  4. Urgent Help MSR stopped running
38 Posts 3 Posters 12.0k Views 3 Watching
    Ok, so now look at the logs again. Disk space problem hiding others, now you should be able to see them.
      #22
      Don't know what's happened now but reactor.service is not even in the list at all anymore.
      The service file is still in there
      I'm downloading the syslog again now.
        #23
        OK these are the latest entries in the syslog to do with reactor
        Mar 18 22:07:48 HP-Thin01 node[522]: NODE_PATH /home/stuart/reactor
        Mar 18 22:07:48 HP-Thin01 node[522]: FileLogStream { type: 'file', name: 'reactor.log', maxsize: 2, keep: 5 }
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.123Z <app:null> Reactor latest-22069-ebeefad starting on v16.13.1
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.126Z <app:INFO> Process ID 522; platform linux/x64 #1 SMP Debian 4.19.208-1 (2021-09-29); locale en_GB.UTF-8
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.127Z <app:INFO> Basedir /home/stuart/reactor; data in /home/stuart/reactor/storage
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.128Z <app:INFO> NODE_PATH=/home/stuart/reactor
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.135Z <app:INFO> Configured locale (undefined); selected locale(s) en_GB.UTF-8
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.195Z <app:INFO> Loaded locale en-US
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.223Z <Capabilities:null> Module Capabilities v21333
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.354Z <Plugin:null> Module Plugin v21186
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.369Z <TimerBroker:null> Module TimerBroker v21333
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.381Z <default:INFO> Module Entity v22042
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.391Z <Controller:null> Module Controller v22003
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.392Z <default:null> Module Structure v22047
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.413Z <default:null> Module Ruleset v21096
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.414Z <default:null> Module Rulesets v21096
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.433Z <GlobalExpression:null> Module GlobalExpression v21333
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.474Z <Predicate:null> Module Predicate v22067
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.484Z <AlertManager:null> Module AlertManager v21355
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.490Z <default:null> Module Rule v22043
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.500Z <GlobalReaction:null> Module GlobalReaction v21333
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.504Z <default:null> Module Engine v22053
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.505Z <default:null> Module httpapi v22021
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.510Z <default:null> Module httpproxy v21333
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.554Z <default:null> Module wsapi v21334
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.558Z <app:NOTICE> Starting Structure...
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.567Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/home/stuart/reactor/storage] failed to read sys_alerts in /home/stuart/reactor/storage/states/sys_alerts.json: [SyntaxError]SyntaxError: Unexpected end of JSON input
        Mar 18 22:07:48 HP-Thin01 node[522]: Trapped unhandled Promise rejection SyntaxError: Unexpected end of JSON input
        Mar 18 22:07:48 HP-Thin01 node[522]:     at JSON.parse (<anonymous>)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at Object.<anonymous> (/home/stuart/reactor/app.js:288:80)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        Mar 18 22:07:48 HP-Thin01 node[522]: SyntaxError: Unexpected end of JSON input
        Mar 18 22:07:48 HP-Thin01 node[522]: Promise {
        Mar 18 22:07:48 HP-Thin01 node[522]:   <rejected> SyntaxError: Unexpected end of JSON input
        Mar 18 22:07:48 HP-Thin01 node[522]: }
        Mar 18 22:07:48 HP-Thin01 node[522]: Trace
        Mar 18 22:07:48 HP-Thin01 node[522]:     at process.<anonymous> (/home/stuart/reactor/app.js:271:162)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at process.emit (node:events:390:28)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at process.emit (node:domain:475:12)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at emit (node:internal/process/promises:136:22)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at processPromiseRejections (node:internal/process/promises:242:25)
        Mar 18 22:07:48 HP-Thin01 node[522]:     at processTicksAndRejections (node:internal/process/task_queues:97:32)
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.582Z <app:ERR> Trapped unhandled Promise rejection: [SyntaxError]SyntaxError: Unexpected end of JSON input
        Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.582Z <app:ERR> Please refer to the console log for trace
        Mar 18 22:07:48 HP-Thin01 systemd[1]: reactor.service: Succeeded.
