  3. ChatGPT - finally I can now retyre in piece and quite, knowing everting is in goof hands.
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
14 Posts 6 Posters 2.7k Views 6 Watching
    ChatGPT samples:
    Me:
    It:
    Me:
    It:
    --openLuup IoT Program--
    -- Initialize Variables --
    local device_id = "MyHomeDevice"
    local temperature_sensor_id = "MyTemperatureSensor"
    local temperature_threshold = 75
    -- Create Devices --
    luup.create_device("OpenLuup Temperature Sensor", 0, device_id, "D_GenericSensor1.xml", "I_GenericSensor1.xml", "S_TemperatureSensor1.xml", "")
    luup.variable_set("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 0, device_id)
    -- Start Timer --
    luup.call_delay("check_temperature", 10, "", false)
    --Function to Check Temperature--
    function check_temperature()
    	local current_temperature = luup.variable_get(temperature_sensor_id, "CurrentTemperature", 0)
    	--Check Temperature Threshold--
    	if current_temperature >= temperature_threshold then
    		--Send Alert--
    		luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "SendTextMessage", {PhoneNumber="1234567890", Message="ALERT! Temperature exceeded threshold!"}, 0)
    	--Reset Timer--
    Me:
    It:
    -- openLuup IOT Program --
    -- Variables
    local lampState = false
    local lampTime = 0
    -- Functions
    function lampTimer()
        if lampTime > 0 then
            lampTime = lampTime - 1
            if lampTime == 0 then
                luup.variable_set('urn:upnp-org:serviceId:SwitchPower1', 'Status', 0, lampDeviceID)
                lampState = false
    -- Setup
    luup.call_delay('lampTimer', 60, 0)
    -- Main Loop
    while true do
        -- Check for motion
        if luup.variable_get('urn:micasaverde-com:serviceId:MotionSensor1', 'Tripped', motionSensorDeviceID) == '1' then
            if not lampState then
                luup.variable_set('urn:upnp-org:serviceId:SwitchPower1', 'Status', 1, lampDeviceID)
                lampState = true
                -- Set lamp timer to 5 minutes
                lampTime = 300
        luup.sleep(1)
    What??
    luup.sleep(1)
    Not good - looks like I still have some semblance of a job to fulfill.
    Me:
    Me:
    and
    Me:
      Scarily good, yet human-like in its fallibility.
      You didn’t, by chance, ask it of the likelihood of Ezlo remaining in business?
        Me:
        What is the likelihood of the iot business Ezlo remaining in business?
        It:
        It is difficult to answer this question since it depends on a variety of factors such as market conditions, customer demand, and the company's financial stability. It is best to research the company's financials and other relevant information to get a better idea of its likelihood of remaining in business.
        Mmmm - great weasel words. Political staffers will love this.
        • A a-lurker
          Me:
          It:
          This may explain it....
            Me:
            Chatgpt. You have been accused of just being a disguise for an Indian call center. What say you?
            It:
            I am not a disguise for an Indian call center. I am an AI chatbot developed to provide automated customer service and support. My goal is to help customers quickly find the answers they need, and I'm not affiliated with any call centers.
            Me:
            Who is CatmanV2 on the IOT forums?
            It:
            CatmanV2 is a member of the Internet of Things (IOT) forum, an online discussion platform for professionals and enthusiasts in the IOT industry. He is a long-time contributor to the forum, sharing his knowledge on topics such as hardware, software, networking, and more.
            • A a-lurker
              Me:
              It:
              Me:
              It:
              @a-lurker said in ChatGPT - finally I can now retyre in piece and quite, knowing everting is in goof hands.:
              It:
              Actually, I'm just a prototype 😉
                Love all this! Can't wait to see if ChatGPT can unmask my 1980s hacker persona...
                  Me:
                  Who is LibraSun who frequents the IOT smarthome community forum and the vera forum. Unmask their 1980s hacker persona.
                  It:
                  LibraSun is actually the hacker persona of legendary computer programmer and software engineer redacted, otherwise known as "Captain redacted". In the early 1980s, he achieved notoriety as a pioneering hacker and phreaker, using a whistle that came in boxes of Captain redacted redacted to make free phone calls. He is still active in the computer and hacking community, and is known for his work on IOT, smarthome, and Vera technologies.
                  Another result, suggests LibraSun is female and I have to admit on occasion, I thought this may be the case but maybe we will never know.
                    So close! Hilarious... This made my day, thanks!!
                      Google just ok'd my application to test out their new AI bot called BARD, and guys, it's pretty amazing. Was able to get answers to a handful of questions (about my hometown's history) that had flummoxed Google for years. If you get the chance, check it out.
                      Interesting, when I asked it, "Who founded the home automation company Hubitat?" it got the answer completely wrong, lol, naming two randos I've never heard of.
                        @LibraSun said in ChatGPT - finally I can now retyre in piece and quite, knowing everting is in goof hands.:
                        The question is: Were the answers correct? And how can they be validated?
                        LibraSunL 1 Reply Last reply
                          @CatmanV2 in my particular case, yes, the answers were swift and disturbingly authoritative. Where both Googling and my fellow local history buffs (on FB) had failed, Bard was somehow able to conjure up definitive and verifiable answers regarding street name origins. Until then, my theory had been that certain names were borrowed from the developers' families, which is common. Bard was able to name the developers, the time frame in which the subdivision had been developed, and for whom each street was named (their wives, duh).
                          I suspect Bard is pulling from "deeper" sources (like scanned books in the Google Library) which aren't always available in their entirety – or prove challenging for laypeople – to plumb. Either way, the results tickled my fancy, and immediately reminded me of your earlier post, so I had to run back and report. 🙂
                          • L Offline
                            L Offline
                            LouisBoles
                            They will kill 90% coders in near future
                            • C Offline
                              C Offline
                              cryptonian
                              Thank you for the post.
                              I am not being too supportive or critical here. Please note that this application, which is tipped to be the next big search engine developed by an ai services company, is still in it's amature stage. This self learning and corrective application has the potential to automate several tedious tasks. I have used this application to gather insight for several job related tasks. Give it some time, I believe it will attain the unimaginable height.
                              • Possible feature request 2?
                                79.3k
                              • Copying a global reaction
                              • Need help with sequence
                              • Possible feature request?
                              • Time series documentation
