  4. Multidimensional Array
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
28 Posts 3 Posters 12.7k Views 2 Watching
    @wmarcolin I smell an X-Y problem, but I'll go on...
    I don't know what "bidirectionally" means in this context. Do you mean "two dimensional?" Bidirectional refers to movement, for example, forwards and backwards, or up and down, which is a different thing.
    A couple of minor comments to @Elcid 's response:
    ${{[["Window 1","Status On"],["Window 2","Status On"],["Window 3","Status Off"],["Window 4","Status On"]]}}
    Note that this is substitution syntax, not expression syntax when defining a variable. Adjust accordingly.
    each val in testarray : if val[1] === "Status On" then val[0] endif
    There is no === operator in the expression language, it's just ==
    (each val in testarray : if val[0] === "Window 1" then val[1] endif)[0]
    This is better written as first ... of ..., since you only want the one element (which by implication here the key "Window 1" must be unique in the array), and there's no need to keep searching through the array once you've found it (wastes CPU cycles).
    But about that uniqueness for "Window 1"... this is the real meat of my response:
    If the first element of each subarray (row) is unique, then using a two-dimensional array is inefficient (i.e. doable, but not the best choice). Where unique values are present, an object containing key/value pairs gives immediate random access to any "element", without iteration:
    devices = {
        "lamp1": "on",
        "lamp2": "off",
        "lamp3": "on"
    In this example, we can quickly determine the status of any lamp without iteration: devices.lamp2 will give us off.
    This can be further broken down with additional data: each value in the key/value pairs of the object can be any data type, so they can be an array or object themselves:
    devices = {
        "lamp1": {
            "status": "on",
            "room": 0
        "lamp2": { "status": "off", "room": 0 }
        "lamp3": { "status": "on", "room": 2 }
    We can again quickly get to the state of lamp2 using devices.lamp2.status (result off again). Using devices.lamp3.room tells us that lamp3 is in room 2. Note that in the example code above, I have shown lamp1 with a typical (JSON-style) fully indented with line breaks for readability, but lamp2 and lamp3 are in a more compact form. Whitespace (including newlines) are not significant to the syntax. Use them for readability if you wish, or leave them out for compactness if that's acceptable.
    When you must search within the values, you can still use iteration. Find the devices in room 0:
        each dev,id in devices: dev.room==0 ? id : null
    By using each dev,id, the iterator will provide both the value and the key for each pair in the object. That is, on the first iteration, dev will contain our subobject (itself with keys status and room) for lamp1, and id will contain lamp1; on the second iteration, the subobject for lamp2 is given in dev, and id is lamp2, and so on. The result of the iteration in this case is an array of IDs of objects in room 0: ["lamp1","lamp2"]; you could also modify the iteration to return the data objects (using dev), if that was more efficient for your later use of this expression's result.
    Find the first device that is "off":
        first dev,id of devices: dev.status=="off" ? id : null
    Adding new devices after the initialization is also easy:
        devices.lamp4 = { "status": "on", "room": 2 }
    But this is all data storage theory, and details of an implementation for a problem that apparently hasn't been stated. We need to know what you are really trying to do, if you are asking for help getting it done. As I said, where we stand right now, this seems very X-Y-ish. The post title is also poor quality, and the head post itself breaks a couple of the posting guidelines.
    wrote on last edited by Elcid
    @toggledbits said in Multidimensional Array:
    Not according to your doc's.
    Also used in a test expression and working.
    Noted used "in" rather than "of" as I thought he wanted a 2D array not a object/dictionary.
    wmarcolinW toggledbitsT 2 Replies Last reply
    • ElcidE Elcid
      @elcid actually, for the final search result, it was easier with object/dictionary, but it could have been done by array as well. Thanks, you also taught me how to make an array that will be useful for sure, it always is.
      • ElcidE Elcid
        @elcid said in Multidimensional Array:
        You are correct, I'm suffering from holiday brain-fade.
        @wmarcolin Version 21331 just released has the first release of dynamic groups. It also includes a syntax enhancement to the expression first...in statement to allow a result expression, so it can return something other than what it finds (i.e. it can perform operations on what it finds and return that as a result). This is useful for your var4 of this post, which should be first dev,id of devices: dev.group=="DevDoor": id to give you the ID of the first matching device. But again, I think the combination of primary attribute assignment and dynamic groups is going to be the best way to solve this.
