  3. Seeking experts for implementing Modbus TCP
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
9 Posts 5 Posters 4.3k Views 5 Watching
  • CrilleC Online
    CrilleC Online
    I just upgraded the firmware for the inverter for my solar panels and that made it possible to enable Modbus TCP.
    At a glance that would be perfect for live production data fed into my home automation environment but my lack of knowledge about the protocol and how to put the data where I want it failed me.
    What I have:
    MSR
    openLuup
    Vera Secure
    Ezlo Plus
    Mosquitto
    Homebridge
    Windows Server
    Ubuntu Server
    Quite decent PowerShell skills
    Enough Lua knowledge to write my own functions and handlers
    The inverters Modbus interface definitions
    What I want to achive:
    Something that can be run by systemd och anything else monitoring the status and keeping the Modbus connection alive.
    Publish readings over MQTT or whatever fits my setup, the goal is to feed the data into openLuup in someway so Historian can log the data for Grafana and display current production to HomeKit (as a mqttthing light sensor, since there is no other accessory suitable at the moment).
    Anyone implemented Modbus TCP in similar projects or have any guidance on how to reach my goal?
    Open for alternative solutions as well, all suggestions are appreciated!
    • B Offline
      B Offline
      benni33
      wrote on last edited by benni33
      I was just browsing here and than saw your post. Just for the sake of answering I registered 😄
      At first we need some more infos about your inverter.
      You can ask the manufacturer about modbus details. (already done)
      Than this project might be exactly what you you are looking for:
      GitHub - bohdan-s/SunGather
      Contribute to bohdan-s/SunGather development by creating an account on GitHub.
      • Black CatB Offline
        Black CatB Offline
        Black Cat
        If you are looking for modbus integration then you might look at HomeSeer which has a Modbus plug in and supports MQTT
        There is an existing thread about Solar Edge which mentions that they (Solar Edge) do not expose panel information but you might want to follow this up.
        https://forums.homeseer.com/forum/energy-management-plug-ins/energy-management-discussion/solaredge-stefxx
        aka Zedrally
          sender
          Modbus Controller
          Modbus Controller
          Instructions for setting up the Modbus Controller component.
            What I have:
            MSR
            openLuup
            Vera Secure
            Ezlo Plus
            Mosquitto
            Homebridge
            Windows Server
            Ubuntu Server
            I have a Huawei inverter, so modbus support is hacky and I went the Shelly route. I have a Smelly EM feeding data in real time into MQTT - then to MSR and Home Assistant. I don't need fancy stats about my solar, just the production, in order to maximize self-consumption.
            The graphs are a nice bonus that you'd create, using native HASS solar prediction as well.
            All that said, HASS has a native support for many solar inverters, take a look, since long term it's probably easy to use them than maintain your own integration.
            • CrilleC Online
              CrilleC Online
              Thank you all for your ideas!
              @benni33 The inverter is a Huawei SUN2000-12KTL-M0 with a SDongleA-05 enabled for Modbus TCP. I'm guessing SunGather is for Sungrow inverters only but I gave it a shot in a docker with edited config.yaml but all I get is "Modbus connection failed".
              @Black-Cat I'm trying to avoid paid services but will investigate this further.
              @sender Modbus Controller looks like it needs physical RS 485 Modbus connection and not compatible with Modbus TCP?
              @therealdb That's an approach I could use as an alternative.
              I got this sort of working. It connects to the inverter and reads data but publishes only twice to the broker, then nothing. Going to fiddle with it more to see whats going on...
              HASS has been on my mind just doing my best to not involve even more systems than I already have.
              therealdbT S 2 Replies Last reply
                @crille said in Seeking experts for implementing Modbus TCP:
                I have the same inverter and it has been a pain. Recently, Huawei has stopped modbus TCP to be enabled by default and changed its port. It's not documented and the chances they'll do it again are high. Anyway, if you're OK with MSR, Shelly EM are easily supported. I don't have a battery, since I could sell my excess to the grid (but I've built a couple of automations to use it - we'll see this summer, where the excess will be way higher, since I have bifacial panels) and I don't have microinverters, since panels are facing south and in plain sight.
                HASS has a nice UI for the energy part - and my wife loves it. I'm also storing the data into InfluxDB (via MSR) and I've built a couple of notifications aggregating data.
                  sender
                  @crille did no know you specifically needed modbus tcp. But that natively in homeassistant
                  Modbus
                  Modbus
                  Instructions on how to integrate modbus and platforms.
                  • CrilleC Online
                    CrilleC Online
                    OK, after trying a few solutions a finally ended up with Home Assistant as a Hyper-V guest on my Windows server.
                    First I evaluated this by Emilv2 but it did not fit my needs and wasn't very stable.
                    The best option by far was this for Huawei inverters, I even tweaked the polling frequency down to 10s to have "realtime" data matching my ESP8266 hooked up to my electricity meter sending data every 10s.
                    Unfortunately HASS was not able to connect to openLuup broker so I enabled the HASS controller for MSR and echo the newly created sensors to openLuup.
                    I then wrote a MQTT handler for openLuup to set appropriate variables and do some math comparing electricity use and production and edited Historian to keep those for Grafana.
                    Been running it for almost 2 days now without any issues.
                    Some of the HASS sensors:
                    openLuup variables:
                    Grafana: (sorry for Swedish)
                    This was a fun project and thanks for pointing me in the right direction!
                    • CrilleC Crille has marked this topic as solved on
                      155.6k
