  4. [SOLVED] Hubitat type guessing and extra attributes v21336-Synology Docker
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
7 Posts 3 Posters 1.1k Views 3 Watching
    In version 21336 the HubitatController: can't assign x_hubitat_extra_attributes value as primary attribute issue that was previously fixed (Mantis 261) has returned. If I remove the local_hubitat_devices.yaml and restart, the experimental "type guessing" feature does a pretty good job of assigning the primary attributes on most devices. I wouldn't expect MSR to guess an extra attribute but setting it manually causes the error again.
    [latest-21336]2021-12-03T17:29:05.399Z <Structure:INFO> Starting controller HubitatController#hubitat
    [latest-21336]2021-12-03T17:29:05.430Z <Structure:INFO> Starting controller OWMWeatherController#weather
    [latest-21336]2021-12-03T17:29:05.461Z <Structure:INFO> Starting controller SystemController#reactor_system
    [latest-21336]2021-12-03T17:29:05.462Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
    [latest-21336]2021-12-03T17:29:05.487Z <app:INFO> Structure running; pausing for controllers' initial ready
    [latest-21336]2021-12-03T17:29:05.517Z <HubitatController:NOTICE> HubitatController#hubitat not ready; performing initial connect/query
    [latest-21336]2021-12-03T17:29:05.534Z <HassController:NOTICE> HassController#hass connected, starting protocol
    [latest-21336]2021-12-03T17:29:05.540Z <HassController:INFO> HassController#hass successful authentication with ws://192.168.1.21:8123; fetching initial data...
    [latest-21336]2021-12-03T17:29:05.544Z <HassController:INFO> HassController#hass Hass reports version "2021.11.5" location Home timezone America/Chicago state RUNNING safe_mode false
    [latest-21336]2021-12-03T17:29:05.632Z <HassController:NOTICE> Controller HassController#hass is now online.
    [latest-21336]2021-12-03T17:29:05.799Z <Entity:ERR> Entity#hubitat>568 attempt to set primary to x_hubitat_extra_attributes.Status invalid: capability not extended
    [latest-21336]2021-12-03T17:29:05.800Z <HubitatController:WARN> HubitatController#hubitat can't set local primary attribute x_hubitat_extra_attributes.Status on Entity#hubitat>568: Error: Invalid primary attribute assignment; capability not assigned (x_hubitat_extra_attributes.Status)
    [latest-21336]2021-12-03T17:29:05.817Z <Entity:ERR> Entity#hubitat>481 attempt to set primary to x_hubitat_extra_attributes.dbSize invalid: capability not extended
    [latest-21336]2021-12-03T17:29:05.818Z <HubitatController:WARN> HubitatController#hubitat can't set local primary attribute x_hubitat_extra_attributes.dbSize on Entity#hubitat>481: Error: Invalid primary attribute assignment; capability not assigned (x_hubitat_extra_attributes.dbSize)
    [latest-21336]2021-12-03T17:29:05.825Z <HubitatController:INFO> HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.1.70/eventsocket
    [latest-21336]2021-12-03T17:29:05.842Z <HubitatController:INFO> HubitatController#hubitat successful connection to ws://192.168.1.70/eventsocket
    [latest-21336]2021-12-03T17:29:05.856Z <HubitatController:NOTICE> HubitatController#hubitat current mode is Day (1)
    [latest-21336]2021-12-03T17:29:05.859Z <HubitatController:NOTICE> Controller HubitatController#hubitat is now online.
    [latest-21336]2021-12-03T17:29:06.088Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
    [latest-21336]2021-12-03T17:29:06.089Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
    [latest-21336]2021-12-03T17:29:06.090Z <app:NOTICE> Starting HTTP server and API...
      Thanks for reporting. Good info/post content. A little tension between trying to make data more deterministic and trying to keep it flexible; always an uphill battle. Just doing a little more testing. New build shortly.
        Build 21337 fixed the issue. Thanks!
        I do not know how to mark the post Solved.
          Good news.
          Just edit the title (by editing your original post) and put [SOLVED] in front.
          S 1 Reply Last reply
            Good news.
            @toggledbits said in Hubitat type guessing and extra attributes v21336-Synology Docker:
            Smh, I thought about that but thought there must be a way to mark it. I tend to make things more complicated than it need to me. Thanks
            • S SweetGenius
              @sweetgenius I'm not sure there is in this forum software, but I'm no expert at it. Paging @DesT -- is there a way to mark an issue solved other than editing the title?
              DesTD 1 Reply Last reply
                DesTD Offline
                DesTD Offline
                DesT
                @toggledbits Let me check in the plugin 😉
                  2.1k
