  3. X-10 replacement for a new wall switch (HomeKit)
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
4 Posts 4 Posters 1.9k Views 4 Watching
    gugy
    I have a X10 wall switch system and I want to get rid of it. What would be the easiest transition to something more modern and easy to use with either wifi/homekit capabilities? My current X10 controls 3 zones in my bedroom. All zones are dimmable.
    Zone 1 is 4 canister ceiling lights. LED bulbs
    Zone 2 is 1 canister ceiling lights. Halogen Bulb
    Zone 3 is 1 canister ceiling lights. Halogen Bulb
    I have an old plug-in remote from Radio Shack and a wall switch with 3 buttons, each controlling one zone. (images attached)
    My wall switch has one two wires from the wall. One black, one white.
    Is there any solution easy to install without the need of an electrician? Thanks for any feedback.
      No takers yet?
      My suggestion would normally be a Shelly device (i4 has four input capability) controlled over WiFi by HomeKit, or the like…
      …but with only two wires it looks like you have no neutral in the box?
        If you're us based, take a look at zooz zen32
        Zooz ZEN32 Scene Controller
        It's zwave, but leds are customizable and it's very cool.
          This is like hearing the very last Blockbuster location is closing... I never imagined any X10 devices would have made it into the 2020s, much less a houseful of them! A hearty hello from a fellow X10 traveler who refuses to empty his two Tupperware tubs of old controllers, switches, receptacles, bridges, lamp/appliance modules, dimmers, contacts, remotes, extenders, sirens, alarms and myriad other 1980/1990's-era componentry. 🙂
            148.8k
