  3. Re-number on OpenLuup
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
4 Posts 3 Posters 1.5k Views 2 Watching
    Morning all. Hope all are well. Been a bit of a trying time here, but nothing we can't deal with....
    .....apart from this!
    My coffee grinder went punk yesterday (wasn't even being used) and took out the main breakers. Once it was isolated I got everything back on line, except on TKB smart plug which was in the same double socket as the grinder.
    OpenLuup claims it's failed. Z-wave server can't see it but it responds to the button pushes physically as I'd expect. (i.e. the socket turns on and off, and the LED flashes to indicate it's in inclusion / exclusion mode)
    My plan is to see if I can exclude it then re-include it in z-wave server. If that doesn't work then I'll bin it, but if it does work can I then re-number it to match the original device ID and not have to trawl through my reactors? Any chance?
    TIA
      TIA
      @catmanv2 if you're using the Reactor plug in, there's a device replacement tool on the tools menu that will appear when the failed device is deleted.
      • K Offline
        K Offline
        kfxo
        Is it marked as failed in z-wave (z-way?) server? If you can reset the device without excluding it, I think you can use the replace failed node operation on the z-way server control section.
          @toggledbits said in Re-number on OpenLuup:
          Well I've just replaced the coffee grinder so normal service should be resumed shortly
          @kfxo said in Re-number on OpenLuup:
          It is marked as failed indeed.
          I was distracted and this post wasn't sent. I couldn't remove it from z-wave as it was waiting on an interview.
          It re-added fine as a new device and I've just edited Reactor manually.
          Cheers
          • CatmanV2C CatmanV2 has marked this topic as solved on
            146.1k
