  4. Reactor Ex Machina
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Reactor Ex Machina
18 Posts 5 Posters 3.2k Views 5 Watching
    @toggledbits was looking thru rule sets and updating which (new) lights I wanted REMII to impact and saw that this...
    ...is showing as (missing) in the rule Deactivatedand looking in the dropdown of Variables it appears I cannot select that local expression (only Global) as I did when originally building this out back in 2021.
    In looking at the rule Active Period I'm seeing:
    487074ef-3bfa-4a84-b03d-ed6d920c118c-image.png which appears to be pointing to setting a variable in a rule?
    It's admittedly been a couple years since this was built and it's def not fresh in my memory.
    *Hubitat C-7 2.5.0.135
    Core 2026.5.0
    MSR: latest-26127-726206dd
      You didn't show the local expressions?
        @toggledbits I guess that's the problem: there are only Global expressions selectable. Looking thru the rules:
        15189579-1ed6-4fff-9259-5750396878ef-image.png 7e4615fc-2621-40e8-a9c8-2abee0e1075b-image.png
        Core 2026.5.0
          Back in mid-2021 there were a bunch of changes to variable evaluation and the rules around that, and among them, a rule cannot set or examine a local variable in another rule. I suspect you're just noticing the effect of that here. The engine still runs those rules, but you cannot edit them and leave them in that condition. The shared variable needs to be moved to global scope.
            @toggledbits I suspected that might be the case (something changed). Of course, I've poked at the Deactivated rule this morning so I've probably broken things now.
            I'm guessing I need to convert any Local expression "sets" to Global to fix this?
            Core 2026.5.0
              @gwp1 said in Reactor Ex Machina:
              Not all, just the ones that referred to from other rules.
              R 1 Reply Last reply
                retireditguy
                Working on migrating off of Vera. I am also trying to use Reactor Ex Machina and wonder whether the changes you referenced above might also keep REM from shutting down properly. REM toggles the lights off and on up until the expiration of the active period. REM ends without turning all of the lights off. The construct I am wondering about is - {{ each light in REM_Lights: performAction( light, 'power_switch.off' , { } 😞 0 }}
                I assume this is supposed to turn all of the lights in the array. I modified the "code" to handle the local/global variable change by moving cycler_stim to Global , but otherwise my REM is as it was after you modified "Deactivate REM' back on May 28, 2021. Any ideas?
                https://smarthome.community/topic/557/solved-random-ghosting-of-lights-when-away/32?_=1677904265383
                  retireditguy
                  wrote on last edited by retireditguy
                  The Board changed ) : to an emoticon.
                    retireditguy
                    • R retireditguy
                      @retireditguy Here are my rulesets and it works just fine.
                      Core 2026.5.0
                        retireditguy
                        Except for the values defining the active time in "Active Period", our scripts are identical. Additionally we are both controlling Hubitat systems. My testing seems to indicate that REM only shuts off one light at the end of the defined period. I believe it was the last one turned on. Are you sure that REM turns off all of your lights at the end of the defined period? I suspect there may be something wrong with the execution of the statement {{ each light in REM_Lights: performAction( light, 'power_switch.off' , { } ) : 0 }} as I noted above. Another "anomaly" occurs at start-up. The 3 scripts together are sensitive to the start sequence. If "Cycler" is started before both "Active Period" and "Deactivated", "Cycler" will trigger as soon as either starts since they both change cycler_stim.
                        • R retireditguy
                          @retireditguy said in Reactor Ex Machina:
                          The expression you show is incorrect -- where you have a colon (:) at the end of the each subexpression (after the closing paren of performAction()) should be a semicolon (;), like this:
                          ${{ each light in REM_lights: performAction( light, 'power_switch.off', {} ); 0 }}
                            @toggledbits Not gonna lie, you made me go squint at mine just to be sure.
                            Core 2026.5.0
                            • K Offline
                              K Offline
                              kellyjelly32
                              wrote on last edited by kellyjelly32
                              If anyone is interested, I will copy/paste my code here for my solution. It builds on the initial "Reactor Ex Machina" from 2021 but incorporates the changes made to MSR since then. I also modified it in such a way to have the OFF switching done individually for each light with definable delays. A bathroom light that way can go OFF after a random 1-5m while the kitchen stays on for longer for example. I made some other changes as well to suit my needs. It works for me, it might not for you.
