  3. An electricians or wiring experts here?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
9 Posts 5 Posters 1.3k Views 4 Watching
    I ordered a Fibaro Dimmer 2 and Bypass device for my upstairs landing / hallway lights.
    I have 2 light switches one at the bottom of the stairs and another one upstairs on the landing.
    But I am struggling to make sense of my current wiring, more details / photos on the Vera forum.
    Jan 27, 2022
    Anyone good at electrical wiring for light switches?
    Hi I ordered a Fibaro Dimmer 2 and Bypass device for my upstairs landing / hallway lights. I have 2 light switches one at the bottom of the stairs and another one upstairs on the landing. I have no neutral wires in the house behind the light switches. This is UK wiring in a 70s house. These...
      Jan 27, 2022
      ArcherS
      In Sweden the most usual connection in that situation is a "stairway connection". It typically is done like this:
      Maybe what you have is something like this connection?
        Not sure at all can't work out my wiring. Best I can tell so far its something like this. but I can't see or tell where some wires go to / come from.
          ArcherS
          @cw-kid it is really difficult to say. I think your drawing looks quite similar to the one I posted, but not quite sure, it could be different. The earthing in the pattress box is unfamiliar with me, the boxes here are in plastic. But I assume it is simply an earth to the box since it is made of metal.
          The colours are always tricky in old houses. They can have changed, different standards over time etc. Not to be trusted in other words. The only way to know is really to try understand what they all are and where they all go.
          You may need to disconnect the cables on the two switches to fully map things out. Marking the original position of all cables, cutting the power while working etc. 🙂
          I do not have any Dimmer 2, but will it not need neutral to operate? This means that you would need to get neutral to behind one of the light switches.
          Another solution could be to put the Fibaro at the light instead, if it fits safely there and is allowed in your location. That could perhaps be a solution not having to get new cables drawn into the boxes.
          Regarding your switches momentary should work or are even needed for being able to dim the light.
          I found a sketch showing one way to connect two momentary switches to a Fibaro Dimmer (the older version I think since it says "O" for the connnection that goes to the light). Maybe it could be of use.
          As always continue with care and cross-check with the Fibaro diagram, they could have changed something in the new version.
          Basically if I understand the sketch correctly the two switches need to be connected in parallel over S1 and SX.
          Not sure I can help more, good luck! 🙂
            Thanks, I think my diagram isn't right at all as it doesn't make much sense. I think I will try and bell out all the wires for continuity to try and work out what is what. You can wire in Fibaro Dimmer 2 modules with no neutral behind the wall switches. All my other ceiling lights don't have neutral wire either behind their wall switches and work fine with the Dimmer 2 modules. Placing the Dimmer 2 in the ceiling above the actual light might be the way to go as you suggested.
              Paging @Elcid, since he is a licensed electrician in UK and may help.
                wrote on last edited by Elcid
                Hey @cw-kid can i see photos of all your switches and the light fitting so i can establish the wiring method and where you can put the dimmer.
                Are you going to change the switches to momentary?
                I have seen your photos on old forum but they are unclear. The red wire going to earthing position seems odd. Is it just a red sleeve on a bare earth wire or is it a a spare wire they just earthed for safety.
                When you take more photos can you get a clear shot of the cables leaving the box an a clear shot of back of switches showing the markings on switch.
                A safety note , you are using metal switches, so there should be an earth fly lead from the earth on box to the switch. removing the switch from the box now means the metal on the switch is not earthed.
                  I have to say that using push switches makes multi-way wiring SO much easier, since you can do this with just two wires and all the switches in parallel.
                    @akbooer I agree. My new house has them everywhere and it’s useful to use them as scene controllers as well (long press to dim, double click
                    to sync levels, etc)
                    • Oh the joy of pairing
                    • HDMI oddness
                      668
                      sethlampman
                    • Date/time condition
