  4. Safari Mac Rule Sets Menu after upgrade build 21275
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
13 Posts 6 Posters 1.8k Views 6 Watching
    I can no longer access the Rule Sets menu after upgrading to build 21275. Nothing happens when I click on Rule Sets. Other menu options work fine. I have cleared history, hard refreshed the browser, Rebooted. Works fine in Firefox and google chrome. I have always used Safari.
    Suggestions?
    Safari for Mac version 15.0
    MSR Version 21275-df3d784
    Synology Docker
    • toggledbitsT Online
      toggledbitsT Online
      I don't have a Mac or Safari, but let's try this. Enable the "Develop" menu in your browser if you haven't already (Safari > Preferences > Advanced and find the checkbox to enable the menu). Then Cmd + Option + C opens the console. Refresh the page and try to click into the Rule Sets menu. See if logs anything useful to the console (post here).
      S 1 Reply Last reply
        @toggledbits I did as you suggested. It is showing an error on refresh but nothing changes when clicking Rule sets. If I continually hit refresh, sometimes the error is gone and then the rule sets menu works. It appears if I open in a private window the error is not there either.
        Edit: The reactor.log shows this also. I do not know if it related but I have no idea what the 172. address is.
        2021-10-03T19:07:55.494Z Engine:5:1448:Engine.js Engine#1 reaction rule-kpw0p0rl:R step 0 perform { "entity": "hubitat>11", "action": "power_switch.off" }
        2021-10-03T19:07:55.494Z HubitatController:null HubitatController#hubitat final action path for power_switch.off on Entity#hubitat>11: http://192.168.1.70/apps/api/416/devices/11/off
        2021-10-03T19:07:55.495Z Engine:5:1351:Engine.js _process_reaction_queue() task returned, new status 3; task 66
        2021-10-03T19:07:55.496Z Engine:5:1386:Engine.js _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting
        2021-10-03T19:07:55.538Z Engine:5:1386:Engine.js _process_reaction_queue() wake-up!
        2021-10-03T19:07:55.540Z Engine:5:1347:Engine.js _process_reaction_queue() running task 66 { "tid": 66, "id": "rule-kpw0p0rl:R", "rule": "rule-kpw0p0rl", "__reaction": [RuleReaction#rule-kpw0p0rl:R], "next_step": 1, "status": 1, "ts": 1633288075480, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 1 }
        2021-10-03T19:07:55.540Z Engine:NOTICE Resuming reaction Pantry Light<RESET> (rule-kpw0p0rl:R) from step 1
        2021-10-03T19:07:55.540Z Engine:INFO Pantry Light<RESET> all actions completed.
        2021-10-03T19:07:55.540Z Engine:5:1351:Engine.js _process_reaction_queue() task returned, new status -1; task 66
        2021-10-03T19:07:55.541Z Engine:5:1386:Engine.js _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
        2021-10-03T19:08:22.586Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1
        2021-10-03T19:08:30.307Z wsapi:INFO client "172.17.0.1#51" closed, code=1006, reason=
        2021-10-03T19:08:30.416Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1
        2021-10-03T19:08:31.621Z wsapi:INFO client "172.17.0.1#52" closed, code=1006, reason=
        2021-10-03T19:08:31.705Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1
          toggledbitsT Online
          Well, unfortunately, the message doesn't really help me. It points to a line with a class declaration, no variable reference on it at all. If it's actually complaining about something inside the class declaration, it isn't detailed enough to figure out what in over 1300 lines of code in that class it may be. My usual lint (code checking) tools don't complain, and other browsers don't, so while I'd like to fix it, I don't really have a path to fixing it, and you have other options, so I'm afraid it's going to stay broken for now.
          The 172 addresses are bridge addresses between your real network and the docker containers internal/virtual LAN.
          • S SweetGenius
            toggledbitsT Online
            toggledbitsT Online
            @sweetgenius said in Safari Mac Rule Sets Menu after upgrade build 21275:
            Kind of suggests something in your browser cache is a problem. Maybe try a hard refresh (always a good idea after an upgrade), and the usual debugging steps for this kind of thing: flush your browser cache and restart the browser, turn off all extensions, etc.
            Safari 15.0 was officially released about two weeks ago, and there are lots of reports of problems with commonly-used web sites, so I have doubts. Do some Google searches. Other things perhaps to try here: https://apple.stackexchange.com/questions/427935/safari-15-0-error-message-a-problem-repeatedly-occurred-catalina-10-15-7
              @toggledbits I agree, I think it's a browser issue. I have tried all the recommended fixes to no avail. Clear Caches, History, Hard Refresh, Reinstall etc.. Will see if they fix it in a later version of Safari. I have found if I keeping hitting refresh it I can get it to work or use a private window or other browser. So I have plenty of options.
              Thanks for the suggestions.
              MatohlM 1 Reply Last reply
              • V Offline
                V Offline
                @toggledbits Other information pertaining to this problem. Maybe you already know this, if so just disreguard.
                My wife has an Apple tablet and I have an android one along with a windows pc. I am using MSR on a pi with MSR version 21292. All is fine on the pc and android but on the ios tablet (ios 12.5.5), using safari or chrome, MSR start just fine but do not actually connect as indicated in the upper right corner with "connecting...". It never gets to connected status.
                If you need more info feel free to ask.
                Edit:
                The more I look at this the more this seemed to be a different issue since MSR is not connecting at all from the ios tablet. At the moment, I wonder if I should I open a different post?
                Using MSR 25139 on Docker, on a Raspberry Pi with Bookworm. Home Assistant 2025.07, Z-Wave JS-UI 10.6.1
                • S SweetGenius
                  MatohlM Offline
                  MatohlM Offline
                  Matohl
                  @sweetgenius I have the same issue but with Safari 14.2.1. I have to use Chrome on my Mac instead.
                  • SnowmanS Offline
                    SnowmanS Offline
                    Snowman
                    For me, running Safari Version 15.1 (15612.2.9.1.30, 15612) on macOS Catalina 10.15.7, it works sometimes and other times, it does not. At moment, I have to windows open. On one window, I can collapse the Rule Sets. On the other window, not happening. Weird.
                      A workaround: When you open MSR and before you click on any menus, if you see the Plus sign by Rule Sets then it is not going to work. If you click refresh repeatedly until the plus sign goes away then everything functions properly. The uninitialized variable error in the code window goes away also.
                      Screen Shot 2021-11-06 at 12.49.17 PM.png Screen Shot 2021-11-06 at 12.50.13 PM.png
                      • S SweetGenius
                        This works beautifully, thanks for this!
                        *Hubitat C-7 2.4.3.177
                        Core 2026.1.1
                        MSR: latest-26011-c621bbc7
                          @gwp1 With build latest-21321-c2fda1c, this problem has gone away. It might be a coincidence but on two different Mac accounts this is now working for me. Are you still having the issue?
                            Unfortunately, I can't correlate with any specific builds but, yes, I've noticed recently it's WAE.
                            Core 2026.1.1
                              987
                              2.0k
                              3.7k
                              3.3k
