  2. Hardware
  3. Any decent destination for a Vera Plus?
Hardware
Shelly Wall Display XL
Hardware
Hardware
DIY HomeKey locks via Reactor
Hardware
A recent thread on supporting the ZRC-90 Z-Wave scene controller got me to wonder, what does everybody use and like? I'll start... oh, and no dashboards. I want to hear from you all about dedicated scene controller devices. Dashboards and apps are great to a point, but my experience is that higher WAF is achieved with (a) a dedicated device (b) in a known location (c) with predictable functions and (d) no extra steps to operate (just walk up to it and push a button -- same effort as a light switch/dimmer). She's not wrong. It's a pain to unlock the phone, find the app, open the app, find the device, tap the device, when you can just walk across the room and push a button. Bonus points for something that can be labeled readably (low WAF for stuck-on tape/thermal labels). I have a ZRC-90 and it's great, but it was temperamental to get working on Vera, and wasn't smooth sailing when it made the move to Z-Wave JS either. A couple of include/exclude cycles were needed to get it fully working on both. Since then, I've done a battery change, and while the buttons work as reliably as ever, the device continues to report the old battery level despite having a measurably fresh battery for over a year now. But I would still recommend it. I have a Hank 4-button that is probably the best and most reliable battery-operated scene controller I have ever used. It's small and unobtrusive, so it lives on a lamp base in our living room and controls the room's mood lighting. I'm not sure they're still available. RIP. I just ran across the Minoston MR40Z on Amazon, and I may try one of those. It looks like an installed (in-wall) Decora switch, but the buttons are actually a removable remote that you can pull off the wall and take to the couch. No line power required. Kinda cool. Maybe a good Hank replacement. But, I've never heard of this manufacturer before, and the concern is always "will I be able to buy more/replacements in one/two/five years?" Among the wired controllers, the Zooz ZEN32 seems to be the most popular modern unit. I like it, but the LEDs are too small for my aging eyes to discern their color in daylight -- they are pin-head sized. Four of the five buttons are too small to label, so low WAF. When I started my Z-Wave network, I used the Leviton four-button scene/zone controllers (VRCS4 and VRCZ4), and these are still all over my house. They're glitchy first-gen Z-Wave stuff (Vizia RF+ actually, so compatible but with proprietary features that aren't usable). They're now discontinued for Z-Wave. Leviton's newer units are WiFi, so if I go that route, it's HomeKit via Home Assistant for those. During the pandemic lock-downs, I built a touch-screen scene controller using an Adafruit PyPortal. It had screens with 1 to 8 labeled, colorable soft buttons that could either perform a device function (i.e. publish to MQTT) or take you to another screen, so it was the love-child of scene controller and dashboard. Wife found it agreeable. But it was just a prototype. Memory limitation of the device was an issue because the PyPortal is really an inexpensive teaching device with a big load of Circuit Python overhead, and the graphic display needs a lot of RAM, so it was severely limited. I'm sure it could work out with the right micro and programming closer to the bare metal. Packaging and powering would also need to be addressed. And, at the end of the day, while "cute," it doesn't seem like something I would want to sell with the house if we ended up moving some day. So, I'm interested in what others are doing and using, or more specifically, what your significant others are comfortable with and willing to use.
