  3. 3-way smart switches in separate buildings.
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
wifi switches3-waymulti-building
7 Posts 3 Posters 1.5k Views 3 Watching
  • D Offline
    D Offline
    dumonttim
    So, I think I'm in a bit of an unusual situation. I work at a camp & retreat center that has wifi throughout. I want to put a few switches in the office that can control outdoor lighting throughout the camp. We currently have switches in each of the buildings, but it is a particularly frustrating job to get all the lights on in the evening when it is brutally cold out or we are short staffed.
    Most of our staff is not very tech savvy (my boss literally has his wife print out his emails for him each day!!!) so, I'd love to avoid having to set up any sort of raspberry pi or new phone app.
    Is there type of 3-way switch that can connect to the wifi, turn on a light in another building AND turn on an indicator light in the office, without having any sort of wire running between the buildings? Hopefully looking for a simple solution without breaking the bank too.
    I greatly appreciate any input that you can give. Thank you!
      Which country are you in?
      Some Shelly switches, attached (by WiFi) to the same LAN could accomplish this, IMHO.
      • Black CatB Offline
        Black CatB Offline
        Black Cat
        ^^^ @akbooer Why not use the WAP that is on Shelly devices for local control? Realistically, the Shelly App would be simpler.
        aka Zedrally
          Yes, doesn’t really matter how you access them, but Shelly is a nice hardware solution to this one.
          • D Offline
            D Offline
            dumonttim
            First off, I'm in the U.S. if that matters for anyone. Also I'm super new to smart home stuff. I'm looking at Shelly's products and I understand electrical wiring, but I'm wondering how these devices will help me. If I run power to a switch in our main office, how will I get it to turn on the lights in the dorm building? Do I need to program it through the app? If I do, would the physical light switches still work in both locations (again, there is no direct connection they have separate electrical panels and meters)?
            I'm sorry if my explanation is confusing or not thorough enough. This is a whole new beautiful world I'm exploring right now.
              Black CatB Offline
              Black Cat
              Best advice I can give you is to buy one and play with it.....
              aka Zedrally
              • Black CatB Black Cat
                @black-cat said in 3-way smart switches in separate buildings.:
                Good advice here.
                But, in short, they all have WiFi capability, you can program them through a web browser (or their app) and a physical switch (or any number of them) can be virtually connected to a number of remotes. N-way switching (ie. multiple switches for the same lights) can be easily arranged. You don’t need any sort of central controller. They also have built-in timers with programmable schedules… Awesome!
