  3. Do you Matter?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
8 Posts 5 Posters 1.1k Views 5 Watching
      Not yet. Looking at it for HA, but had other things on as yet
        Well, that seems remarkably easy configuration…
        Just added a Shelly 2PM Gen4 (dual switch) to Apple Home. It just required me to scan the QR code from the Home app and wait a short while.
        No other configuration required initially. In particular, no need to set up IP addresses or anything.
        Subsequently, I did enable MQTT and openLuup picked up on it immediately (although as a generic Shelly device, because I haven’t included that as a recognised device, yet.)
        Control seems to work instantly from Apple Home app. Now need to link it to automation and other switches.
        So far, so good.
        • akbooerA akbooer marked this topic as a regular topic on
          Nah, I've decided to stick with tried-and-true ZW stuff for the long haul. The older I get, the less I become a leading-edger (was never a bleeding-edger), though I honestly want Matter to succeed and fulfill its promise.
            I got a bad impression of Zwave from Vera, quite incorrectly. Should have stuck with it but actually dumped it. Mostly Shelly now, and its Gen 4 modules are Matter capable.
              I bought a new Sonoff device (ESP32) and flashed it with Tasmota v.15.3.0 and discovered it was possible to enable Matter (actually implemented in v.13.0).
              Tested it and as you say it was a very easy configuration. Having other thoughts about Matter now as there is no need for MQTT configuration in Homebridge, makes it a little bit smoother to add new devices.
              I still need to configure MQTT so Reactor picks it up though, @toggledbits any considerations of a MatterController?
                @Crille said in Do you Matter?:
                Absolutely. No idea on timing though, yet. Right now, I'm tied on an ESP-IDF project.
                  Speaking of Matter and older Shelly (Gen 1 & 2) I found Matterbridge, very similar to Homebridge, paired it to Apple Home and installed matterbridge-shelly and as easy as that all my devices showed up in the Home app. Might be something for you @akbooer .
                  Matterbridge offer other plugins like Zigbee2MQTT, Home Assistant and more, this makes me start thinking of moving away from Homebridge (and some MQTT) to Matterbridge and Matter, especially if a MatterController is eventually in the making.
                  Because I'm Swedish IKEA is very close by and super cheap on "Matter over Thread" devices and my HomePod mini act as a Thread Border Router, I can say Matter starts to grow on me 🙂
                    100.6k
                  • Next Release?
