  4. [Resolved] Day mode implementation question
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
31 Posts 5 Posters 6.8k Views 5 Watching
    @gwp1 I don't understand all the complexity around the Day rule looking at sunrise and wake up times. I think what you are describing is that you want Day to start at the earlier of sunrise or your wake-up time, and that's a simple OR condition: Wake Up Times is true OR time is after sunrise. And the period before from midnight to either has nothing to do with that and isn't a consideration.
    @toggledbits Oy. I don't know how I missed that. I am embarassed.
    In my defense, I do have a history of designing rules much harder than they need to be. I tell myself "think edge" but still try to circle everything instead.
    Guessing for Evening the recommendation would be after sunset vs between sunset/sunrise?
    @Pabla the OR is there for future state... waiting on an update to iCloud3 in HASS that will allow triggering from the presence of my Apple Watch as well as iPhone for those times when it's a quick trip out and I let the Ultra do the work vs carrying the phone, too (think workout, bike ride, etc.)
        @toggledbits had to mess about with some mode additions/removals and changed sunrise/sunset to between to make this work as at sunset both Day and Evening modes were valid at sunset.
        Would this be better served as is or by adding this under Constraints?
          Depends entirely on what the actions are, and when you want them to run. I'm assuming it just sets mode to Day. If the mode changed during the day, would you want it changed back to Day? Trigger.
          G 2 Replies Last reply
            @toggledbits Yep, absolutely - if I leave during the day mode shifts to Away - returning home the expectation would be a return to Day if still before sunset. Same with Evening if after sunset.
              I continue to wrestle with modes. Changing Wake-up and Sunrise to after in Day resulted in a battle between Day and Evening in the later hours as both were "valid" after sunset given the OR in Day
              I've modified Wake-up to start at the two wake times, 0630 ET and 0730 ET, and end before 12noon ET. This closes it off from arguing at sunset.
              Day currently reads as such now:
              • I must be home (can this be addressed better by "mode != Away"?)
              • It must be after wake-up times OR after sunset sunrise, whichever comes first
              • must be ignored if in Vacation (I'm away for extended period) or Guest (someone specific is checking on the house whilst I'm on vaca)
              Evening
              • should kick in after Sunset
              • I must be home (again, can this be driven by mode != Away better?)
              Night is set manually, ie not on a schedule. Two ways it can be set, the more basic is via voice command to Amazon Echo device that flips a virtual switch which triggers mode.
              The second is more complex but still manual:
              • phone must be in master bedroom
              • phone must be charging for > 00:00:10 (so lockdown can be aborted if needed)
              • can only be triggered if the above triggers happen whilst in Evening or Work (awakened in the middle of the night for a work thing and returning to sleep). If I happen to charge the phone during the day the house shouldn't lock down in Night mode.
              I put this out there because I have a tendency (ok, more than a tendency) to overthink and over-complicate my rules as @toggledbits will confirm. This results in unnecessary demand on MSR as well as rules fighting with rules or duplicating outcomes.
                Evening
                @gwp1 said in Day mode implementation question:
                It must be after wake-up times OR after sunset, whichever comes first
                I suspect you mean 'Sunrise'?
                  @catmanv2 Egad, yes. Edited. Thank you!
                    In your "Day" ruleset for sunrise/sunset condition set the sunset condition to be a few minutes before sunset. This way both sunset conditions in "Day" and "Evening" won't go true at the same time. Alternatively you could also add a condition in the "Day" rule that the "Evening" rule must be false . This will make sure "Day" can't be true at the same time as "Evening".
                      @pabla Add a specific condition for Evening = false or add it to this existing condition in Day:
                      PablaP 1 Reply Last reply
                        @gwp1 On second thought I would just add the offset to the sunset time in the "Day" rule. Its less of a band-aid solution.
                          @pabla Updated to:
                            wrote on last edited by Pabla
                            Yeaup that should do the trick, what basically was happening as you said was the sunset conditions in both Day and Evening were true at the same time therefore causing the both rules to be true as well.
                            Now that you added the 1 mins before sunset, they won't overlap.
                              @pabla It should eliminate any race state. The original config was to have "Wake-up" and "sun" both use after but that created a mess alongside Evening as everything ran to midnight together.
                              • therealdbT Online
                                therealdbT Online
                                I don't known why you're all setting a mode like this, but I'm still using home/away/night to drive my rules, plus a lot of flags (dark, sleeping, holiday, party, mute, green mode, solar, rainy, windy, bad weather) to combine all them together and drive my reactions. I'm curious to understand why you prefer this approach.
                                PablaP G 2 Replies Last reply
                                  @therealdb My house modes are simple: Night/Home/Away/Vacation. All them are configured very simply, based on if the alarm is turned on (either stay or away) and who's home. That way there is no accidental/unexpected mode changes
                                    @therealdb said in Day mode implementation question:
                                    This is exactly what I'm driving at. I use Mode followed by a number of what I call "shared rules" (Wake-up times, cloudy day, temp < 40º, presence, etc.) that can be/are referenced in many other rulesets. Where I'm hitting my wall is the actual triggering of the modes (Day, Away, Evening, Night).
                                    My curiosity is around how you're actually triggering the modes themselves. The rest... I've got that nailed down.
                                      So I went back in time to when I first set modes up. Here's my current settings:
                                      53c7b6b5-eedb-40b6-a955-140c9ae469eb-image.png 9c58c5b8-bf57-474a-9fe8-d8c71d9c1200-image.png
                                      I will use Wake Up Times internally with other rulesets rather than trying to use it to drive at the higher Mode level. Presence will be in those rulesets as well.
                                        therealdbT Online
                                        therealdbT Online
                                        @gwp1 I'm using the alarm to drive modes, as @Pabla
                                        I'm also triggering wakeup mode from the alexa's alarm, so it's possible to move the time and automatically execute actions.
                                          @therealdb Interesting approach, using the Echo devices. I'd be concerned over any outage potential, has that been an issue?
                                            165.3k
