  4. Restart router when it's gone offline?
12 Posts 4 Posters 3.1k Views 4 Watching
  • F Offline
    wrote on last edited by Fanan
    Hi!
    Once a month or so, my internet access is lost, and I have to cut the power to the router, to restart it. When I'm away this become a problem, so I thought that if I got a zigbee switch (in Home Assistant), problem is solved. But how do I (MSR) know if it's offline?
    1. What's the easiest and most effective way to make this work? Do I ping a few websites every ten minutes or so, or is there a better approch?
    2. If I'm going to ping, what URL is recommended?
    For information, I have a set up with Asus routers, Home Assistent with zigbee-, z-wave and wifi devices (a total of appr. 150) and every of my 60-70 automation is done by MSR.
    I run MSR ver. 22080-ae7212f (docker on my Home Assistant blue). HA ver 2022.4.6.
    Thanks in advance.
    Take care, you all!
    /Fanan
      Yes, much better, thanks. There is a script to drive a boolean attribute on the Reactor system entity to track the up-down state of Internet access (bare metal users can find that in the tools subdirectory), but I can't guide you on how to get that running under Home Assistant Blue.
      Here's a thread that may help you get the equivalent running in Hass, which you would then be able to see as a binary sensor in Reactor: https://community.home-assistant.io/t/home-assistant-checking-if-internet-connection-is-online/313324
        Attention to the posting guidelines, please: need to know your host platform information, Reactor version number, etc.
        F 1 Reply Last reply
          @toggledbits my bad. I've added some info in my first post. Hopefully it's enough.
          /Fanan
              @toggledbits How does one make use of that script within MSR?
                The script header contains the simple instructions to get it up and running. From there, you just test the value of the Reactor System entity's attribute reactor_system.internet_ok
                G 2 Replies Last reply
                  @toggledbits When I review the readme in the config directory it says:
                  These are the distribution (original) versions of the Reactor configuration
                  files. You may keep them as a reference, or delete them (and this sub-
                  directory). The configuration files used in runtime are in the 'config'
                  subdirectory.
                  When I review the readme in the dist-config directory it says the same thing. Which one is the actual config directory (I'm betting config).
                    @toggledbits So digging thru the script/s a bit I went with config directory as the location.
                    Attempting to run the script ./reactor_inet_check.sh results in this:
                    Just for clarify, this is my config directory:
                    and I'm running MSR on RPi4 bare metal Model B 2GBs latest-22080-ae7212f.
                    • F Fanan has marked this topic as solved on
                      You have to run the script from the Reactor home directory.
                      cd /path/to/reactor
                      tools/reactor_inet_check.sh
                      wmarcolinW 1 Reply Last reply
                        Got this working brilliantly - thanks to @Fanan for the idea!
                          cd /path/to/reactor
                          @toggledbits hi!
                          To execute this command in windows? how would the script be triggered?
                            The included script only runs on Linux systems. A version of the script for Windows would make a great community contribution.
                            • F Fanan referenced this topic on
                              157.7k