          @toggledbits Hi!
          Perfect, you have totally changed the command.
          first dev,id in var1 with dev.group=="DevDoor": dev.devid
          I'm going to study the dynamic group, because even though I can compare object or array contents, the usage is horrible. It's very difficult to validate an array inside another one, or to make combined selections.
          Well, I don't really know the language, so I'm having a hard time. Let's see if the dynamic groups can make something that should be simple easier.
          I'll return tomorrow with my experiences 🙂
            Hi Patrick!
            I don't know if I'm doing something wrong, but I followed the following steps to use DynamicGroupController.
            1. Stopped the MSR
            2. Compared the reactor configuration file
            3. Added the new Groups instruction, the one in the file is almost the same as the manual, and below is the one I set up.
              - id: groups
                enable: true
                  groups:
                    "low_battery":
                      name: Low Battery Devices
                        - include_capability:
                          - battery_power
                      filter_expression: >
                        entity.attributes.battery_power.level < 0.35
                    "tripped":
                          - binary_sensor
                          - motion_sensor
                        entity.attributes.binary_sensor.state == true or
                        entity.attributes.motion_sensor.state == true
            1. I restarted MSR + Tools Restart + Crtl+F5 🙂
            2. Search in Entities and I see that they are created, but without content
            1. Check if they are available for action, yes but also without content.
            1. As the master instructed, let's go to the log file.
            [latest-21331]2021-11-27T21:13:45.136Z <default:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
            [latest-21331]2021-11-27T21:13:45.137Z <default:NOTICE> Controller OWMWeatherController#weather is now online.
            [latest-21331]2021-11-27T21:13:46.538Z <VeraController:NOTICE> Controller VeraController#vera is now online.
            [latest-21331]2021-11-27T21:13:46.540Z <default:ERR> error updating dynamic group low_battery_entries: Error: Invalid selector key
            [latest-21331]2021-11-27T21:13:46.541Z <default:CRIT> Error: Invalid selector key
                at DynamicGroupController._select (C:\MSR\reactor\server\lib\DynamicGroupController.js:260:23)
                at DynamicGroupController._update_group (C:\MSR\reactor\server\lib\DynamicGroupController.js:193:45)
                at C:\MSR\reactor\server\lib\DynamicGroupController.js:243:38
                at DynamicGroupController._update (C:\MSR\reactor\server\lib\DynamicGroupController.js:240:95)
                at C:\MSR\reactor\server\lib\DynamicGroupController.js:150:42
            [latest-21331]2021-11-27T21:13:46.543Z <default:ERR> error updating dynamic group tripped_entries: Error: Invalid selector key
            [latest-21331]2021-11-27T21:13:46.544Z <default:CRIT> Error: Invalid selector key
            [latest-21331]2021-11-27T21:13:46.544Z <app:NOTICE> Starting HTTP server and API...
            [latest-21331]2021-11-27T21:13:46.552Z <app:NOTICE> Starting Reaction Engine...
            Well, I found this error, and obviously, I don't know how to solve it. What I did? I reinstalled the MSR, using only the config and storage directory, and the result is the same.
              The groups would be empty if there were no tripped or low battery devices in their respective groups, so that's not all conclusive; it may be perfectly correct. The groups at least appear to be correct, for empty groups (no entities matched).
              The time stamps in your log snippet are unrelated to the time stamp on the entities, so I can't really draw any conclusions from that either. If you post logs, make sure you are posting logs where the time stamps align to the problem you're reporting.
              On your conditions, you can't compare an array to an empty string; that's not a valid test.
              wmarcolinW 1 Reply Last reply
                Ok let's go in parts, what I created in Group is the same thing I do in the traditional way and get the result, see the battery case.
                I'm not seeing an error anymore, after a reboot of the MSR host.
