Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
38 Posts 3 Posters 12.7k Views 3 Watching
    I think you might be onto the right thing. I looked in to the log and it was complaining it can't connect to the InfluxDB running on another Raspberry Pi. That Pi has gone down at the moment and I can't connect to it for some reason.
    I don't know when the Pi went down? Might have been last week for all I know or this evening, I am not sure. So may or may not be related.
    So I edited the Reactor.yaml file and commented out all lines to do with the InfluxDB plugin and rebooted the Debian Linux box where MSR is running, but MSR is also still down and not accessible.
      This is the reactor.service file I haven't changed anything in there.
      [Unit]
      After=network.target
      [Service]
      Type=simple
      User=stuart
      Environment=NODE_PATH=/home/stuart/reactor
      WorkingDirectory=/home/stuart/reactor
      Restart=on-failure
      RestartSec=5s
      [Install]
      WantedBy=multi-user.target
      If I run these commands:
      sudo systemctl stop reactor
      and then
      sudo systemctl start reactor
      and then
      systemctl --type=service
      It still says that the reactor service is "activating"
      reactor.service loaded activating auto-restart Multi System Reactor
      • K Offline
        K Offline
        kfxo
        The logs dont say anything else? If not I dont know and you might have to wait for @toggledbits
          The timestamps in the logs don't seem to match the actual time here now, so I am having issues working out what is new or not in the logs.
            • K Offline
              K Offline
              kfxo
              Not sure what else to try as you already commented out the Influx. Maybe back up your MSR files and try a fresh install.
                  Initially I commented out all the plugin lines in the reactor.yaml file. After that didn't work I just deleted the entire plugins section from the file and that didn't work either.
                    Can't remember if I installed Node-Red or MSR first. Node-Red has been on this Linux Debian box along with MSR since day 1 when I first set it up.
                      I took a copy of the reactor.yaml file before I edited it, I just restored that and reboot and its still down in the browser.
                          Is this bad ?
                          EDIT:
                                      Ok, so now look at the logs again. Disk space problem hiding others, now you should be able to see them.
                                        #22
                                        Don't know what's happened now but reactor.service is not even in the list at all anymore.
                                        The service file is still in there
                                        I'm downloading the syslog again now.
                                          #23
                                          OK these are the latest entries in the syslog to do with reactor
                                          Mar 18 22:07:48 HP-Thin01 node[522]: NODE_PATH /home/stuart/reactor
                                          Mar 18 22:07:48 HP-Thin01 node[522]: FileLogStream { type: 'file', name: 'reactor.log', maxsize: 2, keep: 5 }
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.123Z <app:null> Reactor latest-22069-ebeefad starting on v16.13.1
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.126Z <app:INFO> Process ID 522; platform linux/x64 #1 SMP Debian 4.19.208-1 (2021-09-29); locale en_GB.UTF-8
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.127Z <app:INFO> Basedir /home/stuart/reactor; data in /home/stuart/reactor/storage
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.128Z <app:INFO> NODE_PATH=/home/stuart/reactor
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.135Z <app:INFO> Configured locale (undefined); selected locale(s) en_GB.UTF-8
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.195Z <app:INFO> Loaded locale en-US
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.223Z <Capabilities:null> Module Capabilities v21333
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.354Z <Plugin:null> Module Plugin v21186
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.369Z <TimerBroker:null> Module TimerBroker v21333
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.381Z <default:INFO> Module Entity v22042
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.391Z <Controller:null> Module Controller v22003
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.392Z <default:null> Module Structure v22047
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.413Z <default:null> Module Ruleset v21096
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.414Z <default:null> Module Rulesets v21096
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.433Z <GlobalExpression:null> Module GlobalExpression v21333
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.474Z <Predicate:null> Module Predicate v22067
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.484Z <AlertManager:null> Module AlertManager v21355
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.490Z <default:null> Module Rule v22043
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.500Z <GlobalReaction:null> Module GlobalReaction v21333
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.504Z <default:null> Module Engine v22053
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.505Z <default:null> Module httpapi v22021
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.510Z <default:null> Module httpproxy v21333
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.554Z <default:null> Module wsapi v21334
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.558Z <app:NOTICE> Starting Structure...
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.567Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/home/stuart/reactor/storage] failed to read sys_alerts in /home/stuart/reactor/storage/states/sys_alerts.json: [SyntaxError]SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:07:48 HP-Thin01 node[522]: Trapped unhandled Promise rejection SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at JSON.parse (<anonymous>)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at Object.<anonymous> (/home/stuart/reactor/app.js:288:80)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                          Mar 18 22:07:48 HP-Thin01 node[522]: SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:07:48 HP-Thin01 node[522]: Promise {
                                          Mar 18 22:07:48 HP-Thin01 node[522]:   <rejected> SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:07:48 HP-Thin01 node[522]: }
                                          Mar 18 22:07:48 HP-Thin01 node[522]: Trace
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at process.<anonymous> (/home/stuart/reactor/app.js:271:162)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at process.emit (node:events:390:28)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at process.emit (node:domain:475:12)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at emit (node:internal/process/promises:136:22)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at processPromiseRejections (node:internal/process/promises:242:25)
                                          Mar 18 22:07:48 HP-Thin01 node[522]:     at processTicksAndRejections (node:internal/process/task_queues:97:32)
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.582Z <app:ERR> Trapped unhandled Promise rejection: [SyntaxError]SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.582Z <app:ERR> Please refer to the console log for trace
                                          Mar 18 22:07:48 HP-Thin01 systemd[1]: reactor.service: Succeeded.
                                          Mar 18 22:05:28 HP-Thin01 node[402]: [latest-22069]2022-03-18T22:05:28.048Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/home/stuart/reactor/storage] failed to read sys_alerts in /home/stuart/reactor/storage/states/sys_alerts.json: [SyntaxError]SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:05:28 HP-Thin01 node[402]: Trapped unhandled Promise rejection SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at JSON.parse (<anonymous>)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at Object.<anonymous> (/home/stuart/reactor/app.js:288:80)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                          Mar 18 22:05:28 HP-Thin01 node[402]: SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:05:28 HP-Thin01 node[402]: Promise {
                                          Mar 18 22:05:28 HP-Thin01 node[402]:   <rejected> SyntaxError: Unexpected end of JSON input
                                          Mar 18 22:05:28 HP-Thin01 node[402]: }
                                          Mar 18 22:05:28 HP-Thin01 node[402]: Trace
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at process.<anonymous> (/home/stuart/reactor/app.js:271:162)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at process.emit (node:events:390:28)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at process.emit (node:domain:475:12)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at emit (node:internal/process/promises:136:22)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at processPromiseRejections (node:internal/process/promises:242:25)
                                          Mar 18 22:05:28 HP-Thin01 node[402]:     at processTicksAndRejections (node:internal/process/task_queues:97:32)
                                          Mar 18 22:05:28 HP-Thin01 node[402]: [latest-22069]2022-03-18T22:05:28.097Z <app:ERR> Trapped unhandled Promise rejection: [SyntaxError]SyntaxError: Unexpected end of JSON input
                                            163.1k