                              You need four "Global Expressions":
                              • REM_lights
                              #list of all DeusExMachina (now ReactorExMachina REM) lights to control
                              #this is an array [ ]
                              #every entity in ' ' (apostrophes) separated by , (comma) in new line
                              #check entity list to get canonical ID to be used
                              #comments start with hash and are ignored
                              'hass>input_boolean_testlight', #Test
                              'hass>input_boolean_testlight2', #test2
                              'hass>input_boolean_testlight3', #Stephan
                              'hass>input_boolean_testlight4', #Stephan
                              'hass>input_boolean_testlight5', #Stephan
                              'hass>input_boolean_testlight5' #Stephan
                              • REM_dummy (leave empty)
                              • REM_cycler_stimulus (leave empty)
                              • REM_status (leave empty)
                              If you want a light to be more frequently "ghosted" add it multiple times into the list. In my case light5. If you are on HA, you can add via the helper section some virtual toggles as I did to test your setup. Probably also possible on other platforms.
                              My rules are like this:
                              Start & Stop rule (via set/reset reaction), the ghost switching on the lights and then for each light a ghost which switches off so I can manage the individual behavior per light.
                              The Start&Stop rule:
                              47c893f8-0bdd-4829-b906-64a227863fef-image.png ab665d14-6b87-4236-9dee-a6cce644e73d-image.png
                              The reset code bit, hard to read/copy from screenshot:
                              The ghost for switching ON a random element/light from the list:
                              b0a190e8-62b0-4ed9-aa55-08485dee378a-image.png 340d6e2f-0eba-48f5-a19d-4bf6590ef812-image.png
                              Code:
                              ${{ performAction( REM_lights[ floor( random() * len( REM_lights ) ) ], 'toggle.toggle', {} ) }}
                              ${{ random()*600 + 600 }}
                              ${{ REM_cycler_stimulus + 1 }}
                              The light-specific OFF ghost:
                              ${{ random()*600 + 300 }}
                              Some explanation for random function and the values used with it. It randomly generates number between 0 and 1 (example: 0.4739302) The delay time is in seconds. So the above example will create a delay of 300s minimum plus anything between 0 to 10m, effectively a random time of 5m-15m. See what works for you.
                              This REM is working well for me and I am now finally ready to migrate it all to HA after many years on my trusty Vera Lite which is about to die of flash memory degradation.
                              3 1 Reply Last reply
                              • 3 Offline
                                3 Offline
                                Ahh... I miss that app. Probably one of my favorites from my Vera days. The "Lighting Director" app on Hubitat just isn't the same.
                                Thanks for posting your setup @kellyjelly32. I've mocked this into my MSR and if all works well, DeusExMachina returns. Well kinda
                                • K kellyjelly32
                                  • REM_lights
                                  Code:
                                  3 Offline
                                  3 Offline
                                  @kellyjelly32 Is there a way to specify how many lights should be on at one time? I tested REM last night and the most on at the same time appeared to be two. I'm fine with this, but curious if there was an option or way to adjust it. Again, thanks for sharing your logic.
                                  • K Offline
                                    K Offline
                                    kellyjelly32
                                    My REM "Switch ON Ghost" is using the "toggle" action. This means it can also switch a light off if the one chosen randomly is (still) on. Change that to power_switch.on and it can only switch lights ON. This will at least prevent the "ON Ghost" from turning/toggling lights OFF. Then it all comes down the the times used to in the random() functions between the "ON Ghost" toggles/switches lights ON and the "OFF Ghosts" switching lights OFF.
                                    Probably the introduction of another variable like REM_active_lights which is increased every time the "ON Ghost" switches something ON and decreased when the "OFF Ghost xyz" turns it off, you can track how many lights are ON. Add a AND trigger in the "On Ghost" that states "REM_Active_lights" equal/smaller than "4" and you can make sure that no more than four lights will be on at any time.
                                    Probably you need to somehow force the MSR to re-evaluate the "Ghost ON" conditions to start another cycle, once enough lights are out again. Maybe another "Ghost" to keep track of the REM_Active_lights, when below 4 to count the REM_cycler_stimulus up to re-start the ON Ghost.
                                    I will see if I can get it to work...
                                    • 3 Offline
                                      3 Offline
                                      I'm not in need of it. As I was moving off Lighting Director I just happened to notice they had a max number of lights. I think the OG DeusExMachina did too. I think how you have it would be more lifelike. Especially when you couple of a few specific OFF rules so the lights turn off faster than 10-20 minutes.
                                        101.0k
                                      • Next Release?
