38 Posts 3 Posters 11.0k Views 3 Watching
    I just restarted MSR and it never came back up again.
    I cannot connect to it now in the browser it says connection refused.
    I can still SSH in to the Debian Linux box OK, so I rebooted that but still no MSR.
    if I run this command:
    systemctl --type=service
    It says "activating" for Reactor all the others say "active".
    I then tried updating MSR to the latest build that seemed to work as normal but MSR is still down and not accessible.
    Not sure what happened, I only pressed the Restart button in the MSR gui.
      I also have Node Red and HA Bridge running on the same Linux box, I can still access those two OK but not MSR..
      • K Offline
        K Offline
        kfxo
        Maybe the logs will have a clue? The other day I moved HA to a new computer and MSR was trying to connect to the old machine and MSR would not load. Sure enough the logs indicated that MSR could not connect to HA. Fixed that and all was well.
          I think you might be onto the right thing. I looked in to the log and it was complaining it can't connect to the InfluxDB running on another Raspberry Pi. That Pi has gone down at the moment and I can't connect to it for some reason.
          I don't know when the Pi went down? Might have been last week for all I know or this evening, I am not sure. So may or may not be related.
          So I edited the Reactor.yaml file and commented out all lines to do with the InfluxDB plugin and rebooted the Debian Linux box where MSR is running, but MSR is also still down and not accessible.
            This is the reactor.service file I haven't changed anything in there.
            [Unit]
            After=network.target
            [Service]
            Type=simple
            User=stuart
            Environment=NODE_PATH=/home/stuart/reactor
            WorkingDirectory=/home/stuart/reactor
            Restart=on-failure
            RestartSec=5s
            [Install]
            WantedBy=multi-user.target
            If I run these commands:
            sudo systemctl stop reactor
            and then
            sudo systemctl start reactor
            and then
            It still says that the reactor service is "activating"
            reactor.service loaded activating auto-restart Multi System Reactor
            • K Offline
              K Offline
              kfxo
              The logs dont say anything else? If not I dont know and you might have to wait for @toggledbits
                The timestamps in the logs don't seem to match the actual time here now, so I am having issues working out what is new or not in the logs.
                  • K Offline
                    K Offline
                    kfxo
                    Not sure what else to try as you already commented out the Influx. Maybe back up your MSR files and try a fresh install.
                        Initially I commented out all the plugin lines in the reactor.yaml file. After that didn't work I just deleted the entire plugins section from the file and that didn't work either.
                          Can't remember if I installed Node-Red or MSR first. Node-Red has been on this Linux Debian box along with MSR since day 1 when I first set it up.
                            I took a copy of the reactor.yaml file before I edited it, I just restored that and reboot and its still down in the browser.
                                Is this bad ?
                                EDIT:
                                            136.5k
