  3. openLuup : Kiosk (Touchscreen) Idea ?
openLuup email server
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup: Version Log
openLuup
ZWaveJS and MQTT
openLuup
Awesome MQTT - GitHub list
openLuup
openLuup
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
openLuup
openLuup
openLuup and room names
openLuup
openLuup
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
openLuup
openLuup
AltUI access over VPN
openLuup
openLuup
OpenLuup installation
openLuup
Unexpected stop of openLuup
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
openLuup
12 Posts 3 Posters 2.1k Views 3 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    I have an old raspberry pi and 7" touchscreen gathering dust, and have started to explore how I could potentially use the openLuup feature to ‘specify my own’ index.html?
    The openLuup manual suggests it’s straightforward to set up, the challenge is going to be around how best to create a single html for just one of my plugins so i can use it in a kiosk type mode..
    As you can probably tell, html and web development are alien to me 🙂 - but I assume I can do something basic, like create buttons that just call luup.call_action - e.g. here’s one from a plugin I created.
    Luup
    luup.call_action("urn:nodecentral-net:serviceId:Matrix1","SYCall",{ action ="I3" },1083)
    Html
    <form action="https://google.com">
        <input type="submit" value="Go to Google" />
    </form>
    Not sure how that luup.call_action translate to a url, but I guess it’s something like this..
    http://ip_address:3480/data_request?id=action&output_format=xml&DeviceNum=1083&serviceId=urn:nodecentral-net:serviceId:SYMatrix1&SYCall={action=I3}
    Has anyone done anything like this already, and has any examples of their own html content they can share ?
    Is there maybe something out there that can translates any Vera static .json file into something presentable on a .html page. ? I had a quick look through @amg0 AltUi content on GitHub for inspiration but that is a way more comprehensive interface, compared to the single screen look I’m going for..
    Any suggestion/advice (examples ideally) would be much appreciated..
    • parkercP parkerc
      Luup
      Html
      </form>
      I'm doing something like that, but my dashboard is based on C#. It's effectively running inside a Fire Tablet with Fully Kiosk and it's a web app. I've posted screenshots before, but here we go again:
      (sorry, it's in Italian, but you'll get the point thanks to the icons - if you see lower temperature don't worry, we're fine, it's just the wife changing air - a typical Italian habit :D).
      It's effectively calling Vera's endpoint, beside a couple of things calling my own stuff (via HTTP calls).
      I had to re-create every widget I wanted to support, and it's pretty tied to my needs, but it's working good for us. Wife is happy and it's not easy. I'll probably add a new scene for the morning, to show a different view with weather and appointments later this year. Everything is updated in real-time via WebSockets. Fully Kioks has the ability to trigger external apps, so I'm launching the cams when a motion is detected. Screen is always on, but it's managed to dim to 0 automatically and turn on based on motion and/or an event (like doorbel, motion detected, doors opened, etc).
      If you want something ready to use, MSR has a dashboard capability you could try.
        Yes, I've used openLuup in this way, although nowadays my go-to dashboard is Grafana (which can have arbitrary HTML links too.)
        Your HTTP action call syntax is not quite right – the parameters are not enclosed within braces – see:
        http://wiki.micasaverde.com/index.php/Luup_Requests#action
        • parkercP Offline
          parkercP Offline
          parkerc
          Thanks all,
          I’ve decided to use the Vera Smartphone UI plugin code as my guide - > https://apps.mios.com/plugin.php?id=6 .
          This seems to be a reasonably straight forward approach as it’s Lua based and leverages the luup.register_handler route .. Although admittedly it’s a little dated, and a trip down memory lane for those old Vera 2 users (before UI5) , but it seems a very viable option for my OpenLuup Kiosk idea.
          Has anyone worked with this phone UI code before ?
          • parkercP Offline
            parkercP Offline
            parkerc
            After a little bit of tweaking and a whole lot of luck, I’ve managed to repurpose aspects of the Vers Smartphone UI to give me a basic kiosk page for my new HDMI Matrix plugin..
            I’m currently running it on my Vera, and have been installing it via the startup Lua, so I can make constant tweaks.
            My limited of knowledge in all the parts at play and the coding languages involved, means I’m fumbling around quite a bit with this - but I’m pleased with the progress so far 🙂
            • parkercP Offline
              parkercP Offline
              parkerc
              For those that are interest, here’s the code I have at the moment..
              Next steps are (1) to try this on openLuup , (2) to see where I can streamline the code, as it there seems more than I probably need and (3) look at linking to content elsewhere rather than mios.com..
