  4. Safari Mac Rule Sets Menu after upgrade build 21275
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
13 Posts 6 Posters 3.3k Views 6 Watching
    I don't have a Mac or Safari, but let's try this. Enable the "Develop" menu in your browser if you haven't already (Safari > Preferences > Advanced and find the checkbox to enable the menu). Then Cmd + Option + C opens the console. Refresh the page and try to click into the Rule Sets menu. See if logs anything useful to the console (post here).
    S 1 Reply Last reply
      @toggledbits I did as you suggested. It is showing an error on refresh but nothing changes when clicking Rule sets. If I continually hit refresh, sometimes the error is gone and then the rule sets menu works. It appears if I open in a private window the error is not there either.
      Edit: The reactor.log shows this also. I do not know if it related but I have no idea what the 172. address is.
      2021-10-03T19:07:55.494Z Engine:5:1448:Engine.js Engine#1 reaction rule-kpw0p0rl:R step 0 perform { "entity": "hubitat>11", "action": "power_switch.off" }
      2021-10-03T19:07:55.494Z HubitatController:null HubitatController#hubitat final action path for power_switch.off on Entity#hubitat>11: http://192.168.1.70/apps/api/416/devices/11/off
      2021-10-03T19:07:55.495Z Engine:5:1351:Engine.js _process_reaction_queue() task returned, new status 3; task 66
      2021-10-03T19:07:55.496Z Engine:5:1386:Engine.js _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting
      2021-10-03T19:07:55.538Z Engine:5:1386:Engine.js _process_reaction_queue() wake-up!
      2021-10-03T19:07:55.540Z Engine:5:1347:Engine.js _process_reaction_queue() running task 66 { "tid": 66, "id": "rule-kpw0p0rl:R", "rule": "rule-kpw0p0rl", "__reaction": [RuleReaction#rule-kpw0p0rl:R], "next_step": 1, "status": 1, "ts": 1633288075480, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 1 }
      2021-10-03T19:07:55.540Z Engine:NOTICE Resuming reaction Pantry Light<RESET> (rule-kpw0p0rl:R) from step 1
      2021-10-03T19:07:55.540Z Engine:INFO Pantry Light<RESET> all actions completed.
      2021-10-03T19:07:55.540Z Engine:5:1351:Engine.js _process_reaction_queue() task returned, new status -1; task 66
      2021-10-03T19:07:55.541Z Engine:5:1386:Engine.js _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
      2021-10-03T19:08:22.586Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1
      2021-10-03T19:08:30.307Z wsapi:INFO client "172.17.0.1#51" closed, code=1006, reason=
      2021-10-03T19:08:30.416Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1
      2021-10-03T19:08:31.621Z wsapi:INFO client "172.17.0.1#52" closed, code=1006, reason=
      2021-10-03T19:08:31.705Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1
        Well, unfortunately, the message doesn't really help me. It points to a line with a class declaration, no variable reference on it at all. If it's actually complaining about something inside the class declaration, it isn't detailed enough to figure out what in over 1300 lines of code in that class it may be. My usual lint (code checking) tools don't complain, and other browsers don't, so while I'd like to fix it, I don't really have a path to fixing it, and you have other options, so I'm afraid it's going to stay broken for now.
        The 172 addresses are bridge addresses between your real network and the docker containers internal/virtual LAN.
        • S SweetGenius
          @sweetgenius said in Safari Mac Rule Sets Menu after upgrade build 21275:
          Kind of suggests something in your browser cache is a problem. Maybe try a hard refresh (always a good idea after an upgrade), and the usual debugging steps for this kind of thing: flush your browser cache and restart the browser, turn off all extensions, etc.
          Safari 15.0 was officially released about two weeks ago, and there are lots of reports of problems with commonly-used web sites, so I have doubts. Do some Google searches. Other things perhaps to try here: https://apple.stackexchange.com/questions/427935/safari-15-0-error-message-a-problem-repeatedly-occurred-catalina-10-15-7
            @toggledbits I agree, I think it's a browser issue. I have tried all the recommended fixes to no avail. Clear Caches, History, Hard Refresh, Reinstall etc.. Will see if they fix it in a later version of Safari. I have found if I keeping hitting refresh it I can get it to work or use a private window or other browser. So I have plenty of options.
            Thanks for the suggestions.
            MatohlM 1 Reply Last reply
            • V Offline
              V Offline
              @toggledbits Other information pertaining to this problem. Maybe you already know this, if so just disreguard.
              My wife has an Apple tablet and I have an android one along with a windows pc. I am using MSR on a pi with MSR version 21292. All is fine on the pc and android but on the ios tablet (ios 12.5.5), using safari or chrome, MSR start just fine but do not actually connect as indicated in the upper right corner with "connecting...". It never gets to connected status.
              If you need more info feel free to ask.
              Edit:
              The more I look at this the more this seemed to be a different issue since MSR is not connecting at all from the ios tablet. At the moment, I wonder if I should I open a different post?
              • S SweetGenius
                MatohlM Offline
                MatohlM Offline
                Matohl
                @sweetgenius I have the same issue but with Safari 14.2.1. I have to use Chrome on my Mac instead.
                • SnowmanS Offline
                  SnowmanS Offline
                  Snowman
                  For me, running Safari Version 15.1 (15612.2.9.1.30, 15612) on macOS Catalina 10.15.7, it works sometimes and other times, it does not. At moment, I have to windows open. On one window, I can collapse the Rule Sets. On the other window, not happening. Weird.
                    A workaround: When you open MSR and before you click on any menus, if you see the Plus sign by Rule Sets then it is not going to work. If you click refresh repeatedly until the plus sign goes away then everything functions properly. The uninitialized variable error in the code window goes away also.
                    Screen Shot 2021-11-06 at 12.49.17 PM.png Screen Shot 2021-11-06 at 12.50.13 PM.png
                    • S SweetGenius
                      This works beautifully, thanks for this!
                        @gwp1 With build latest-21321-c2fda1c, this problem has gone away. It might be a coincidence but on two different Mac accounts this is now working for me. Are you still having the issue?
                          Unfortunately, I can't correlate with any specific builds but, yes, I've noticed recently it's WAE.
                            165.6k
