  3. Expression Evaluation - Last Seen Date/Time
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
6 Posts 3 Posters 2.4k Views 3 Watching
    sidmsmith
    wrote on last edited by sidmsmith
    I am trying to run a reaction that turns on lights if a sensor has not been tripped for 2 minutes. Basically, when a garage door is open, turn on inside lights if nothing has been sensed for 2 minutes. My question has to do with the expression/variable for "Last Seen". The variable never gets updated over time since the last seen event never changes.
    In the screenshot above, the reaction checks for any garage door as well as the variable called "GarageLastEntry". The expression for this variable is displayed below:
    The problem that I am experiencing is that the variable never changes over time. I understand that this is because the "last seen" variable does not change over time when there is no activity. In this screenshot, the value shows 0.029... This can also be seen as the current value in the original reaction screenshot above. After 10 minutes, this value should be 10. However, when a garage door is opened, the variable does not get updated and thus the rule does not become true since .029 is less than 2.
    When I go to the variable and click on the > icon, the variable then gets updated as expected as seen below:
    So the ultimate question is, how do I use a rule that can use a variable such as "last seen"? Do I need to create another variable or reaction that multiplies this by 1 every minute? From what I read in the manual, a variable is evaluated every time it is included in a reaction. But this is not what I am seeing.
    I also want to ask another question related to this variable. It seems like Reactor continuously deletes this variable and I have to keep recreating it? I have never experienced this with MSR so wanted to ask if this is a common problem or if my definition is causing this.
    Any info is appreciated!!!
      I usually use metadata to accomplish the same:
      e = getEntity( "virtual>house_mode" ),
      e.attributes.string_sensor.value == "away" ? ( time() - e.attribute_meta.string_sensor.value.last_modified ) > 64800 : false
      Change attributes and timeouts (in seconds) accordingly.
      YMMV.
      S 1 Reply Last reply
        YMMV.
        sidmsmith
        @therealdb Thanks for your feedback!
        I have not used a metadata statement like this before so have a follow up. I think I have the proper data elements. But is this statement supposed to be part of the Expression definition or the Reaction Trigger? The screenshot below shows what I tried creating the expression.
        Sorry for the lack of understanding on my part! Is the goal to have the variable itself be true/false? Or is the goal to have the variable still provide a numeric result that is used in the reaction? I may just need a little more direction.
        Thanks again!
          sidmsmith
          I think I solved this with a completely different approach. Instead of using variables based on Last Seen, I am just checking the current state of the sensor and used the Restriction that the sensor must be FALSE (ie door closed) for 120 seconds. Not sure why I did not try this the first time.
          Since my Reaction is now working, I should probably close this out as Solved. However, I am still interested in how to use a variable as described in the original post in case I need to use a similar approach in the future. Hopefully someone can provide some guidance (thanks realdb!) on how to use the variables. If I don't hear back within a few days, I will go ahead and update this as Solved.
          toggledbitsT therealdbT 2 Replies Last reply
          • S sidmsmith
            toggledbitsT Online
            toggledbitsT Online
            @sidmsmith said in Expression Evaluation - Last Seen Date/Time:
            This is the way.
            • S sidmsmith has marked this topic as solved on
            • S sidmsmith
              your solution is correct. This code will give you the ability to use it in notifications (ie: Door left open for 5 minutes) or when you want to do things programmatically (ie: house is away since 12 hours, do that, 18 hours, do this, etc).
                163.4k