        Mar 18 22:05:28 HP-Thin01 node[402]: [latest-22069]2022-03-18T22:05:28.048Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/home/stuart/reactor/storage] failed to read sys_alerts in /home/stuart/reactor/storage/states/sys_alerts.json: [SyntaxError]SyntaxError: Unexpected end of JSON input
        Mar 18 22:05:28 HP-Thin01 node[402]: Trapped unhandled Promise rejection SyntaxError: Unexpected end of JSON input
        Mar 18 22:05:28 HP-Thin01 node[402]:     at JSON.parse (<anonymous>)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at Object.<anonymous> (/home/stuart/reactor/app.js:288:80)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        Mar 18 22:05:28 HP-Thin01 node[402]: SyntaxError: Unexpected end of JSON input
        Mar 18 22:05:28 HP-Thin01 node[402]: Promise {
        Mar 18 22:05:28 HP-Thin01 node[402]:   <rejected> SyntaxError: Unexpected end of JSON input
        Mar 18 22:05:28 HP-Thin01 node[402]: }
        Mar 18 22:05:28 HP-Thin01 node[402]: Trace
        Mar 18 22:05:28 HP-Thin01 node[402]:     at process.<anonymous> (/home/stuart/reactor/app.js:271:162)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at process.emit (node:events:390:28)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at process.emit (node:domain:475:12)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at emit (node:internal/process/promises:136:22)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at processPromiseRejections (node:internal/process/promises:242:25)
        Mar 18 22:05:28 HP-Thin01 node[402]:     at processTicksAndRejections (node:internal/process/task_queues:97:32)
        Mar 18 22:05:28 HP-Thin01 node[402]: [latest-22069]2022-03-18T22:05:28.097Z <app:ERR> Trapped unhandled Promise rejection: [SyntaxError]SyntaxError: Unexpected end of JSON input
          The disk going full has resulted in the corruption of your storage folder. You will need to restore a backup.
            What's the storage folder ?
            The entire reactor folder ?
              @cw-kid it's the folder called storage in your Reactor folder.
                Is that the folder with the rulesets in it ?
                I have a backup of all the folders and files, but it's not very recent.
                Hope I am not going to lose the more recent changes to the rules.
                  #28
                  Looks like it is
                  So they are all corrupted ?
                  There are hundreds of rules on those folders
                    #29
                    Looking in the current storage sub folders the "states" folder has a lot of the files in there are 0kb. But in the other folders like "rules" "rulesets" and "reactions" they still have data it seems and have kb values.
                      I just deleted all the files in the states folder on the Linux box there was 170 odd files. I then uploaded the files from the backup I had, there were 130 odd files. MSR has now started and loaded in the browser. But I am unsure what I have lost.
                        That's good sleuthing and good work. Yes, the states folder gets most of the I/O. If it looks like everything else is intact, that's fine. Rules and rule sets would only be damaged if you happened to edit them during the time the disk was full.
                        On the Reactor master device, there are flags for warning you when disk space is becoming limited; rules with notifications may be a good idea, to avoid future unpleasant surprises.
                          I am assuming I have had a lucky escape here then, all my rules look to be present still, I am assuming "States" is just that as the name suggests the current state of the rules and that they will rebuild and repopulate themselves.
                          I didn't have any auto backup in place as not really sure how to do that in Linux command line, so I was just now and again manually copying the entire contents of the /reactor folder down on to my PC.
                            All correct.
                              In Entities under Reactor System I have all this information
                              reactor_system.alert_count=0
                              reactor_system.alert_last=1647657325518
                              reactor_system.alert_severity=null
                              reactor_system.alerts=[]
                              reactor_system.arch="x64"
                              reactor_system.hostname="HP-Thin01"
                              reactor_system.internet_ok=null
                              reactor_system.platform="linux"
                              reactor_system.reactor_memory_used=138702848
                              reactor_system.reactor_uptime=1082
                              reactor_system.system_load=[0.13,0.15,0.11]
                              reactor_system.system_memory_free=2020356096
                              reactor_system.system_memory_size=3537993728
                              reactor_system.system_uptime=17002.98
                              reactor_system.volume_critical_reactor_base=false
                              reactor_system.volume_critical_reactor_data=false
                              reactor_system.volume_critical_reactor_logs=false
                              reactor_system.volume_reactor_base=[5390756,13825496,0.389,"/home/stuart/reactor"]
                              reactor_system.volume_reactor_data=[5390756,13825496,0.389,"/home/stuart/reactor/storage"]
                              reactor_system.volume_reactor_logs=[5390756,13825496,0.389,"/home/stuart/reactor/logs"]
                              sys_system.state=true
                              Capabilities: reactor_system, sys_system
                              Actions: reactor_system.clear_alert, reactor_system.clear_alerts, sys_system.restart
                              Memory free is that disk or RAM ?
