  3. New to Home Automation Looking for a Single app?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
7 Posts 5 Posters 3.6k Views 3 Watching
    Adrian_B
    Hi All
    Hopefully this place looks like a helpful forum as I’m quite new to all this!
    I’ve had a few devices all working separately /through their proprietary apps but we’re just finishing off a large house extension and this has added to the list.
    I’d ideally like to be able to view/switch a number of different devices on one screen/head end but have no idea where to start.
    The devices we have/will have shortly are as follows;
    Zigbee Smart Sockets
    Zigbee smart switches (for lights)
    Heatmiser Neo Underfloor Heating (this runs from a Samsung ASHP but that part is automatic)
    Samsung VRF air conditioning (currently using Smart Things App)
    Hive (2xLTHW heating circuits in the existing house and Hot Water)
    Ring (doorbell!)
    Hik Vision PoE CCTV
    We have lots of appliances (Neff N70) which we can control remotely but not too fussed about controlling those at the
    Moment)
    Any help/recommendations would be appreciated!
    Adrian
      Home Assistant will likely cover most of the devices, just not your Ring Doorbell
      • C Offline
        C Offline
        christian_fabre
        Ring doorbell is supported by Home Assistant.
        Ring
        Ring
        Instructions on integrating Ring.com devices with Home Assistant.
        PablaP 1 Reply Last reply
        • C christian_fabre
          Ring
          Ring
          @christian_fabre Yes, but unofficially and utilizing the cloud. Company's like Ring (Amazon) notoriously block third party use of their APIs at random, so what may work now will not be guaranteed to work in the future.
            @Pabla said in New to Home Automation Looking for a Single app?:
            Good reason for folks like us to not choose those products.
              Adrian_B
              Hi all
              Thanks for the recommend.
              Have purchased a device and now the fun of setting up and configuring!
              Adrian
              • A Adrian_B
                Hi all
                Adrian
                @Adrian_B "a device" - so you're gonna leave us all hanging?
                *Hubitat C-7 2.5.0.143
                Core 2026.5.3
                MSR: latest-26143-a81ae8ba
                  107.2k
                • Integrations and 'Loaded'
