  3. Forum sysops
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
Forum sysops
6 Posts 3 Posters 4.7k Views 3 Watching
    1. The chat is not currently usable, as the scrolling is all not right and it's not possible to read chats or send chats reliably.
    2. There are a lot of female members that should perhaps be on another forum; where they can advertise their skills more appropriately. Note: I agree it's a job, like any other.
    • DesTD Offline
      DesTD Offline
      DesT
      @a-lurker can you elaborate on the female members? 😉
      About the chat, I know, @akbooer told me that this week!
        Those female members have been banned, and caught before they can post, but I don't have the authority to actually delete their accounts.
        • DesTD Offline
          DesTD Offline
          DesT
          For the chat... found it
          Just go under your profile, then theme settings and enable the last checkbox 😉
            Great - thanks - that fixed it for me.
              Yup, that works. Thanks.
              • A a-lurker referenced this topic on
              • Oh the joy of pairing
              • HDMI oddness
                668
                sethlampman
              • Date/time condition
