  4. MSR Not Recognizing Old HASS on New VM
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
20 Posts 2 Posters 2.3k Views 2 Watching
    wrote on last edited by Pabla
    Hey Patrick, had to switch over my HA VM from VirtualBox to VMware since VirtualBox stopped playing well. Anyways I updated the IP address to the new VM IP and deleted the Long Lived Access Token and created a new one just in case (copy pasted the new token into the config file). Tried rebooting both the HA machine and the MSR one too and MSR is still not connecting. The only thing I have not tried yet is creating another controller entry, but I am worried it may create all new entities for everything forcing me to redo all my logic. Here are some logs:
    [latest-22258]2022-09-20T21:17:24.749Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
    [latest-22258]2022-09-20T21:17:24.749Z <HassController:NOTICE> HassController#hass websocket to ws://192.168.8.113:8123/api/websocket closed during open/negotiation
    [latest-22258]2022-09-20T21:17:24.749Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
    [latest-22258]2022-09-20T21:18:09.753Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
    [latest-22258]2022-09-20T21:18:24.761Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
    [latest-22258]2022-09-20T21:18:24.761Z <HassController:NOTICE> HassController#hass websocket to ws://192.168.8.113:8123/api/websocket closed during open/negotiation
    [latest-22258]2022-09-20T21:18:24.761Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
    [latest-22258]2022-09-20T21:19:01.083Z <VeraController:INFO> VeraController#vera 0 dead entities older than 86400000s purged
    [latest-22258]2022-09-20T21:19:14.780Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
    [latest-22258]2022-09-20T21:19:29.785Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
    [latest-22258]2022-09-20T21:19:29.785Z <HassController:NOTICE> HassController#hass websocket to ws://192.168.8.113:8123/api/websocket closed during open/negotiation
    [latest-22258]2022-09-20T21:19:29.785Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
    [latest-22258]2022-09-20T21:20:24.791Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
    [latest-22258]2022-09-20T21:20:39.813Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
    [latest-22258]2022-09-20T21:20:39.820Z <HassController:NOTICE> HassController#hass websocket to ws://192.168.8.113:8123/api/websocket closed during open/negotiation
    [latest-22258]2022-09-20T21:20:39.820Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
      Check the (Home Assistant) settings for the http component and make sure those make sense for the new IP you are on. Also make sure the websocket_api component is configured. Did you make any other configuration changes? Enable SSL/TLS? If you were using SSL/TLS on the old VM, did you issue a new certificate for new one?
        I am not sure what to check for the http component in HA, however I confirmed that web socket is still in my configuration file. I have not made any other config changes, basically restored from my backup from the old VM. I wasn't using SSL/TLS on the old VM so I don't think I need to mess with it.
          Doing a bit of research on the HA forums and looks like someone has had almost the exact same issue and came to the solution of disabling https. Haven't tried that yet since I am unsure if that would be safe.
            Try adding ignore_cert: true in the config section for HassController (after source and same indent level). You may additionally need to change the ws:// in the source to wss://. If that works, SSL/TLS is enabled in Hass and you are on a self-signed or invalid certificate (but no changes to Hass needed).
            Also, if your Hass http component configuration has ssl_certificate then SSL/TLS is enabled. That's another way to tell.
            PablaP 1 Reply Last reply
              @toggledbits tried setting ignore_cert: true and this is what came up in the logs tried both ws:// and wss//. I do not have the http component in my HA config file
              [latest-22258]2022-09-21T02:52:29.492Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
              [latest-22258]2022-09-21T02:52:29.493Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
              [latest-22258]2022-09-21T02:53:29.501Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
              [latest-22258]2022-09-21T02:53:29.502Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
              [latest-22258]2022-09-21T02:54:29.507Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
              [latest-22258]2022-09-21T02:54:29.509Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
              [latest-22258]2022-09-21T02:55:29.519Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
              [latest-22258]2022-09-21T02:55:29.519Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
              [latest-22258]2022-09-21T02:56:21.052Z <VeraController:INFO> VeraController#vera 0 dead entities older than 86400000s purged
              [latest-22258]2022-09-21T02:56:29.528Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
              [latest-22258]2022-09-21T02:56:29.529Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
              [latest-22258]2022-09-21T02:57:29.530Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
              [latest-22258]2022-09-21T02:57:29.531Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
              [latest-22258]2022-09-21T02:58:20.106Z <Rule:INFO> "10 Min Light Polling" (Rule#rule-grpqldnna5) starting evaluation; because timer-trigger Timer#rule-grpqldnna5
              [latest-22258]2022-09-21T02:58:20.107Z <Rule:INFO> "10 Min Light Polling" (Rule#rule-grpqldnna5) evaluated; rule state transition from RESET to SET!