                                SystemController - Reactor - Multi-Hub Automation
                                  Ok thanks I will read that tomorrow
                                  Also have to figure out why my Raspberry Pi has gone tits up, that's still totally down, but only InfluxDB and Grafana on there so not the end of the world.
                                    #37
                                    Patrick would it be possible for the system to detect if any state files have 0kb values and just delete them automatically ?
                                      Losing state will cause rules to possibly run unexpectedly. For example, say you had a rule that triggers between sunrise and sunset. If state was lost due to disk full corruption such as this in mid-day, discarding the state at restart will cause the rule to have no state, therefore think it has a transition into the sunrise (triggered) period and fire. This may or may not be a desirable side-effect, depending entirely on how the user determines the rules to work, and I cannot predetermine whether re-running a rule would have side-effects in the user environment or not. Since this can occur unattended (such as while on vacation or at a remote vacation home), it's potentially very troublesome and should at least be corrected with the full awareness of the user, as you have in this case.
                                      My number one recommendation is that you manage filesystem space well on the system. This is always an issue on all systems, and in Linux/Unix systems in particular, processes can die (due to errors) and files can become (logically) corrupt due to disk full conditions. It is something that needs to be managed. In your case, I would remember what log files were deleted, and investigate why those were so large and not being rotated and expired or archived. In your case, it appears you have a single root volume with everything on it. That means any subsystem running on the box can potentially fill the filesystem and cause other applications to misbehave. Best practices for system management often call for segmenting files/directories out. It is not uncommon, for example, to have /var, /usr and /home all on separate filesystems, that any one of them filling (/var often has this issue because it holds system logs and other fast-changing files) would not result in other files in the other directories to become corrupt or truncated. Taking this to an extreme, but if hardening Reactor is mission-critical to you, it is possible to create a small volume and mount it as /var/reactor at boot time, and use that as the home for the storage directory (and config, but not Reactor's logs), thereby isolating and protecting Reactor's storage from everything else. This is all Linux system management stuff, so not really appropriate to deep dive into, but if you're going to use and maintain these systems as part of your infrastructure, well worth spending the time to learn. A must really, because when it goes wrong, and it will go wrong, your fluency in system management will directly determine the time it takes to recover, and how well (or not) you recover.
                                      I can take more mitigating steps to harden startup, and I will definitely do that. I will also see about adding Status page alerts for disk space problems. The way Reactor works, if the disk space problem is mitigated before a restart of Reactor (i.e. while Reactor is running), Reactor will (eventually) rewrite the files with state (which is cached in RAM during operation) -- at shutdown, Reactor writes the RAM state back to disk as a final assurance that they are in sync, just for this reason. But I cannot protect those files from every eventuality, and every other subsystem on the machine works pretty much the same way (rebooting after fixing a no-space condition is always recommended, because many daemons will just die when they can't write a file).
                                      And as I've said again and again and again, please read the documentation and look at your log files. If you see something in the log files that points to obvious issue, handle it. If you don't know how to handle it, post the log file snippet and remember that context is vital, so posting 2-3 lines of a log file may provide little or no useful information (even when the error contains module names and line numbers); it often takes a dozen or more lines of context prior to really interpret how the system got to the crash point, so you must post a least a dozen or more lines prior to any error message you are inquiring about. Fortunately in this case, it was pretty obvious.
                                      Pardon errors. Tapping this out on a bluetooth keyboard and over my home VPN on sketchy Internet made this a bit of a chore. Onward.
                                        148.3k
