  3. Lights switches for warehouse
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
6 Posts 4 Posters 1.9k Views 4 Watching
    sammybizz
    wrote on last edited by sammybizz
    I need to replace about 15 traditional wall light switches (no neutral wire) to turn on/off all lights with one operation inside the warehouse. And still maintain the ability to control each light individually.
    The preference is not to set up a Wifi for each switch to reduce the number of devices connected to the network, and also, they change the Wifi password regularly, so they do not want to change all 15 switches.
    I am looking for some solution that will achieve this with either Bluetooth/RF or any other technology.
    The warehouse dimensions are about 100ftx100ft with sheetrock walls.
    Please assist.
      Z wave and Zigbee switches are good starting place. They dont use wifi, but will require some sort of controller (think a router but for the switches) to connect the switches too and control them
      • Tom_DT Offline
        Tom_DT Offline
        Tom_D
        Switches that don't use a neutral are dimmers that keep the switch powered but dim the lights to "off". If the lights are dimmable then this type of switch would work.
        latest-25082-3c348de6
          sammybizz
          Thank you
          Which controller is needed for Z-wave and Zigbee
          Can you point me at a link or something?
          PablaP 1 Reply Last reply
            Hubitat Elevation is one option (has both z-wave & zigbee)
            • S sammybizz
              Thank you
              @sammybizz there are quite a few options out there, best to look into what suits your needs best
                123.2k