              [latest-22258]2022-09-21T02:58:20.124Z <Rule:INFO> "45 Min Light Polling" (Rule#rule-l6whyfqd) starting evaluation; because data-changed Data#states:cs-rule-grpqldnna5
              [latest-22258]2022-09-21T02:58:20.124Z <Rule:INFO> "10 Min Light Polling" (Rule#rule-grpqldnna5) evaluation complete
              [latest-22258]2022-09-21T02:58:20.125Z <Rule:INFO> "45 Min Light Polling" (Rule#rule-l6whyfqd) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-22258]2022-09-21T02:58:20.126Z <Rule:INFO> "45 Min Light Polling" (Rule#rule-l6whyfqd) evaluation complete
              [latest-22258]2022-09-21T02:58:20.126Z <Engine:INFO> Enqueueing ""10 Min Light Polling<SET>"" (rule-grpqldnna5:S)
              [latest-22258]2022-09-21T02:58:20.139Z <Engine:NOTICE> Starting reaction "10 Min Light Polling<SET>" (rule-grpqldnna5:S)
              [latest-22258]2022-09-21T02:58:20.140Z <HassController:null> HassController#hass: sending payload for x_hass_system.call_service on System#hass>system action: [Object]{ "type": "call_service", "service_data": { "entity_id": "light.island_lights" }, "domain": "zwave_js", "service": "refresh_value" }
              [latest-22258]2022-09-21T02:58:20.141Z <HassController:ERR> HassController#hass request 1663729100140<2022-09-20, 7:58:20 p.m.> (call_service) failed: [Error]Error: WebSocket not connected
              [latest-22258]2022-09-21T02:58:20.143Z <Engine:INFO> Resuming reaction "10 Min Light Polling<SET>" (rule-grpqldnna5:S) from step 1"
              Not sure if this is useful but here are some logs pertaining to web socket from HA Supervisor
              22-09-20 19:39:48 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
              22-09-20 19:58:33 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
              22-09-20 19:58:33 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_vscode
              22-09-20 19:58:33 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
              22-09-20 19:58:38 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
                The log snippet shows the ws:// result but no wss:// result. I'd like to see that, because it's probably a different message and maybe more useful. The messages you are showing clearly indicate it wants you to use wss://.
                  @toggledbits logs attached using wss://
                  [latest-22258]2022-09-21T02:38:34.723Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:38:34.723Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
                  [latest-22258]2022-09-21T02:38:34.723Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:38:39.737Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
                  [latest-22258]2022-09-21T02:38:54.745Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:38:54.745Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
                  [latest-22258]2022-09-21T02:38:54.746Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:38:59.748Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
                  [latest-22258]2022-09-21T02:39:14.751Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:39:14.752Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
                  [latest-22258]2022-09-21T02:39:14.752Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:39:19.759Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
                  [latest-22258]2022-09-21T02:39:28.763Z <VeraController:INFO> VeraController#vera 0 dead entities older than 86400000s purged
                  [latest-22258]2022-09-21T02:39:34.765Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:39:34.765Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
                  [latest-22258]2022-09-21T02:39:34.765Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:39:39.771Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
                  [latest-22258]2022-09-21T02:39:54.776Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:39:54.777Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
                  [latest-22258]2022-09-21T02:39:54.777Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:40:04.779Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
                  [latest-22258]2022-09-21T02:40:19.786Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:40:19.787Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
                  [latest-22258]2022-09-21T02:40:19.788Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:40:34.791Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
                  [latest-22258]2022-09-21T02:40:49.796Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:40:49.797Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
                  [latest-22258]2022-09-21T02:40:49.798Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
                  [latest-22258]2022-09-21T02:41:00.728Z <Rule:INFO> Inside Light Polling (Rule#rule-grpqlebtkk) starting evaluation; because timer-trigger Timer#rule-grpqlebtkk
                    And that's also with ignore_cert: true, correct?
                      @toggledbits correct
                        OK. All I can suggest at this point is that maybe you have the old IP address of the previous system in Hass' configuration somewhere and it's messing things up. Beyond that, I'm out of ideas. Maybe shut down that VM, create a new one, install Hass fresh and clean without restoring the prior configuration, just use a default configuration, and see if you can connect to it. If you can, it's definitely something in the old config/restored install. If you can't, maybe something in the VM configuration... I don't know. This usually isn't much of a challenge, and HassController isn't doing anything tricky, it uses a standard Websocket library in wide use for its connections, so I'm doubtful there's suddenly some bug or incompatibility there.
                          @toggledbits Will try creating a new Hass install and see if I can get MSR to work. In terms of the existing config, none of the entities will get auto deleted since the controller is offline right? Also if I clear out he Hass config completely from MSR, restart MSR then reconfigure as if its the first time entering a Hass config in will this overwrite all my existing Hass entities?
                            Just use a different ID for the new HassController instance... so if you had id: hass in the first config, use hass2 in the second.
                            It probably won't matter anyway, as the IDs should be stable... the new entities would have the same IDs as the old, be of the same type, etc.
                              @toggledbits Just quickly set up a new Hass VM and am seeing the same errors. Tried with both ignore_cert: true and false no luck. This seems to be a VMware issue, I did do look through settings but couldn't really see anything that would stop MSR from connecting.
                                To be specific, you need to try ws:// (ignore_cert does not matter for this case), and wss:// with ignore_cert: true. Both cases.
                                Beyond that, I'm at a loss. Are you running Hass in docker? Are you running Reactor in docker? I'd look at all of that, too...
                                  @toggledbits Neither are running in docker, both run on their own VM on the same host. Just the difference now is Reactor is running on a VirutalBox VM and MSR is on a VMware VM
                                    @pabla said in MSR Not Recognizing Old HASS on New VM:
                                    Huh?
                                      Huh?
                                      @toggledbit Lol whoops meant to say MSR is running on a VirtualBox VM and Hass is running on a WMware VM
                                        So did a little research and it looks like Websocket is not supported in VMware workstation 16.. I just bought an ODROID cause I am tired of tinkering with all these issues I have had with VMs
                                          Just to close this thread up, it was a VMware issue as stated above. Moved over to an ODROID and MSR connected no problem.
                                            99.7k
                                          • Next Release?