                [latest-21331]2021-11-28T02:45:18.584Z <default:null> Module httpapi v21308
                [latest-21331]2021-11-28T02:45:18.661Z <VeraController:null> Module VeraController v21324
                [latest-21331]2021-11-28T02:45:18.668Z <default:INFO> Structure#1 loading controller interface hubitat (HubitatController)
                [latest-21331]2021-11-28T02:45:18.676Z <HubitatController:null> Module HubitatController v21324
                [latest-21331]2021-11-28T02:45:18.679Z <default:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                [latest-21331]2021-11-28T02:45:18.686Z <DynamicGroupController:null> Module DynamicGroupController v21331
                [latest-21331]2021-11-28T02:45:18.688Z <default:INFO> Structure#1 loading controller interface weather (OWMWeatherController)
                [latest-21331]2021-11-28T02:45:18.693Z <OWMWeatherController:null> Module OWMWeatherController v21313
                [latest-21331]2021-11-28T02:45:18.761Z <default:INFO> Starting controller HubitatController#hubitat
                [latest-21331]2021-11-28T02:45:18.782Z <default:INFO> Starting controller DynamicGroupController#groups
                [latest-21331]2021-11-28T02:45:18.784Z <default:NOTICE> Controller DynamicGroupController#groups is now online.
                [latest-21331]2021-11-28T02:45:18.785Z <default:INFO> Starting controller OWMWeatherController#weather
                I see that the times are synchronized
                But the array is still empty
                Any instructions where I can look for something?
                  The recommended debugging for this would be to start unraveling your criteria and see what it produces. As a first step (don't do this, just read), I would remove the filter_expression and make sure that your selectors are producing the expected set of eligible devices. An easy way to do that is to simply put an "X" in front of filter_expression (i.e. to make it Xfilter_expression), which changes the name of the key and hides it from the code that's looking for it. You could also comment it out, but that would require that you comment each subordinate line as well, which is more work and can be error-prone. Restart MSR after config changes, of course, and refreshes are also recommended (don't need to be hard refreshes).
                  But, I found an error, and it's pretty subtle. For me, it logged one short line, so it would be easy to miss; I imagine you have it as well. But it's going to require a code change to fix, so I'll release another build later today. I'll also fix the doc issue you PM'd me about.
                  Also, don't forget that filtering by controller or capability is a good way to quickly remove "noise" from your Entities list.
                    I debugged removing filter_axpression entirely, and the variables are still empty. I'll wait for your version update and test again.
                      @toggledbits well done
                      Low Battery Devices charging perfect!
                      But there is a problem for "tripped", which repeated the same setting as "low_battery".
                        - id: groups
                          enable: true
                            groups:
                              "low_battery":
                                    - battery_power
                              "tripped":
                                    - binary_sensor
                                    - motion_sensor
                      This is what is showing up in the log.
                      [latest-21332]2021-11-29T01:49:33.599Z <default:ERR> error updating dynamic group tripped: ReferenceError: Invalid reference to member state of null
                      [latest-21332]2021-11-29T01:49:33.600Z <default:CRIT> ReferenceError: Invalid reference to member state of null
                          at _run (C:\MSR\reactor\common\lexp.js:1369:31)
                          at _run (C:\MSR\reactor\common\lexp.js:1233:34)
                          at _run (C:\MSR\reactor\common\lexp.js:1290:44)
                          at C:\MSR\reactor\common\lexp.js:1223:29
                          at _run (C:\MSR\reactor\common\lexp.js:1222:28)
                          at Object.run (C:\MSR\reactor\common\lexp.js:1564:22)
                          at DynamicGroupController._update_group (C:\MSR\reactor\server\lib\DynamicGroupController.js:229:141)
                          at C:\MSR\reactor\server\lib\DynamicGroupController.js:267:39
                      Would I have to include any additional information in the configuration to not have this problem with null?
                        In your expression, you are not guarding for entities that have binary_sensor but do not have motion_sensor, and vice versa. Use the coalescing member access operator ?. in the two sub-expressions.
                          Perfect, solved, after putting the ?. in several places until I discovered how to use it correctly 😁
                                  "tripped":
                                        - binary_sensor
                                        - motion_sensor
                                      entity.attributes?.binary_sensor?.state == true or
                                      entity.attributes?.motion_sensor?.state == true
                          Boss, this thread started because I want to associate to each device an information of which group it would belong inside my system, external information that I will have to prepare manually, we started with the array, then we went to object, until you announce this new function.
                          What is the way now? At this moment my progress is to have in a more simplified way the ID of the devices that will understand a condition, now how in the case of Tripped I will be able to associate to the groups, the list assembled before? I already saw that I can have a global variable with the information, that this Dynamic instruction by the manual will be able to read.
                          Could you put together an example please?
