  4. Hubitat "hubitat" is reconnecting alert
6 Posts 3 Posters 1.5k Views 3 Watching
  • Tom_DT Offline
    Tom_DT Offline
    Tom_D
    I have been seeing this alert for a while and wondering what I should do about it.
    Hubitat "hubitat" is reconnecting because the events feed seems to have become unresponsive.
    Last 8:47:56 PM; this alert has repeated 131 times.
    latest-25082-3c348de6
      Alan_F
      If you haven't already done so, the docs suggest this:
      Install the Hub Information driver
      It is highly recommended that you install and configure (create a device using) the Hub Information driver on your hub. This driver is available through Hubitat Package Manager and from Github. The device must also be published by Maker API.
      3 1 Reply Last reply
      • Tom_DT Offline
        Tom_DT Offline
        Tom_D
        I started on this several weeks ago, had trouble, got distracted and then didn't get back to it.
        Returned to the process today and got it figured out and installed.
        • A Alan_F
          3 Offline
          3 Offline
          @alan_f said in Hubitat "hubitat" is reconnecting alert:
          I too was seeing this message, especially after a reboot, and was curious about it as well. It appeared to happen more often a few builds ago, but has stopped now. I had Hub Info installed, but recently removed it as I wasn't really using it much anymore. However I couldn't find anything in the MSR docs about this though. Maybe I missed it?
          But what I did find was how I could include a username: and password: in the config: section of the reactor.yaml file to help with this. But when I put these in under the config section, I started getting errors about invalid formatting in the yaml file and my docker wouldn't start anymore. Did I format things wrong? Is my username and password needed if I have Hub Info reinstalled and published via the Marker API?
                source: "http://[IPADDRESS]/apps/api/4/devices?access_token=TOKEN-KEY"
                dump_all_devices: false
                username: thatsme
                password: itssecret
            - id: weather
              enabled: false
          • 3 3rdStng
                  username: thatsme
                  password: itssecret
              - id: weather
                enabled: false
            Alan_F
            @3rdstng That doesn't look right at all. YAML needs all the indentations to be correct, and yours don't match up to the docs which show this:
            - id: hubitat
              enabled: true
              implementation: HubtitatController
                source: "http://192.168.0.3/apps/api/166/devices?access_token=4b840f3e-0000-4c1d-0000-357242c2d272"
            I'm assuming you have the
            - id: hubitat
              enabled: true
              implementation: HubitatController
            above what you quoted. If so, what comes after that should look something like:
                username: thatsme
                password: itssecret
            - id: weather
              enabled: false
            Name needs to be indented two spaces. Everything below needs to be backed up by two spaces so 'config' lines up with 'name' and everything below 'config' lines up with the 'n' in 'config' (I think... I'm a yaml newbie). It also looks like your "- id: weather" is indented more than it should be.
            (Disclaimer: I looked at the docs, but I'm not looking at my own config file right now, so this advice may be worth slightly less than you paid for it)
            • 3 Offline
              3 Offline
              Sorry. I didn't include the very top of my Hubitat section. It does have the id: stuff. I think I was missing the two spaces. I went back and edited the yaml more and made sure those additional spaces were there. Then restarted the docker and everything worked just fine.
                136.9k
