TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
38 Posts 3 Posters 7.4k Views 3 Watching
    I just restarted MSR and it never came back up again.
    I cannot connect to it now in the browser it says connection refused.
    I can still SSH in to the Debian Linux box OK, so I rebooted that but still no MSR.
    if I run this command:
    systemctl --type=service
    It says "activating" for Reactor all the others say "active".
    I then tried updating MSR to the latest build that seemed to work as normal but MSR is still down and not accessible.
    Not sure what happened, I only pressed the Restart button in the MSR gui.
      I also have Node Red and HA Bridge running on the same Linux box, I can still access those two OK but not MSR..
      • K Offline
        K Offline
        kfxo
        Maybe the logs will have a clue? The other day I moved HA to a new computer and MSR was trying to connect to the old machine and MSR would not load. Sure enough the logs indicated that MSR could not connect to HA. Fixed that and all was well.
          I think you might be onto the right thing. I looked in to the log and it was complaining it can't connect to the InfluxDB running on another Raspberry Pi. That Pi has gone down at the moment and I can't connect to it for some reason.
          I don't know when the Pi went down? Might have been last week for all I know or this evening, I am not sure. So may or may not be related.
          So I edited the Reactor.yaml file and commented out all lines to do with the InfluxDB plugin and rebooted the Debian Linux box where MSR is running, but MSR is also still down and not accessible.
            This is the reactor.service file I haven't changed anything in there.
            [Unit]
            After=network.target
            [Service]
            Type=simple
            User=stuart
            Environment=NODE_PATH=/home/stuart/reactor
            WorkingDirectory=/home/stuart/reactor
            Restart=on-failure
            RestartSec=5s
            [Install]
            WantedBy=multi-user.target
            If I run these commands:
            sudo systemctl stop reactor
            and then
            sudo systemctl start reactor
            and then
            It still says that the reactor service is "activating"
            reactor.service loaded activating auto-restart Multi System Reactor
            • K Offline
              K Offline
              kfxo
              The logs dont say anything else? If not I dont know and you might have to wait for @toggledbits
                The timestamps in the logs don't seem to match the actual time here now, so I am having issues working out what is new or not in the logs.
                  • K Offline
                    K Offline
                    kfxo
                    Not sure what else to try as you already commented out the Influx. Maybe back up your MSR files and try a fresh install.
                        Initially I commented out all the plugin lines in the reactor.yaml file. After that didn't work I just deleted the entire plugins section from the file and that didn't work either.
                          Can't remember if I installed Node-Red or MSR first. Node-Red has been on this Linux Debian box along with MSR since day 1 when I first set it up.
                            I took a copy of the reactor.yaml file before I edited it, I just restored that and reboot and its still down in the browser.
                                Is this bad ?
                                EDIT:
                                            2.1k
                                            3.8k
                                            3.3k