                          • wmarcolinW wmarcolin
                                    "tripped":
                                          - binary_sensor
                                          - motion_sensor
                            #23
                            @wmarcolin said in Multidimensional Array:
                            You still haven't stated why you want to do this, so in my view, we're on the Y of an X-Y problem. What you are asking seems an odd thing to do... error-prone, laborious, hard to maintain. If I understood why you think you need to do it, we might arrive at a better solution that works from existing functionality, or a clear requirement for a new feature. When I asked before for this clarification (and repair of the topic title), you replied with a restatement of your implementation question, not an explanation of the problem you are trying to solve (i.e. why you want to do the implementation you are asking about), just as you've again done now.
                            If I ask you how to ventilate an enclosed space that has small windows and a doorway that is usually left open, given no other information, what might you suggest?
                            Would you answer differently if I also told you in advance that the space will be a new module for the International Space Station?
                              Ok, I will try to explain what I want to do.
                              When using Vera, I in the Dashboard > My Modes panel determined which devices could trigger the house alarm in a given mode. With the change to Hubitat has no equal to Vera, and also not wanting to depend on the hub anymore, I want to have total control of the situation.
                              I thought about creating device groups (yes manually for now), i.e.: door group, window group, motion sensors, sensors like CO and water, and devices that should alarm and are not in the other groups.
                              So when I activate for example the night mode I want to trigger the alarm if the devices that are in the door group are tripped. If I enter Away mode, I want to join the devices' doors, windows, and motion. In Vacation mode, I put everything together and monitor if any device is tripped to trigger the alarm.
                              Another example, I can put all the liquid sensor devices in a water detector group, so when I evaluate the rule I refer to the group, and not to each device. You could say more there, just see who has leak_detector_state, but as we discussed before there is no standard, remember the discussion of the binary_sensor standard?
                              Another situation we could put together, the same way I put the door and window group together in Away mode, I could use it to if nothing is tripped, allow the central air in the house to work.
                              Trying to make a summary is, in a single table (beginning of this thread), I determine which group the device belongs to and do actions by group and not having to identify each device, we can say that it would be the equivalent in Vera as category_num and subcategory_num, and again this is from Vera, and they made mistakes by not respecting the table they created and both icon and device behavior not working, but it was interesting the grouping table (http://wiki.micasaverde.com/index.php/Luup_Device_Categories).
                              That is why even in this thread I thought if there was a way to add a group attribute to the devices in the MSR table, and by a set variable align this information, it did not work because you explained that if it does not come from the hub, there is no way to load the information.
                              Did I succeed in explaining the scenario?
                              Where I am at this moment:
                              1. I created the object as you taught:
                                DeviceList = {
                                "vera>device_489": {group:"Door"},
                                "vera>device_432": {group:"Door"},
                                "hubitat>99": {group: "Window"},
                                "hubitat>15": {group: "Window"},
                                "vera>device_1672": {group:"Sensor"},
                                "vera>device_1867": {group:"Sensor"},
                                "vera>device_22": {group: "Security"},
                                "vera>device_1679": {group:"Security"},
                                "hubitat>1": {group: "Security"},
                                "vera>device_1822": {group:"Security"}
                              2. Now with Dynamic I have it easy that it is tripped;
                              3. I have a global variable that is loaded in each mode, DeviceAlarm, which is an object that I put who will be monitored in the activated mode, for example, set variable DeviceAlarm = ${{["Door", "Window"]}}.
                              What I don't know how to do now, I don't dominate the programming/language, is how to ask and/or put together Dynamic's tripped + DeviceList object + DeviceAlarm + Device name.
                              What do I look for? Who is Tripped (Dynamic Tripped), with the parameter filter (DeviceAlarm), in the device list (Object DeviceList)? Give me the device name in one variable, and a second variable the list of Groups that are tripped. In this second answer, I pass the list of what I want to look at in DeviceAlarm, but it should only return what is tripped.
                              Sorry for the bother, and you are right that I am joining topics from several different threads. I'm just trying to have something that could make the operation easier, and optimize the code in my view.
                                  DeviceList = {
                                @wmarcolin Hubitat has modes, and it has the Hubitat Safety Monitor (HSM), both of which are supported by Reactor. HSM can set arming based on detection level, so it's worth looking into.
