Home Assistant up to version 2021.8.6 supported; the online version of the manual will now state the current supported versions; Fix an error in OWMWeatherController that could cause it to stop updating; Unify the approach to entity filtering on all hub interface classes (controllers); this works for device entities only; it may be extended to other entities later; Improve error detail in messages for EzloController during auth phase; Add isRuleSet() and isRuleEnabled() functions to expressions extensions; Implement set action for lock and passage capabilities (makes them more easily scriptable in some cases); Fix a place in the UI where 24-hour time was not being displayed.That's probably more appropriate to post on Mantis for @toggledbits, but since I know there's at least @Crille publishing templates, my intent with this post is to open a broader discussion.
ZWaveJSController 0.1.23254
Home Assistant:
Core 2024.2.5 Supervisor 2024.02.1 Operating System 12.0Who are my Home Assistant + ZWave-JS users?
I will have my first update to post later today with some fixes and a lot of new device support (thanks to those of you running so far -- lots of data, good stuff!).
@toggledbits Since we are at the beginning of this, should we put a header like "ZWAVE-JS" at the begining of the title for every new post related to Zwave-JS just to flag the topic? Or do we keep on going into this thread for all issues, questions, etc...?
How would you like us to proceed?
Build 22049 for zwavejs now posted. Some bug fixes, and a lot of device mapping.
Hello, i'm running zwavejs2mqtt addon on Home Assistant and the addon don't allow to connect to the addon via IP address. Is there a solution for this or i'm out of luck?
I'm running my Reactor on a docker on Unraid, and home assistant os as a VM on the unraid, i can't install docker zwavejs2mqtt because for some unknown reason my zwave stick loses a connection with the docker after couple of days and cant find the solution for that.
cheers
@toggledbits why not answer my question? Do I need msr? What's in it (extra) for me?
@sender If you're happy with whatever you are using for automations, you may not need Reactor. If you're struggling with Node-Red or find HA's native automations too limiting or clunky, then Reactor may be an alternative you find agreeable.
Build 22050:
- Continued improvements in attribute mapping for devices (locks are entirely new in this release).
- Z-Wave device polling see docs
Build 22051:
- Fix node/entity-specific interval on polling
- More device updates and action enhancements
Build 22052:
- Fix startup synchronization issue causing problems for polling when connection reset/restarts.
Hello, i managed to connect the HA add on to reactor. The first thing i noticed is that mappings for fan on ZXT-600 and ZXT-120 IR extender for AC are incorrect, on reactor are as follows: 0-off, 1 - auto, 2 - continuous, 3 - periodic, 4 - low, 5 - medium, 6 - high, in zwavejs web console are 0 - Auto low, 1- Low, 3 - High, 5 - Medium
@eonnet said in Who are my Home Assistant + ZWave-JS users?:
As I mentionned earlier in this thread, I also had issues with the zwavejs2mqtt HA addon. The only option I found was to remove the addon and install it stand alone but still in Docker.
I am just curious to know your setup and how you manage to make it work still using the HA addon.
Expect LOTS of device mappings to be off, or very generic. Not all devices follow the Z-Wave spec recommendations, particularly legacy Z-Wave devices, and even some first-generation Plus devices. I imagine this is why the Gen 2 specs are a good bit tighter. Regardless, every oddity and exception has to be handled as what it is, which is why I collect data from the interface. I literally sit and spend hours picking through your devices. On every new release, check those devices that previously didn't seem right. If, after a release or two, things still look or behave oddly, do let me know (specific data, please; if you say "X doesn't work" and nothing else, I will ignore it).
Reactor has its own set of values for its capabilities. These are mapped (or not) into the ZWave standard values supported by the command class, and/or what the device actually supports. Reactor's list is not limited by what the device does, although choosing values the device doesn't support usually won't do anything (or cause a default to be chosen, device-dependent); this has always been true for all devices on all controllers in Reactor.
EDIT: I see where you are getting the numbers, and that's actually a bug (an ancient one, at that) in the Reaction editor, nothing to do with ZWaveController specifically. That is now fixed both for general release 22053 and zwavejs build 22053.
Build 22053:
- Fixes in sync with general release build 22053 -- see BREAKING CHANGE notice there
- More small device tweaks
- The default for capturing the zwave-js logs is now
false
in config (i.e. it won't capture zwavejs log entries by default now).
Build 22054:
- Continued device improvements (lots of work on Aeotec devices among others)
