  4. [SOLVED] Modes race condition upon docker restart returns
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
5 Posts 3 Posters 659 Views 3 Watching
  • 3 Offline
    3 Offline
    Hi @toggledbits. It appears that the race condition from this post has returned. Or maybe it's a sibling race condition?
    MSR latest-21360-315df22 in docker on unRAID server for Hubitat C7 running 2.30.0.121
    EDIT: I may see the cause of the issue- More below in my EDIT section. And please let me know if this is TOO much information and screenshots. Trying to make it easier for you. Thx.
    I have a contact sensor report over my Echo devices when it is opened/closed, but only when the Hubitat is in it's Home state. Every once in a while this contact sensor get's stuck in the open state, as it is right now. A quick open and close resets the state, but that's a different issue.
    The issue, similar to the last race condition, upon my docker restart, the Reset Reaction is announced followed by the Set Reaction. If I remove the Mode entity and restart the docker, no announcements are made.
    Copy of the rule prior to docker restart (Copied to only notify on one Echo vs spam the family.)
    Docker restarted - SET times changed.
    Removed Mode entity and restarted Docker - Contact sensor and SET times remained.
    Added Mode back in and restarted again. SET time and Home True value are set to the same time.
    EDIT: I was grabbing my entire rule to show the work. No Constraints, No Local Expressions. Upon doing this, I noticed that the Mode entity has a Null value. I checked another one of my rules that uses my Mode state and that rule is also Null. As if this value is not being stored. The overview/summary page shows the value as Home, but when I edit the rule, it shows Null.
    A completely different rule, not touched, yet. Showing the null value differences.
    3 1 Reply Last reply
    • 3 3rdStng
      3 Offline
      3 Offline
      If I restart my Hubitat controller, the Entity value when editing the rule will show the current value. But if I restart my docker, it will then show a null value.
      Value after HE hub reboot but before docker restart
      wmarcolinW 1 Reply Last reply
      • 3 Offline
        3 Offline
        @toggledbits posted a new blind docker build 21362 which has resolved the Mode issue. He wasn't able to test this build, but I wanted to get this update on here in case others come across it. I will mark this as SOLVED for now, even though this build was not tested by him.
        • 3 3rdStng
          @3rdstng
          Allow me my two cents, in the third situation when you return to the Hubitat mode evaluation, it is written home with the "h" in lowercase, and remember that this is a case sensitive comparison that is valid, i.e., see that in the Currente Value status the Home is with the H in uppercase, that would make your rule unfeasible.
            He's got a case-insensitive test going; it'll be fine. The problem arises mostly when you send a new mode to Hubitat... that's where you need to be careful and get the case correct.
              2.0k
              3.8k
              3.3k