              sPh_LAYOUT_PFX = 'https://download1.mios.com/L_sPhoneUI_layout'
              g_is_remote = 0
              	function string:template(variables)
              		return (self:gsub('{%%(.-)%%}', function (key) return tostring(variables[key] or _G[key] or '') end))
              	function flag(v)
              		if( v==nil or tonumber(v)==0 ) then
              			return '0'
              		return '1'
              luup.register_handler("lug_sKioskRequest","sKiosk")
              luup.register_handler("lug_sPhoneRequest_action_js","sPhone_action_js")
              -- http://192.168.102.10:3480/data_request?id=lr_sKiosk
              local html_header = ([[
              <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
              <html xmlns="http://www.w3.org/1999/xhtml">
              	<head>
              		<title>Vera Mobile</title>
              		<meta http-equiv="pragma" content="nocache"/>
              		<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
              		<meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0;"/>
              		<script src="{%sPh_LAYOUT_PFX%}/js/mobile.js" language="javascript"></script>
              		<link rel="stylesheet" href="{%sPh_LAYOUT_PFX%}/css/iui.css" type="text/css" />
              	</head>
              	<body onLoad="js_prepare_urls();set_layout_prefix('{%sPh_LAYOUT_PFX%}');">
              ]]):template ({})
              	local html_footer=[[
              	</body>
              	</html>]]
              function list_devices (lul_room, out, lul_js)
              		local grouphead_inserted = false
              		for k,v in pairs(luup.devices) do
              			if( v.room_num==tonumber(lul_room) and v.hidden==false and v.invisible==false ) then
              				if not grouphead_inserted then
              					table.insert (out,'<li class="group">Devices</li>\n')
              					grouphead_inserted = true;
              				if v.category_num==0 then
              				table.insert (out, '<li class="bg">' .. lug_sPhoneRequest_switch(k,v.description,lul_js) .. "</li>\n")
              function lug_sPhoneRequest_switch(lul_device,lul_description,lul_js)
              		local lul_Status = luup.variable_get("urn:nodecentral-net:serviceId:SYMatrix1","Input",lul_device)
              		local tmpl_params = {
              			device = lul_device,
              			description = lul_description,
              			room = luup.devices[tonumber(lul_device)].room_num,
              			time = os.clock(),
              			status_0 = lul_Status=="1" and '_h' or '',
              			status_25 = lul_Status=="2" and '_h' or '',
              			status_50 = lul_Status=="3" and '_h' or '',
              			status_100 = lul_Status=="4" and '_h' or '',
              		if( lul_js=='1' ) then
              			return ([[
              				<img src="{%sPh_LAYOUT_PFX%}/icons/switch.gif" alt="" width="44" height="43" align="absmiddle" class="icon" id="pic_device_{%device%}" />{%description%}<br>
              				<img src="{%sPh_LAYOUT_PFX%}/images/spacer.gif" border="0" width="20" height="20" id="action_icon_{%lul_device%}">
              				<a href="javascript:void(0);" onClick="set_device_icon({%device%},1);send_command('data_request?id=lr_sPhone_action_js&room={%room%}&device={%device%}&service=urn:nodecentral-net:serviceId:SYMatrix1&action=SYCall&SetInput=I1&time={%time%}',{%device%})"><img src="{%sPh_LAYOUT_PFX%}/buttons/on{%status_0%}.gif" alt="" border="0"/></a>
              				<a href="javascript:void(0);" onClick="set_device_icon({%device%},1);send_command('data_request?id=lr_sPhone_action_js&room={%room%}&device={%device%}&service=urn:nodecentral-net:serviceId:SYMatrix1&action=SYCall&SetInput=I2&time={%time%}',{%device%})"><img src="{%sPh_LAYOUT_PFX%}/buttons/on{%status_25%}.gif" alt="" border="0"/></a>
              				<a href="javascript:void(0);" onClick="set_device_icon({%device%},1);send_command('data_request?id=lr_sPhone_action_js&room={%room%}&device={%device%}&service=urn:nodecentral-net:serviceId:SYMatrix1&action=SYCall&SetInput=I3&time={%time%}',{%device%})"><img src="{%sPh_LAYOUT_PFX%}/buttons/on{%status_50%}.gif" alt="" border="0"/></a>
              				<a href="javascript:void(0);" onClick="set_device_icon({%device%},1);send_command('data_request?id=lr_sPhone_action_js&room={%room%}&device={%device%}&service=urn:nodecentral-net:serviceId:SYMatrix1&action=SYCall&SetInput=I4&time={%time%}',{%device%})"><img src="{%sPh_LAYOUT_PFX%}/buttons/on{%status_100%}.gif" alt="" border="0"/></a>
              			]]):template (tmpl_params)
              		else
              			return ([[
              				<img src="{%sPh_LAYOUT_PFX%}/icons/switch.gif" alt="" width="44" height="43" align="absmiddle" class="icon" />{%description%}<br>
              				<a href="data_request?id=lr_sPhone_action&room={%room%}&device={%device%}&service=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=0&time={%time%}"><img src="{%sPh_LAYOUT_PFX%}/buttons/on{%status_0%}.gif" alt="" border="0"/></a>
              				<a href="data_request?id=lr_sPhone_action&room={%room%}&device={%device%}&service=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1&time={%time%}"><img src="{%sPh_LAYOUT_PFX%}/buttons/on{%status_25%}.gif" alt="" border="0"/></a>
              				<a href="data_request?id=lr_sPhone_action&room={%room%}&device={%device%}&service=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=0&time={%time%}"><img src="{%sPh_LAYOUT_PFX%}/buttons/on{%status_50%}.gif" alt="" border="0"/></a>
              				<a href="data_request?id=lr_sPhone_action&room={%room%}&device={%device%}&service=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1&time={%time%}"><img src="{%sPh_LAYOUT_PFX%}/buttons/on{%status_100%}.gif" alt="" border="0"/></a>