Hardware
O
Hardware
Z
Hardware
Hardware
LEDVANCE
O
Hardware
Water Flow Meter & Shutoff
B
Hardware
Hardware
Remote light switch
Hardware
ESP32 / ESP8266
Hardware
Hardware
Hardware
PerHP
After a long wait for an updated version of the rather crude and unfinished Z-Way integration to HASS, i'm now looking (reluctantly) in to replacing Z-Way with Z-wave JS.. Mind you this is a big existing network, not a new controller stick.. I threw up a docker for z-wave JS UI, and tried to connect it to the UZB stick.. It loads the whole network from the stick, but the driver keeps restarting? Looking at the logs, I see a lot of Dropping message because the driver is not ready to handle it yet. It seems like the stick just keeps talking like z-way was still listening? This ends up in the driver crashing repeatedly.. Any ideas to how I can get them talking? In the code snippet below, you see the driver restarting with the graphic letters, seemingly while the stick is mid-sentence, or because of ACK timeout... 2022-10-02T19:19:59.664Z CNTRLR received additional controller information: Z-Wave API version: 6 (legacy) Z-Wave chip type: ZW050x node type Controller controller role: primary controller is the SIS: true controller supports timers: false nodes in the network: 1, 5, 6, 10, 11, 12, 13, 14, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 32, 33, 34, 36, 37, 38, 39, 41, 42, 43, 44, 45, 46, 4 7, 48, 52, 55, 69, 70, 71, 73, 74, 75, 77, 78, 79, 81, 82, 83 2022-10-02T19:19:59.765Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated 2022-10-02T19:19:59.766Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated 2022-10-02T19:19:59.767Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated 2022-10-02T19:19:59.768Z CNTRLR [Node 001] [+] [Manufacturer Specific] manufacturerId: 277 2022-10-02T19:19:59.769Z CNTRLR [Node 001] [+] [Manufacturer Specific] productType: 1024 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [+] [Manufacturer Specific] productId: 1 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated 2022-10-02T19:19:59.771Z CNTRLR [Node 001] [+] [Version] firmwareVersions: 5.39 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [Version] sdkVersion: metadata updated 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [+] [Version] sdkVersion: "6.9.0" 2022-10-02T19:19:59.772Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms 2022-10-02T19:19:59.792Z SERIAL » 0x01050006640f97 (7 bytes) 2022-10-02T19:19:59.792Z DRIVER » [REQ] [SetSerialApiTimeouts] payload: 0x640f 2022-10-02T19:19:59.815Z SERIAL « [ACK] (0x06) 2022-10-02T19:19:59.816Z SERIAL « 0x01050106640f96 (7 bytes) 2022-10-02T19:19:59.817Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.177Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:03.178Z DRIVER version 10.2.0 2022-10-02T19:21:03.179Z DRIVER 2022-10-02T19:21:03.179Z DRIVER starting driver... 2022-10-02T19:21:03.199Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:03.212Z DRIVER serial port opened 2022-10-02T19:21:03.213Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:03.229Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.232Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.233Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.234Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.261Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.273Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.274Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.274Z DRIVER loading configuration... 2022-10-02T19:21:03.298Z CONFIG Using external configuration dir /usr/src/app/store/.config-db 2022-10-02T19:21:03.298Z CONFIG version 10.2.0 2022-10-02T19:21:04.284Z DRIVER beginning interview... 2022-10-02T19:21:04.286Z DRIVER added request handler for AddNodeToNetwork (0x4a)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for ReplaceFailedNode (0x63)... 1 registered 2022-10-02T19:21:04.287Z CNTRLR querying controller IDs... 2022-10-02T19:21:04.484Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:04.485Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:04.487Z SERIAL « 0x0123000400511a9f039900b834787d066515a4b79c45bb3af55ea7f6203006010 (37 bytes) 80120c84d 2022-10-02T19:21:04.489Z SERIAL « [DISCARDED] invalid data 0x9ef4 (2 bytes) 2022-10-02T19:21:04.490Z DRIVER Dropping message because it contains invalid data 2022-10-02T19:21:04.490Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:05.488Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i n 100 ms. 2022-10-02T19:21:05.591Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:05.592Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:06.596Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i n 1100 ms. 2022-10-02T19:21:07.698Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:07.699Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:08.717Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200) at Driver.sendMessage (/usr/src/app/node_modules/zwave-js/src/lib/driver/D river.ts:3980:23) at ZWaveController.identify (/usr/src/app/node_modules/zwave-js/src/lib/co ntroller/Controller.ts:713:33) at Driver.initializeControllerAndNodes (/usr/src/app/node_modules/zwave-js /src/lib/driver/Driver.ts:1207:26) at Immediate.<anonymous> (/usr/src/app/node_modules/zwave-js/src/lib/drive r/Driver.ts:1014:16) 2022-10-02T19:21:08.723Z DRIVER destroying driver instance... 2022-10-02T19:21:08.728Z DRIVER driver instance destroyed 2022-10-02T19:21:08.739Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:08.740Z DRIVER version 10.2.0 2022-10-02T19:21:08.740Z DRIVER 2022-10-02T19:21:08.740Z DRIVER starting driver... 2022-10-02T19:21:08.745Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:08.751Z DRIVER serial port opened 2022-10-02T19:21:08.752Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:08.754Z DRIVER loading configuration... 2022-10-02T19:21:08.755Z SERIAL « 0x01080120c84d9ef40138 (10 bytes) 2022-10-02T19:21:08.757Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:08.758Z DRIVER « [RES] [GetControllerId]
Hardware
Hardware
Hardware
Hardware
Hardware
34 Posts 11 Posters 15.3k Views 9 Watching
    Check the docs; clearly after what I did to @wmarcolin , my memory is not reliable of these details! 🙂
    In any case, the indenting is way off.
