  4. [Solved] Runtime error when exiting global reaction that contains a group
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
7 Posts 3 Posters 1.5k Views 3 Watching
  • S Online
    S Online
    I am getting a Runtime error on different browsers when I click exit when editing an existing or creating a new global reaction containing a group. If the global reaction does not have a group I don't get an error. I see a similar post on the forum about a Runtime Error when creating reactions but started a new thread as that appears to be solved.
    The Runtime Error is different in the two browsers
    Safari v18.3
    @http://192.168.10.21:8111/reactor/en-US/lib/js/reaction-list.js:171:44
    You may report this error, but do not screen shot it. Copy-paste the complete text. Remember to include a description of the operation you were performing in as much detail as possible. Report using the Reactor Bug Tracker (in your left navigation) or at the SmartHome Community.
    Google Chrome 133.0.6943.142
    TypeError: self.editor.isModified is not a function
        at HTMLButtonElement.<anonymous> (http://192.168.10.21:8111/reactor/en-US/lib/js/reaction-list.js:171:34)
    Steps to reproduce:
    Click the pencil to edit a global reaction with a group.
    Click the Exit button.
    Runtime error appears.
    or
    Click Create Reaction
    Click Add Action
    Select Group
    Add Condition such as Entity Attribute.
    Add an Action.
    Click Save
    Click Exit
    I don’t know how long the error has been there as I haven’t edited the global reaction in a long time.
    Reactor (Multi-hub) latest-25060-f32eaa46
    Docker
    Mac OS: 15.3.1
      OK. For now, just create it in Global Reactions, then move the list to the Rule Set, if that issue is getting in your way. I'll have an update over the weekend.
      • S Online
        S Online
        No hurry sir, Just reporting.
          Oh, and the exit error part, while alarming, should be harmless. I think I've finally got the real root cause on that as well.
            @toggledbits not that you need it but I can confirm this behaviour.
            *Hubitat C-7 2.4.3.171
            *HASS 2025.12.2
            MSR: latest-25328-b2ed1365
            • S Online
              S Online
              Fixed in Reactor build 25067.
              Thank You!
              • S SweetGenius
                Thank You!
                @toggledbits Confirmed.
                *HASS 2025.12.2
                • Single protocol?
                • HDMI oddness
                • Oh the joy of pairing
                  692
                  sethlampman
                • Date/time condition