              function lug_sKioskRequest(lul_request,lul_parameters,lul_outputformat)
              		local lul_js = flag(lul_parameters.js)
              		g_is_remote = flag (lul_parameters.r)
              -- 		if( lul_js==nil or tonumber(lul_js)==0 ) then
              -- 			lul_js = 0
              -- 		end
              		luup.log("lul_js = " .. lul_js)
              		local out = {html_header, [[
              		<div id="toolbar" class="toolbar"><!--logout_btn--></div>
              		<ul id="searches" title="MyHome" selected="true">
              		local time = os.clock()
              		list_devices (0, out, lul_js)
              		table.insert (out, '</ul>')
              		table.insert (out, html_footer)
              		return table.concat (out),"text/html"
              function lug_sPhoneRequest_action_js(lul_request,lul_parameters,lul_outputformat)
              		local lul_room = lul_parameters.room
              		local lul_device = lul_parameters.device
              		local lul_action = lul_parameters.action
              		local lul_service = lul_parameters.service
              		if( lul_device==nil or lul_action==nil or lul_service==nil ) then
              			luup.log("lug_sPhoneRequest_action: missing arguments")
              			return 'ERROR: Missing arguments'
              		local lul_arguments = {}
              		for k,v in pairs(lul_parameters) do
              			if( k~="device" and k~="action" and k~="service" and k~="room" and k~="time" ) then
              				lul_arguments[k]=v
              			luup.log("lug_sPhoneRequest_action: " .. tostring(k) .. "=" .. v)
              		for k,v in pairs(lul_arguments ) do
              			luup.log("lug_sPhoneRequest_action: argument " .. tostring(k) .. "=" .. v)
              	luup.log("luup.call_action(" ..lul_service..","..lul_action..","..lul_arguments..","..tonumber(lul_device)")")
              		local lul_resultcode,lul_resultstring,lul_job,lul_returnarguments = luup.call_action(lul_service,lul_action,lul_arguments,tonumber(lul_device))
              		luup.log("lug_sPhoneRequest_action: device: " .. tostring(lul_device) .. " action: " .. tostring(lul_action) .. " service: " .. tostring(lul_service)  .. " returned: " .. tostring(lul_resultcode) .. " str " ..tostring(lul_resultstring) .. " job " .. tostring(lul_job))
              		if( lul_resultcode~=0 ) then
              			return 'ERROR: ' .. tostring(lul_resultcode) .. ': ' .. tostring(lul_resultstring)
              		luup.log("lul_resultcode: " .. lul_resultcode)
              		luup.log("lul_resultstring: " .. lul_resultstring)
              		if( lul_job==0 ) then
              			return 'OK'
              		return 'Running: ' .. lul_job .. '|' .. lul_device
              • parkercP Offline
                parkercP Offline
                parkerc
                Hi @akbooer
                I’ve just got the Pi set up with openLuup installed and run the script above via the Misc / Lua code test option but when I go to the address http://10.10.10.72:3480/data_request?id=lr_sKiosk it gives me the follow error.
                No handler for data_request?id=lr_sKiosk
                I also tried pasting it into the start up Lua and restarted it, but I got the same message again..
                As always, any ideas/suggestions appreciated
                  I haven't looked through the code, but I know that defining a handler works from the openLuup Lua Test page works just fine:
                  function FOO()
                    return "Hello"
                  luup.register_handler ("FOO","FOO")
                  then calling with openLuupIP:3480/data_request?id=lr_FOO yields the expected output "Hello".
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    Thanks @akbooer , ok, the issue seems to be where I declare the luup.register_handler…
                    The smartphone UI code has it near the very top, which seems to work fine when it’s run on my Vera, but openLuup doesn’t like it like that.. , However if I move the handle(s) to the very end it works.. 🙂
                      Yes, that’s true. I understand why that’s the case. It is a difference between Vera and openLuup, but it does work either way in plugins, so they work on both systems.
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        Thanks, and I seem to have a working (single plugin kiosk) UI now 😉
                        FYI - I’ve also managed to embed the .js and .css into the luup.handler HTML creation script, thus reducing the external MIOS dependencies. (I still need to explore alternative hosting for button/images etc.)
                        Now admittedly it’s not the most sophisticated of UI, or the prettiest of Lua scripts, but it’s functional, and it means I have a dedicated UI for my plugin 🥳🥳🥳🥳🥳!
                        @akbooer - What are your thoughts on making this a ‘feature’ of openLuup? Not sure how, just thinking out-loud ? If it helps, I’ve created my script within a K_xxxxxx.lua file to help identify it, maybe that could be a thing for others to follow too?
                          Glad you have it working to your satisfaction.
                          I'm not quite sure what you're suggesting as an openLuup feature, but as you've found, all the tools are there and it's not hard. Not sure how much use it might get since there are so many difference options for this sort of thing.
                          • parkercP parkerc referenced this topic on
                            228
                            3.6k
                            3.2k
                            757
