  3. Vera/openLuup plugins
  4. RulesEngine
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
B
B
Broadlink setup
Virtual Sensor Polling
B
Z
RulesEngine
32 Posts 3 Posters 16.9k Views 3 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    what's the module to install under debian/ubuntu ?
      If it was working for you, then you must have the module, and you won’t get this error message.
      • DesTD Offline
        DesTD Offline
        DesT
        @akbooer any luck finding something ?
        • DesTD Offline
          DesTD Offline
          DesT
          I was trying to check using openLuup console and I got an error 500 when accessing /openLuup
            I’m really struggling with the graphic interface… can’t seem to make any logic bits stick together, so nothing to try to save. Save button is always red.
            What were you doing to get a 500 error?
            DesTD 1 Reply Last reply
              Ah , I forgot the missing module. I would need to configure a system which does have lxp and then try again.
                DesTD Offline
                DesTD Offline
                DesT
                @akbooer said in RulesEngine:
                Just going to http://IP:3480/openLuup
                  Are you sure? Looking at the server code, the only reason I can see for a 500 error is an invalid request, in which case the error should include reference to which request ID it saw.
                  I’ve seen this happen sometimes when testing and I’ve refreshed a browser page from a previously incorrect request.
                  Re type the URL in the browser and try again?
                  Anything in the log??
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    2023-07-30 08:15:52.777   openLuup.server:: GET /openLuup HTTP/1.1 tcp{client}: 0x42d21578
                    2023-07-30 08:15:52.777   openLuup.wsapi:: using openLuup/console.lua for openLuup
                    2023-07-30 08:15:52.777   openLuup.wsapi:: using REQUIRE to load CGI openLuup/console.lua
                    2023-07-30 08:15:52.778   openLuup.wsapi:: can't find WSAPI application entry point
                      Helpful, thanks. That’s something for me to get my teeth into…
                        Any other errors in the startup log, or since startup in the main log?
                          @DesT
                          I did an install of the latest openLuup from the development branch (v23.3.21) and semm to have no problem accessing the console page. Will try again, now, to install the lxp module and fire up the RulesEngine...
                            #23
                            On the RulesEngine saving issue...
                            I've been seeing this error in the browser console:
                            POST
                            http://172.16.42.10:49162/cgi-bin/cmh/upload_upnp_file.sh
                            404 Not Found
                            ...and I found that the file was missing from my installation (which I had done manually, because the AltAppStore configuration doesn't handle the GitHub structure of the repository.)
                            Do you have the folders and file (within the openLuup home folder) ?
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              yes I have the file and it contain:
                              #!/usr/bin/env wsapi.cgi
                              module(..., package.seeall)
                              -- @vosmont's implementation of /cgi-bin/cmh/upload_upnp_file.sh
                              -- converted to WSAPI application by @akbooer
                              -- see: http://keplerproject.github.io/wsapi/manual.html
                              -- 2016.02.18  extract vosmont's modification from openLuup.server and make into WSAPI app
                              local _log    -- defined from WSAPI environment as error.write(...) in run() method.
                              -- create the file
                              local function upload_file (URL)
                                local file, status, result
                                local path = "" -- should use a specific folder for security reason ?
                                local fileName, fileContent = URL.upnp_file_1_name, URL.upnp_file_1
                                if fileName and fileContent then
                                  file = io.open(path .. fileName, "w")
                                fileName = fileName or '?'
                                if (file == nil) then
                                  _log ("File '" .. path .. fileName .. "' cannot be created")
                                   result = "KO"
                                   status = 400   -- Bad Request.
                                else
                                  file:write(fileContent)
                                  file:close()
                                  _log ("File '" .. path .. fileName .. "' has been written")
                                  result = "OK"
                                  status = 201    -- Created. The request has been fulfilled and resulted in a new resource being created
                                return status, result .. "|" .. fileName, "text/html"
                              -- gets headers in multipart content
                              local function read_part_headers (content, pos)
                                      local EOH = "\r\n\r\n"
                                      local i, j = string.find(content, EOH, pos, true)
                                      if i then
                                              local header_data = string.sub(content, pos, j - 1)
                                              local headers = {}
                                              for type, val in string.gmatch(header_data, '([^%c%s:]+):%s+([^\n]+)') do
                                                      headers[type] = val
                                              return headers, j + 1
                                      else
                                              return nil, pos
                              -- gets fields in multipart headers
                              local function get_field_names(headers)
                                      local disp_header = headers["Content-Disposition"] or ""
                                      local attrs = {}
                                      for attr, val in string.gmatch(disp_header, ';%s*([^%s=]+)="(.-)"') do
                                              attrs[attr] = val
                                      return attrs.name, attrs.filename and string.match(attrs.filename, "[/\\]?([^/\\]+)$")
                              -- gets the data in multipart content
                              local function read_field_content(content, boundary, pos)
                                      local i, j = string.find(content, "\r\n" .. boundary, pos, true)
                                      if i then
                                              return string.sub(content, pos, i - 1), j + 1
                                      else
                                              return nil, pos
                              -- global entry point called by WSAPI connector
                              The environment is a Lua table containing the CGI metavariables (at minimum the RFC3875 ones) plus any
                              server-specific metainformation. It also contains an input field, a stream for the request's data,
                              and an error field, a stream for the server's error log.