    @toggledbits testing with version 22025 we have the following situation.
    In the manual (https://reactor.toggledbits.com/docs/Troubleshooting-Entities/), it looks like this:
      accept_entity:
        "device_123": true
      dump_entity:
        "device_123": true
    I tested it this way in the new version and it works like the manual - without quotes (have to fix the manual):
          source: 'http://192.168.33.6:3480'
          accept_entity:
            device_9: true
    So, I tested the new version that I understand you have aligned with the other systems:
          accept_entity:
            - device_9
    OR
          filter_entity:
            - device_9
    IT WORKED!!!
    Testing the way that mentioned @tunnus :
          filter_entity:
            - "vera>device_9"
    IT DOESN'T WORK, with or without the quotes it doesn't work.
    IN SUMMARY, the form can be for Vera, don't know for other hubs:
      accept_entity:
        device_9: true
    or
      accept_entity:
        - device_9
    I hope I have helped.
    • wmarcolinW wmarcolin
        accept_entity:
          "device_123": true
        dump_entity:
          "device_123": true
            accept_entity:
              device_9: true
            accept_entity:
              - device_9
      OR
            filter_entity:
              - device_9
      IT WORKED!!!
            filter_entity:
              - "vera>device_9"
        accept_entity:
          device_9: true
      or
        accept_entity:
          - device_9
      @wmarcolin said in Any decent destination for a Vera Plus?:
      The reason it doesn't work is because you are including a controller ID to make it a canonical ID. Canonical IDs are not used in that context because the configuration is already specific to one controller -- you don't tell it the controller for filter_entity in a VeraController config because it's in the controller's config, so it already knows.
      InfluxFeed is different because it watches entities for all controllers, so when identifying an entity, you have to use a canonical ID.
      As for quotes or no quotes, as long as the string doesn't contain any characters with special meaning to YAML, you don't need quotes. Do you know what those are? I don't keep that in my head. So I default to using quotes whenever it's anything other than A-Z, 0-9 and underscore. The > used in canonical IDs can definitely cause problems, so I always quote canonical IDs.
      • wmarcolinW Offline
        New use for Vera, and helping to save him from the incinerator 🙂
        One of the eventual problems I am having with Hubitat, are devices that are added with Security S0, and several community posts report that this is a problem.
        So today I removed and reinstalled what had S0, but 4 there was no way to get in without Security, and to not create a problem in Hubitat's z-wave network, I installed again in Vera: Door Lock Yale B1L YRD110-ZW-0BP, Smoke Sensor Smoke (2x) and Bulb Zipato RGBW2.US.
        Of course I had problems to include in the Vera, the bulb is failing, everything we already know in the Vera. Just unfortunate that Hubitat can not bypass this problem.
          @wmarcolin I only have the security enabled on my two Schlage locks. I have no issues with my iblinds anymore (which I did when I first paired them using security.)
            @gwp1
            I have tried several times, removing the device and reinserting it, hoping to get the prompt to use the security code or not, but it didn't happen. So I put it in the Vera, so if there is a communication problem, it doesn't affect the Hubitat network, and the Vera ended up with only these 4 devices.
            I also took the opportunity to remove the Vera from the cloud (https://github.com/toggledbits/Vera-Decouple) for stability.
              @gwp1
              I shared this information on the Hubitat forum, and received a message that I think is in line with your comment about the lock, that even though it is S0 I should keep it on Hubitat because in this case, not having recurring status communication would not affect the z-wave network. I think I will come back.
                parkercP Offline
                parkercP Offline
                parkerc
                … I wanted to open a debate, for those who have not yet sold their Vera on eBay, are with the equipment idle, what destination could be given?
                I have to admit, my Vera (of which I have 4 now, thanks to people who have jumped ship via eBay 😎) still runs my house, and being paired with a Rasp Pi - that provides me with additional command line capabilities too. Hence it’s still ticking the majority of boxes for me, and call me crazy but I do love the Vera UI.
                My situation is perhaps a little different in that It took me well over a decade of using Veras, to understand aspects of what goes on under the hood (Lua/Luup wise), and I’ve just recently started to create my own Vera plugins (oh if my younger self could see me now ;-)). That capability is opening up area I never thought of before. So as you can see I’m very late to the party on that front, which is a shame..
