  3. VeraAlexa icon
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
VeraAlexa icon
7 Posts 2 Posters 1.4k Views 2 Watching
    Morning
    The original D_ComboDevice1.json file lists the icon for VeraAlexa as zwave_default.png
    I've modified this to be alexa.png, checked that alexa.png exists in /etc/cmh-ludl/files. Checked it's the right size.
    Restarted Openluup
    Cleared all downloaded images.
    Force refreshed
    Checked the other browsers.
    It still shows zwave_default. Any ideas?
    Cheers
      OK if anyone else hits this, it needs to be in icons, not files.
      Cheers
        I've not changed the icon, even if it's ready, because I've always intended this as temporary. Maybe I'll just pull the trigger and provide a proper device file + icon, since the icon is already there 😄
          That's because D_ComboDevice1.json is in fact a standard device file 😉
            @therealdb Yeah I figured that, but I can't see anything else on my system using it. I assume (and we know my track record at that) that it would be simple enough to rename it something like D_AlexaDevice1.json and change the Attributes?
            Cheers
              Yes, that’s the plan!
                @therealdb great stuff!
                  124.6k
