  3. "kinda smart" switch to put behind a normal light switch
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
18 Posts 6 Posters 5.3k Views 5 Watching
    The i3 is a bit wasteful if only a single switch. If it is a single switch why not go with a shelly 1 then you make the light smart and can also send http request or subscribe to device mqtt stat topic.
    • H Offline
      H Offline
      huhnmann
      That light switch has to work exactly as before. So the i3 seems to be the best option here, indeed. That is, if exactly this:
      Imgur
      imgur.com
      imgur.com
      Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
      is possible.
      As for the Shelly 1, I may have a different use. Is it possible to give power to a "door buzzer"*) for a predefined amount of time (like 5s)?
      😉 Sorry, I don't know the word for it in any language. It makes "bzzzzzz" and you can open the door.
      therealdbT ElcidE 2 Replies Last reply
      • H huhnmann
        Imgur
        imgur.com
        imgur.com
        is possible.
        @huhnmann yes, I’m using this to open a gate. This is often referred to as latching or pulsing. Shelly 1 has an option to turn off a relay after a given amount of time.
        H 1 Reply Last reply
          H Offline
          H Offline
          huhnmann
          @therealdb Perfect, thank you!
          • H huhnmann
            Imgur
            imgur.com
            imgur.com
            is possible.
            @huhnmann said in "kinda smart" switch to put behind a normal light switch:
            fitting a shelly 1 , the light should function as before but also have smart capabilities, so you get the best of both worlds
            • ElcidE Elcid
              H Offline
              H Offline
              huhnmann
              @elcid No, because the switch's off and on positions would change, every time its smart capabilities are used. Or is the Shelly 1 capable of physically flipping the switch's position?
              ElcidE 1 Reply Last reply
                This is why I use push switches, rather than toggle switches… can’t bear to see a toggle in the ‘wrong’ position for the light status. That’s OCD for you! Same is true for two or three way arrangements.
                I use the MK Grid switch hardware (in the UK) which allows you to swap out individual switches in a multi-switch wall plate.
                • H Offline
                  H Offline
                  huhnmann
                  wrote on last edited by huhnmann
                  No, that's normal, not OCD. 🙂 I could easily change the switch, but I need it to work exactly as it does now with exactly that switch. But you're right, of course, that this would make things easier.
                  • H huhnmann has marked this topic as solved on
                    @akbooer said in "kinda smart" switch to put behind a normal light switch:
                    I use Click Mode, good quality. These are not grid design but still all switches can be interchanged, the have mulitple inserts and colours. And the bonus of being cheaper than MK. and take less space in the box.
                    • H huhnmann
                      wrote on last edited by Elcid
                      @huhnmann You could still use the shelly 1 in the same way as a i3. You can disiconnect the relay from the switch. You then end up with what you required, and you are still left with future options if you change you requirements.
                      p.s. It is OCD no matter how much you deny it.
                      H G 2 Replies Last reply
                      • ElcidE Elcid
                        H Offline
                        H Offline
                        huhnmann
                        @elcid said in "kinda smart" switch to put behind a normal light switch:
                        Maybe, but in this case, it's called "old people compatibility".
                        But I'll have another look at the Shelly 1, thank you!
                        • ElcidE Elcid
                          @elcid CDO. It's like OCD but the letters are in the right order....
                            164.3k