                              The input field answers to the read([n]) method [AKB: NOT YET IMPELMENTED],
                              where n is the number of bytes you want to read
                              (or nil if you want the whole input[AKB: THIS IS IMPLEMENTED]).
                              The error field answers to the write(...) method.
                              return values: the HTTP status code, a table with headers, and the output iterator.
                              function run (wsapi_env)
                                _log = wsapi_env.error.write     -- set up the log output
                                      -- vosmont : add upload file management
                                -- inspired from https://github.com/keplerproject/wsapi
                                local URL = {}
                                -- get POST content,
                                local post_content = wsapi_env.input.read()
                                local content_type = wsapi_env["CONTENT_TYPE"]
                                -- get uploaded file
                                if string.find(content_type, "multipart/form-data", 1, true) then
                                  local boundary = "--" .. string.match(content_type, "boundary%=(.-)$")
                                  -- get all the parts
                                  local pos = 1
                                  local _, part_headers, name, value
                                  _, pos = string.find(post_content, boundary, 1, true)
                                  pos = pos + 1
                                  part_headers, pos = read_part_headers(post_content, pos)
                                  while (part_headers) do
                                    --_log ("HTTP POST request multipart headers : " .. json.encode(part_headers))
                                    name, _ = get_field_names(part_headers) -- do not use "file_name" in Vera implementation of uploading files
                                    value, pos = read_field_content(post_content, boundary, pos)
                                    URL[name] = value
                                    -- prepare next multipart scan
                                --_log ("HTTP POST request content : " .. post_content)
                                --_log ("HTTP POST request content : " .. json.encode(URL))
                                local status, return_content, return_content_type = upload_file (URL)
                                local headers = {["Content-Type"] = return_content_type}
                                local function iterator ()     -- one-shot iterator, returns content, then nil
                                  local x = return_content
                                  return_content = nil
                                  return x
                                return status, headers, iterator
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                @akbooer had some time to find something? 😉
                                  Been away for a couple of weeks. That missing file was the last thing I tried. Will get back to it now!
                                    So I've got this far. What so I do now...?
                                    • DesTD Offline
                                      DesTD Offline
                                      DesT
                                      You can try to create a basic rule like that:
                                      than try to save it!
                                      • DesTD Offline
                                        DesTD Offline
                                        DesT
                                        You should see the rule in the list after but you will not be able to edit it or see it!
                                        Clicking on the pen will bring the EDIT window BUT you should see nothing as the rule is not saved properly.
                                        Clicking on the big icon on the left, should bring the "view" and should see nothing also as the rule is not saved properly
                                          I see these errors in the bowser console when constructing the rule:
                                          When saving, I get from the openLuup log:
                                          2023-09-20 15:00:49.723   openLuup.server:: POST /cgi-bin/cmh/upload_upnp_file.sh HTTP/1.1 tcp{client}: 0x55edaf542828
                                          2023-09-20 15:00:49.758   openLuup.wsapi.cgi:: /cgi-bin/cmh/upload_upnp_file.sh : File 'C_RulesEngine_Rules.xml' has been written
                                          2023-09-20 15:00:49.758   openLuup.server:: request completed (124 bytes, 0 chunks, 34 ms) tcp{client}: 0x55edaf542828
                                          2023-09-20 15:00:49.767   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=5&serviceId=urn:upnp-org:serviceId:RulesEngine1&action=LoadRules&fileName=C_RulesEngine_Rules.xml&ruleIdx=1 HTTP/1.1 tcp{client}: 0x55edaf542828
                                          2023-09-20 15:00:49.768   luup.call_action:: 5.urn:upnp-org:serviceId:RulesEngine1.LoadRules
                                          2023-09-20 15:00:49.768   openLuup.server:: request completed (62 bytes, 1 chunks, 0 ms) tcp{client}: 0x55edaf542828
                                          2023-09-20 15:00:49.768   openLuup.context_switch::  ERROR: [dev #5] [string "I_RulesEngine1.xml"]:25: attempt to index field 'RulesFile' (a nil value)
                                          2023-09-20 15:00:49.768   openLuup.scheduler:: job aborted : [string "I_RulesEngine1.xml"]:25: attempt to index field 'RulesFile' (a nil value)
                                          2023-09-20 15:00:49.771   openLuup.server:: GET /data_request?id=lr_RulesEngine&command=getRulesInfos&output_format=json HTTP/1.1 tcp{client}: 0x55edaf542828
                                          2023-09-20 15:00:49.771   openLuup.server:: request completed (31 bytes, 1 chunks, 0 ms) tcp{client}: 0x55edaf542828
                                          So it's not clear what's going wrong here. There are some 5,400 lines of Lua, and 1,950 of Javascript to look through...
                                            152.5k