                With all that said, I know it’s not going to last forever, and sadly my dream of ezlo making Vera (Luup/UI) a community version for us all to build on is likely never gonna happen, but I have no idea where I’ll eventually end up.
                I do love the open-source stuff and must have tried pretty much everything out there, HASS, OpenHAB, NodeRed etc. plus I’ve also been tempted by the Hubitat and Fibaro HomeCenter even ezlo Hubs if they get their act together.
                Ultimately- I like the idea of having a ‘one-stop-HA-shop’ - with everything I need all in one place..
                P 1 Reply Last reply
                • parkercP parkerc
                  P Offline
                  P Offline
                  prplrhd
                  @parkerc Well said. I'm grateful to hang with the geniuses around here and contribute what I can over the years. But the situation with Vera and Ezlo doesn't stimulate confidence in any commitments to cooperation or extensibility, does it?
                  I have vacation rentals with Vera Plus or Secure. Lots of lovingly handcrafted scenes, lua code, defunct plug-ins glued together, scripts on Pis. I would love to pull together a "greatest hits" compilation of how-to documentation to set up automation analogous to Vera capabilities. Open-Luup on Pi? How to set up GUI and remote access? some hybrid with existing Vera UI7 GUI (mob app sux). But clearly decoupling is providing many benefits. Several have gone in different paths, would be great if there is a hardware/software/plug-in view for the future as a migration path outside of Ezlo
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    #26
                    OK, well let’s see what a non-Vera, Vera-like set up could look like…
                    openLuup - https://github.com/akbooer/openLuup
                    openLuup zway - https://github.com/rafale77/Z-Way
                    And in your situation, each remote location will need some sort of a vpn server set up; so you can connect to it remotely, so maybe something like..
                    PiVPN - https://thesecmaster.com/how-to-set-up-open-vpn-on-raspberry-pi/
                    Assuming you can migrate your Vera plugins and zwave devices to the above Open-Luup set up - What else do you have to factor in ?
                      I have largely moved away from Zwave, excepting my beloved MiniMote 4-button controllers (about half a dozen of those) and a couple of electricity meter readers. These are also the only devices that remain on Vera… I just haven’t bothered to move them. ZWay would be a good alternative here, when Vera finally fails. Don’t say I didn’t warn of the demise of Vera, and Ezlo was never a contender.
                      Of course, openLuup does all my automation, along with Shelly devices via MQTT and Philips Hue. The whole thing is now supervised by Apple Homebridge running on a Synology NAS (along with openLuup) and it’s the Apple Home app that I use for occasional manual control and remote access… no need for a VPN.
                      parkercP 1 Reply Last reply
                        parkercP Offline
                        parkercP Offline
                        parkerc
                        #28
                        @akbooer said in Any decent destination for a Vera Plus?:
                        It’s been a pretty long, drawn out demise 🙂 and thankfully, even in this limbo state, I’m still getting what I need from my Veras.
                        The whole thing is now supervised by Apple Homebridge running on a Synology NAS (along with openLuup) and it’s the Apple Home app that I use for occasional manual control and remote access.
                        Nice, I’ve been running Homebridge and openLuup on my QNAP - for a while, just to give me an iOS route into things, but I’ve never considered making it the overall supervisor - but you’ve got me thinking (as the house is largely Apple)
                        Which Vera Homebridge plugin are you using ?
                        My Docker/QNAP side-set up is pretty good, and i have multiple HA related containers (node-red, zoneminder, Homebridge , HomeAssistant, Homer etc.) all interacting with each other - but I must admit I do still like the idea of having everything I need focussed into a few, and all running on a Raspberry PI. (Perhaps that’s more for the confidence in using all my usb add-on elements ( Bluetooth, zwave and RFXtrx433).
                          oznu/homebridge
                          • parkercP Offline
                            parkercP Offline
                            parkerc
                            Which plugin ?
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                Ok, that’s helps as it looks like your not using one of the purpose built Vera plugins - I was wondering if you had got one of those yo work with openLuup.
                                I’ve tried a couple but no luck for me (so far)
                                  It’s all done via MQTT.
                                  • parkercP parkerc
                                    @parkerc The old unmaintained one from damianxd is in fact working fine with openLuup but it's not very efficient as it polls very frequently. I'd go the MQTT path as well with Mqttthing.
                                    The only downside I see is that openLuup must be set to publish every variable update which for me causes a lot of unnecessary traffic.
                                      378
                                      151.4k