                                If you still want to keep it all off hub, I would simply make groups:
                                • door_sensors: include_capability: door_sensor
                                • leak_sensors: include_capability: leak_detector
                                • motion_sensors: include_capability: motion_sensor
                                The create "tripped" versions of each:
                                • door_sensors_tripped: include_group: door_sensors, filter_expr: entity.attributes.door_sensor.state
                                • leak_sensors_tripped: include_group: leak_sensors, filter_expr: entity.attributes.leak_detector.state
                                • etc.
                                Creating these extra tripped groups does two things for you: (1) it isolates the expression to the capability, so you don't have to worry about motion_sensor.state vs leak_detector.state within a single group, the group is homogenous; and (2) by segmenting the devices to type, you more easily make the conditions for what devices are active in what security mode.
                                Then in your alarm rules for Night, Away, Vacation modes, you check if the tripped group for each group you are interested in for that mode is empty or not. So for Night, you would only be checking door_sensors_tripped, while for Away it will be the tripped door, window, and motion groups.
                                (ignore my group name -- I just picked a group I had to illustrate how the condition may be set up)
                                You don't need any variables at all (global or otherwise) to do what's described using dynamic groups.
                                  • etc.
                                  #26
                                  @toggledbits first of all thank you for the quick response, and this may be one way.
                                  However (sorry), I see a disadvantage, we use the case of sensors with the attribute door_sensor they are valid for access doors to the house, but are also for windows (first and second floor of the house, and the second floor is not turned on in night mode), and the same attribute has the internal door sensors, which in this case I use for air conditioning management (open door turns off the air).
                                  Another example would be the motion_sensor, I have internal and external sensors, in night mode the external ones turn on the garage and entrance lights, if I group everything by the attribute a movement inside the house would also trigger.
                                  This way your proposal is very valid, but there should be a way to dismember the groups, i.e. door_sensors_group1 (external door), door_sensors_group2 (window 1), door_sensor_group3 (internal door).... that's why I thought about the table that could specify each device and not use an attribute that generalizes the devices.
                                  I don't know if there could be something in these instructions referring to the global object we commented on DeviceList.
                                  door_sensors: include_capability: door_sensor %(#ff0000)[contained in DeviceList = "Door External".]
                                  or would it be something in this instruction
                                  door_sensors_tripped: include_group: door_sensors, filter_expr: entity.attributes.door_sensor.state %(#ff0000)[contained in DeviceList = "Door External".]
                                  (please don't laugh at my coding, I said I don't know it))
                                  The excellent thing is that we are going to take more automatic paths as you are commenting.
                                  Despite not wanting to depend on a hub, I looked at the HSM option, I see that it would be possible to create the groups I have commented, now I did not understand your comment that the MSR would talk to the HSM.
                                  In HSM the actions I see are alert by text, audio, siren or light. The way, in this case, would be to create a virtual device connected with HSM, and this one the MSR would monitor to take action?
                                  In the Apps that I set up the MSR, I don't see the option to select on device the action I created in the HSM. I have the option Allow control of HSM activated. Do I have to configure anything to show up on the MSR?
                                  Fact that I will not make Hubitat take action, who performs action in my solution is the MSR.
                                    door_sensors: include_capability: door_sensor contained in DeviceList = "Door External".
                                    No, you can't refer to global variables in a group filter expression.
                                    Make as many groups as you need/want.
                                    Find the entity called "Safety Monitor" in the Entities list (hint: use the filters; it will come from your Hubitat controller, and it will have capability x_hubitat_hsm, as well as that very distinct name, so lots of ways to find it).
                                      Well, you put me to think a lot, I'm reviewing all the logic and I think progressing. You could have a video lesson on Creating Automations > Expressions 🙂 I am looking to meet this with trial and error. I just tested this on Groups and it worked perfectly, it will help:
                                          "internal_move":
                                            name: Internal Move Devices
                                              - include_entity:
                                                - "vera>device_1679"
                                                - "vera>device_1683"
                                                - "vera>device_1797"
                                                - "hubitat>1"
                                                - "hubitat>14"
                                      Now from your last comment about the MSR visualizing the HSM, I really don't know what I have to do, the Safe Monitor you commented appears, but it is all Disarmed.
                                      But in the HSM in the hub the rules are created, activated, and even with action alert activated.
                                      Any recommendations on what I should do?
                                      Thanks,
                                        163.0k
