  4. MSR SMTP Notifications fail - <wsapi:CRIT> Error: Engine has not been started
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 2 Posters 1.4k Views 2 Watching
  • B Offline
    B Offline
    basai
    MSR Version: latest-23218
    Running as Docker Container : Docker version 24.0.5, build ced0996
    OS: Linux 15BPMSR1 6.1.26-05272-g26c406245a2c #1 SMP PREEMPT_DYNAMIC Thu Apr 27 10:15:40 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
    SMTP notifications had been working fine and I am unsure exactly what action(s) stopped it from working.
    I have verified that the SMTP server configured in notifications.yml is working properly.
    To duplicate the problem I am forcing an SMTP email notification using the set reaction play button, the reactor.log shows the following errors:
    [latest-23218]2023-08-21T14:23:22.462Z <wsapi:ERR> [WSAPI]wsapi#1 can't queue reaction rule-lgxmrba4:S: [Error] Engine has not been started [-]
    [latest-23218]2023-08-21T14:23:22.463Z <wsapi:CRIT> Error: Engine has not been started [-]
        at Engine.queueReaction (/opt/reactor/server/lib/Engine.js:1494:46)
        at WSAPI.clientMessage (/opt/reactor/server/wsapi/wsapi.js:782:64)
        at WebSocket.<anonymous> (/opt/reactor/server/wsapi/wsapi.js:301:157)
        at WebSocket.emit (node:events:527:28)
        at WebSocket.emit (node:domain:475:12)
        at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1068:20)
        at Receiver.emit (node:events:527:28)
        at Receiver.emit (node:domain:475:12)
        at Receiver.dataMessage (/opt/reactor/node_modules/ws/lib/receiver.js:517:14)
        at Receiver.getData (/opt/reactor/node_modules/ws/lib/receiver.js:435:17)
    I have tried:
    OS level: apt udate and apt upgrade and reboot
    docker pull toggledbits/reactor:latest-aarch64
    latest-aarch64: Pulling from toggledbits/reactor
    Digest: sha256:d8a019d457c9fef61f7c3e6908db1f1d0a2d14b6f7c5e9d4fc536c791503d152
    Status: Image is up to date for toggledbits/reactor:latest-aarch64
    docker.io/toggledbits/reactor:latest-aarch64
    docker stop reactor
    docker start reactor
    docker compose down
    docker compose up -d
    To no avail.
    I feel like I'm missing something obvious but can't put my finger on it.
    Thank you in advance for any guidance.
    -bh
      Your Engine didn't start. Maybe other recent config changes? Look earlier in the log file, at the startup, for additional messages.
      • B Offline
        B Offline
        basai
        wrote on last edited by basai
        Thanks for the input.
        I'm not sure if deleting this zero length file was the right thing to do or not but it fixed the problem, the engine starts now and SMTP works.
        From the log:
        [latest-23218]2023-08-21T20:55:09.695Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/var/reactor/storage/states] failed to read cs-rule-lbhys108 in /var/reactor/storage/states/cs-rule-lbhys108.json:
        So basically the file /var/reactor/storage/states/cs-rule-lbhys108.json had a file length of "0"
        -rwx------ 1 501 staff 0 Jul 20 02:00 cs-rule-lbhys108.json
        I moved the file in question to a tmp directory, restarted reactor, the engine started and SMTP works now.
        Question:
        Was moving / effectively deleting this file from reactors view a bad thing to do that will cause future problems and is there anything else that need to do other than getting rid of that zero length file?
        Thanks,
        -bh
          Removing the file is fine. It's just a state file used to preserve the rule state across restarts. These are most often corrupted by disk-full conditions, so you might check your disk space.
          • B Offline
            B Offline
            basai
            That was likely it now that you mention it. I did have a problem awhile back where I fat fingered a 2:00AM cron job that was supposed to trim backup files to only keep the last x days of *.tar.gz files which filled the partition. I bet the file date reflects when that happened 🙂
            Thanks again for the help and clarifying. Take care,
            -bh
              163.7k
