  4. MSR actions aren't running anymore-- can't find what's broken
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
11 Posts 6 Posters 1.8k Views 6 Watching
    apocalypsehobby
    Hey crew,
    I'm running into an issue where MSR's reactions aren't successfully running, and I can't figure out what's gone wrong.
    Backstory-- we had a big thunderstorm roll through the other day, we lost internet and the storm got bad so I unplugged most items in my homelab, including the Pi that's running MSR.
    Now that everything is powered back up, the reactions aren't running correctly. Most of my MSR automations are to use motion sensors to turn lights on/off, and I immediately noticed that even when a motion sensor is tripped, the light doesn't turn on like it's supposed to.
    I've tested a bunch of things to see what's broken, here's what I've observed:
    -I can successfully flip lights on/off manually within Vera
    -I can successfully flip lights on/off manually within MSR's Entities section
    -the motion motion sensors are correctly reporting to Vera and MSR (I can see when they're sensing motion)
    -the rules within MSR are working correctly, I can see when they flip to 'true' when I walk by a motion sensor
    -I can successfully run the Reaction within MSR (by hitting the 'play' button)
    But for whatever reason, when everything needs to work together, it doesn't successfully run the action. IE: the motion sensor trips, reports it to MSR, I can see MSR going "true" but the light does not turn on. Open to any suggestions, thank you!
    SYSTEM
    Vera has all my devices
    MSR is running bare metal on Rpi "Reactor (Multi-hub) stable-22004-6d6c6b7"
      I don't know what would of broke but that appears to be an old build. Have you thought about upgrading to the newest version? Is there anything in the Logs to give you a clue?
      • S SweetGenius
        apocalypsehobby
        @sweetgenius yeah I should— I can probably do that tomorrow.
        • E Offline
          E Offline
          Edwin1972
          I had the same problem. After upgrade to new version the problem is solved
            apocalypsehobby
            Of course, that fixed it. Thank you both!
              Motsie
              wrote on last edited by Motsie
              Hi Guys,
              I Have exact the same problem.
              My story is that I got a new ISP modem, I corrected everything, set all the IP addresses to the same numbers as before. Restarted all the Home Automation hardware and still no clue.
              System: MSR in docker container on Synology NAS, Vera PLus Zwave with all devices and a Home Assistant for some extra information.
              The reactions aren't running correctly. Most of my MSR automations are to use motion sensors to turn lights on/off, and time based automations nothing worked where MSR does his magic.
              I've also tested a bunch of things to see what's broken, here's what I've observed:
              But I cannot successfully run the "Set Reaction" and "Reset Reaction" within MSR (by hitting the 'play' button)
              But the play buttons on the action in the "Set Reaction" and in "Reset Reaction" they work well.
              Lastly I updated the Docker Container as you all suggested.
              But on my system nothing changes.
              M 1 Reply Last reply
              • C Offline
                C Offline
                christian_fabre
                I had the same problem yesterday following a power outage.
                I saw that MSR reacted but there was no effective reaction.
                I didn't see anything in the logs
                I reinstalled MSR and the problem went away.
                  Motsie
                  I Found something in the docker logs, which II don't understand how to fix:
                  stream | /var/reactor/logs/reactor.log not open boolean | false
                  opened file with correct file editor and saved back with docker stopped container, now message is gone, but did not solve issue.
                    You replied on the solution.
                      Motsie
                      @toggledbits Thanks for your remark, I get that it won't get much attention then 😉
                      Solved the problem though. It was in the upgrade to 22203 from 22080, where the docker file got renamed. Came here to place this in this thread. Thanks again.
                      • M Motsie
                        Hi Guys,
                        Motsie
                        @motsie
                        [SOLVED] this problem; it was in the upgrade from 22080 to 22203 where the Docker file got renamed.
                        • E Edwin1972 referenced this topic on
                        • Next Release?
