  4. [SOLVED] Hubitat type guessing and extra attributes v21336-Synology Docker
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
7 Posts 3 Posters 1.5k Views 3 Watching
    In version 21336 the HubitatController: can't assign x_hubitat_extra_attributes value as primary attribute issue that was previously fixed (Mantis 261) has returned. If I remove the local_hubitat_devices.yaml and restart, the experimental "type guessing" feature does a pretty good job of assigning the primary attributes on most devices. I wouldn't expect MSR to guess an extra attribute but setting it manually causes the error again.
    [latest-21336]2021-12-03T17:29:05.399Z <Structure:INFO> Starting controller HubitatController#hubitat
    [latest-21336]2021-12-03T17:29:05.430Z <Structure:INFO> Starting controller OWMWeatherController#weather
    [latest-21336]2021-12-03T17:29:05.461Z <Structure:INFO> Starting controller SystemController#reactor_system
    [latest-21336]2021-12-03T17:29:05.462Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
    [latest-21336]2021-12-03T17:29:05.487Z <app:INFO> Structure running; pausing for controllers' initial ready
    [latest-21336]2021-12-03T17:29:05.517Z <HubitatController:NOTICE> HubitatController#hubitat not ready; performing initial connect/query
    [latest-21336]2021-12-03T17:29:05.534Z <HassController:NOTICE> HassController#hass connected, starting protocol
    [latest-21336]2021-12-03T17:29:05.540Z <HassController:INFO> HassController#hass successful authentication with ws://192.168.1.21:8123; fetching initial data...
    [latest-21336]2021-12-03T17:29:05.544Z <HassController:INFO> HassController#hass Hass reports version "2021.11.5" location Home timezone America/Chicago state RUNNING safe_mode false
    [latest-21336]2021-12-03T17:29:05.632Z <HassController:NOTICE> Controller HassController#hass is now online.
    [latest-21336]2021-12-03T17:29:05.799Z <Entity:ERR> Entity#hubitat>568 attempt to set primary to x_hubitat_extra_attributes.Status invalid: capability not extended
    [latest-21336]2021-12-03T17:29:05.800Z <HubitatController:WARN> HubitatController#hubitat can't set local primary attribute x_hubitat_extra_attributes.Status on Entity#hubitat>568: Error: Invalid primary attribute assignment; capability not assigned (x_hubitat_extra_attributes.Status)
    [latest-21336]2021-12-03T17:29:05.817Z <Entity:ERR> Entity#hubitat>481 attempt to set primary to x_hubitat_extra_attributes.dbSize invalid: capability not extended
    [latest-21336]2021-12-03T17:29:05.818Z <HubitatController:WARN> HubitatController#hubitat can't set local primary attribute x_hubitat_extra_attributes.dbSize on Entity#hubitat>481: Error: Invalid primary attribute assignment; capability not assigned (x_hubitat_extra_attributes.dbSize)
    [latest-21336]2021-12-03T17:29:05.825Z <HubitatController:INFO> HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.1.70/eventsocket
    [latest-21336]2021-12-03T17:29:05.842Z <HubitatController:INFO> HubitatController#hubitat successful connection to ws://192.168.1.70/eventsocket
    [latest-21336]2021-12-03T17:29:05.856Z <HubitatController:NOTICE> HubitatController#hubitat current mode is Day (1)
    [latest-21336]2021-12-03T17:29:05.859Z <HubitatController:NOTICE> Controller HubitatController#hubitat is now online.
    [latest-21336]2021-12-03T17:29:06.088Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
    [latest-21336]2021-12-03T17:29:06.089Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
    [latest-21336]2021-12-03T17:29:06.090Z <app:NOTICE> Starting HTTP server and API...
      Thanks for reporting. Good info/post content. A little tension between trying to make data more deterministic and trying to keep it flexible; always an uphill battle. Just doing a little more testing. New build shortly.
        Build 21337 fixed the issue. Thanks!
        I do not know how to mark the post Solved.
          Good news.
          Just edit the title (by editing your original post) and put [SOLVED] in front.
          S 1 Reply Last reply
            Good news.
            @toggledbits said in Hubitat type guessing and extra attributes v21336-Synology Docker:
            Smh, I thought about that but thought there must be a way to mark it. I tend to make things more complicated than it need to me. Thanks
            • S SweetGenius
              @sweetgenius I'm not sure there is in this forum software, but I'm no expert at it. Paging @DesT -- is there a way to mark an issue solved other than editing the title?
              DesTD 1 Reply Last reply
                DesTD Offline
                DesTD Offline
                DesT
                @toggledbits Let me check in the plugin 😉
                  130.9k
