completed in 2ms
    23 timing stage:runTopLevelLifecycles Completed in 4975ms
    24 verbose stack Error: Unsupported platform for inotify@1.4.6: wanted {"name":"inotify","version":"1.4.6","engines":{"node":">=0.8"},"os":["linux"],"dependencies":{"bindings":"^1.3.1","nan":"^2.12.1"},"optionalDependencies":{},"peerDependenciesMeta":{},"devDependencies":{},"bundleDependencies":false,"peerDependencies":{},"deprecated":false,"_resolved":"https://registry.npmjs.org/inotify/-/inotify-1.4.6.tgz","_integrity":"sha512-WW8/uqIA04O3AePQVe/Ms3ZLR0yGamaz8YOEpaXc4WBAGOPZfzu58wWErEPSUYaPyDrJRIeCn6PEIQgC1ZyQ5w==","_shasum":"c5a51852df1647d1a589d46c4baa2771ed36b8d2","_shrinkwrap":null,"_id":"inotify@1.4.6","_from":"inotify@>= 0.1.6","_requested":{"type":"range","registry":true,"raw":"inotify@>= 0.1.6","name":"inotify","escapedName":"inotify","rawSpec":">= 0.1.6","saveSpec":null,"fetchSpec":">= 0.1.6"},"_spec":"inotify@>= 0.1.6","_where":"/data/data/com.termux/files/home/reactor/node_modules/dev"} (current: {"os":"android","cpu":"arm"})
    24 verbose stack     at checkPlatform (/data/data/com.termux/files/usr/lib/node_modules/npm/node_modules/npm-install-checks/index.js:46:14)
    24 verbose stack     at thenWarnEngineIssues (/data/data/com.termux/files/usr/lib/node_modules/npm/lib/install/validate-args.js:63:5)
    24 verbose stack     at /data/data/com.termux/files/usr/lib/node_modules/npm/node_modules/iferr/iferr.js:3:64
    24 verbose stack     at checkEngine (/data/data/com.termux/files/usr/lib/node_modules/npm/node_modules/npm-install-checks/index.js:25:10)
    24 verbose stack     at module.exports.isInstallable (/data/data/com.termux/files/usr/lib/node_modules/npm/lib/install/validate-args.js:60:3)
    24 verbose stack     at resolveWithNewModule (/data/data/com.termux/files/usr/lib/node_modules/npm/lib/install/deps.js:677:10)
    24 verbose stack     at /data/data/com.termux/files/usr/lib/node_modules/npm/lib/install/deps.js:600:7
    24 verbose stack     at /data/data/com.termux/files/usr/lib/node_modules/npm/node_modules/call-limit/call-limit.js:28:43
    24 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:75:11)
    25 verbose pkgid inotify@1.4.6
    26 verbose cwd /data/data/com.termux/files/home/reactor
    27 verbose Linux 4.9.76
    28 verbose argv "/data/data/com.termux/files/usr/bin/node" "/data/data/com.termux/files/usr/bin/npm" "i" "--no-save" "--omit" "dev"
    29 verbose node v14.15.4
    30 verbose npm  v6.14.10
    31 error code EBADPLATFORM
    32 error notsup Unsupported platform for inotify@1.4.6: wanted {"os":"linux","arch":"any"} (current: {"os":"android","arch":"arm"})
    33 error notsup Valid OS:    linux
    33 error notsup Valid Arch:  any
    33 error notsup Actual OS:   android
    33 error notsup Actual Arch: arm
    34 verbose exit [ 1, true ]
    Depandencies
    {"dependencies": {
        "@influxdata/influxdb-client": "^1.18.0",
        "@mdi/font": "^5.9.55",
        "body-parser": "^1.19.0",
        "bootstrap": "4.6.0",
        "bootstrap-icons": "1.5.0",
        "cookie": "^0.4.1",
        "digest-fetch": "^1.2.1",
        "diskusage-ng": "^1.0.1",
        "express": "^4.17.1",
        "feather-icons": "^4.28.0",
        "font-awesome": "^4.7.0",
        "gridstack": "^5.0.0",
        "jquery": "3.6.0",
        "jquery-ui-dist": "1.12.1",
        "js-yaml": "^3.14.1",
        "node-fetch": "^2.6.7",
        "nodemailer": "^6.5.0",
        "qs": "^6.10.1",
        "serve-static": "^1.14.1",
        "uuid": "^8.3.2",
        "ws": "^7.5.6"
      Looks like a dependency of one of the dependent packages doesn't have an Android implementation. Sorry, mate. Nothing I can do about that. You've been riding the bleeding edge with your setup, and it finally cut.
        160.0k
