  4. Hubitat "hubitat" is reconnecting alert
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
6 Posts 3 Posters 1.1k Views 3 Watching
  • Tom_DT Offline
    Tom_DT Offline
    Tom_D
    I have been seeing this alert for a while and wondering what I should do about it.
    Hubitat "hubitat" is reconnecting because the events feed seems to have become unresponsive.
    Last 8:47:56 PM; this alert has repeated 131 times.
    latest-25082-3c348de6
      Alan_F
      If you haven't already done so, the docs suggest this:
      Install the Hub Information driver
      It is highly recommended that you install and configure (create a device using) the Hub Information driver on your hub. This driver is available through Hubitat Package Manager and from Github. The device must also be published by Maker API.
      3 1 Reply Last reply
      • Tom_DT Offline
        Tom_DT Offline
        Tom_D
        I started on this several weeks ago, had trouble, got distracted and then didn't get back to it.
        Returned to the process today and got it figured out and installed.
        • A Alan_F
          3 Offline
          3 Offline
          @alan_f said in Hubitat "hubitat" is reconnecting alert:
          I too was seeing this message, especially after a reboot, and was curious about it as well. It appeared to happen more often a few builds ago, but has stopped now. I had Hub Info installed, but recently removed it as I wasn't really using it much anymore. However I couldn't find anything in the MSR docs about this though. Maybe I missed it?
          But what I did find was how I could include a username: and password: in the config: section of the reactor.yaml file to help with this. But when I put these in under the config section, I started getting errors about invalid formatting in the yaml file and my docker wouldn't start anymore. Did I format things wrong? Is my username and password needed if I have Hub Info reinstalled and published via the Marker API?
                source: "http://[IPADDRESS]/apps/api/4/devices?access_token=TOKEN-KEY"
                dump_all_devices: false
                username: thatsme
                password: itssecret
            - id: weather
              enabled: false
          • 3 3rdStng
                  username: thatsme
                  password: itssecret
              - id: weather
                enabled: false
            Alan_F
            @3rdstng That doesn't look right at all. YAML needs all the indentations to be correct, and yours don't match up to the docs which show this:
            - id: hubitat
              enabled: true
              implementation: HubtitatController
                source: "http://192.168.0.3/apps/api/166/devices?access_token=4b840f3e-0000-4c1d-0000-357242c2d272"
            I'm assuming you have the
            - id: hubitat
              enabled: true
              implementation: HubitatController
            above what you quoted. If so, what comes after that should look something like:
                username: thatsme
                password: itssecret
            - id: weather
              enabled: false
            Name needs to be indented two spaces. Everything below needs to be backed up by two spaces so 'config' lines up with 'name' and everything below 'config' lines up with the 'n' in 'config' (I think... I'm a yaml newbie). It also looks like your "- id: weather" is indented more than it should be.
            (Disclaimer: I looked at the docs, but I'm not looking at my own config file right now, so this advice may be worth slightly less than you paid for it)
            • 3 Offline
              3 Offline
              Sorry. I didn't include the very top of my Hubitat section. It does have the id: stuff. I think I was missing the two spaces. I went back and edited the yaml more and made sure those additional spaces were there. Then restarted the docker and everything worked just fine.
                690
                3.6k
                3.2k
                798
