Hey guys ... I've started creating a Docker container for Z-Way.
I was previously using the Razberry2 but found it a bit slow on my Raspberry Pi 3. I could upgrade to a Raspberry Pi 4 but since I already run a dedicated Linux server and many Docker containers I thought it might make more sense to run Z-Way on there.
GitHub: https://github.com/sofakng/docker-zway
DockerHub: https://hub.docker.com/repository/docker/sofakng/zway
This container is based on other containers that are no longer updated: (ruimarinho/docker-z-way) and (EugenMayer/docker-image-zway)
I'd love to hear feedback and any improvements that might be needed.
One thing I want to add immediately is to separate the configuration files from the Docker volume but it looks like Z-Way has several user configuration files/directories?
$ZWAY_DIR/config/Configuration.xml $ZWAY_DIR/config/Rules.xml $ZWAY_DIR/config/maps $ZWAY_DIR/config/zddx $ZWAY_DIR/automation/user_syscommands $ZWAY_DIR/automation/storage $ZWAY_DIR/automation/userModules $ZWAY_DIR/htdocs/smarthome/user $ZWAY_DIR/config.xmlNot 100% sure this is the best place, but this seems to be the sticking point.
Background: My NotVera system has been working perfectly now for some years. USB Z wave stick in an old Intel NUC.
The NUC has a bare metal install of Debian buster, and on that we have:
Z-wave Smart Home
OpenLuup
AltUI
MSR
Mosquito server
Home Automation Bridge.
I also have a bare metal Raspian install of Home Assistant running on a Pi
Due to my Buffalo Linkstation doing some odd stuff (like suddenly disconnecting, while maintaining everything was fine) I bit the bullet and bought a Synology DS224+
Now, given the age of my NUC I'm thinking that I should probably start thinking about how to replace / safeguard it. Pretty happy that I can make an image of the existing disk and drop it onto a virtual machine in the Synology, or re-install / restore or do some other things (not decided what yet) but I get stuck on the USB dongle.
Can I connect that to a VM on the NAS, or do I need another solution?
TIA
I have a Razberry v2 with firmware v5.04, and Bootloader v8aaa with CRC 35498 (I did manage to upgrade to this version using the "ZMESerialUpdater" tool ). I want to upgrade the firmware to v5.27, which Z-Wave.me Support say is the newest version that my hardware can handle without bricking it. Firmware v5.27 introduces the Analytics tab, according to Poltos, which is what I want.
I have been studying the firmware map (https://service.z-wave.me/expertui/uzb-stats/versions-graph.html?with_hidden) which I sort-of understand. I have also got the "ZMESerialUpdater" tool to do the update, and could use it if I knew which binaries to use.
My question is, what firmware update route do I use to get from v5.04 to v5.27? What exactly are the URLs of the binaries (as in "UPD_FIRMWARE_Razberry500_from_05_04_to_05_07.bin")?
Somewhat confused!
ScotsDon
Hi all, I hope someone could drive me in the right direction.
I was setting up a new zware environment using a UZB stick I bought about 2 yeasr ago and never used.
This stick was using firmware 5.27 that sounded to me a bit old.
So I looked on the process of upgrading the device and I downloaded the ZMESerialUpdater, the I went on the z-wave.me site and look for the firmware and I found (on this awfull map) the firmware UPD_FIRMWARE_UZB_STATIC_2ch_ZME_05_1b_04000001_ZME_05_24_04000001.bin (that AFAIK should upgrade from version 5.27 to 5.36).
I run the update and it never finished....
After 2 hours waiting for nothing, I finally CTRL-C and removed and reinserted the USB stick that is not recognized anymore.
I really think I won a nice peace of plastic usb shaped, but in case someone has an idea, I would be pleased to read your coment.
Regards
The expertUI of Z-way has a very interesting menu called analytics which I have not seen on any other controller.
My engineering curiosity and OCD tendency to want to optimize everything lead me to dig into it to see if I could get things working even better... even though nothing seem to be broken since my move from the UI firmware to z-way. So the background noise menu was of particular interest.
So here it is: This was my first shot of the starting block on the left side of this graph and you can see that at around 21:00 I did something to reduce the noise. My zwave.me uzb is connected to the vera through a usb extension cable and a usb hub but initially the vera and usb hub were sitting only a 6-7 inches (20cm) away from the uzb. Keep in mind the scale on both channels. What I did was to move the vera away from the uzb stick, to about 80cm but the big step was for me to use some metal leftover amazon gift card boxes I had from christmas and covered the usb hub with them. The step back up was me moving these macgyver shields around.
Next step is still goofing around with the shields to see if I could optimize further and while I initially made it worse, you can see that it got a little better later on. That USB hub is quite noisy.
After sometime, I just thought that the whole thing is just too sensitive any movement around that area could potentially cause problems. So I decided to remove the hub connected to the vera which really was just allowing to extroot the vera. Since I am no longer using the vera as a vera but only as a remote serial bridge, which doesn't write anything on its drive, I took it out. Again look closely at the scales. It did take the noise down another notch.
Now the stick is still sitting 14inch away from a UPS with a bunch of wall warts connected to it, powering a variety of devices like a hue 2 hub. I had the idea of replacing just the wall wart (AC-DC power supply) for the vera with a POE splitter. Since channel 2 is already hovering around the detection limit, I am only showing channel 1 here
This last step alone enable me to flip this other statistics menu:
It not only significantly decreased the CRC error rate but also made the foreign network impact greater that the CRC error bar negating the success on reception for the first time. When I took a zniffer to look into what these CRC error frames were, I discovered that they were all from my neighbor's network which is distant and have obviously poor signal strength. (Yes I can see his HomeId from the zniffer). The fact that I see less error means that my controller's range is greater. It is now able to recognize frames which are from my neighbor's instead of saying they are corrupted... Also The back off frames number decreased indicating less wasted/repeated frames on the network.
I have installed my UZB1 stick on my RP4 and want to megrate my device form my Vera to z-way. Now I want to use my Roller shutter 2 in z-way.mev as a scene controller. This is activated by 2x / 3x clicks on the switch. This works perfectly with vera (verabridge) in openluup and reactor using variable LastSceneID and LastScenetime.
Fibaro documentation:
When using z-way.me and z-way bridge it works differently. In reactor I see the variable below. I don't know how to use it. Maybe someone else can help me.
Lagging a little here but I just upgraded my z-way-server version and couldn't find much information on their website or even forum.
Z-Way buildsWhat is interesting for the ubuntu/debian version is that it is now released as a .deb package making upgrades much easier. I just downloaded the package and ran:
dpkg -i z-way-*.deband nothing else. The previous versions required some manual work since it was just a bunch of files for us to overwrite our installations.
From the release note, there could be interesting things for some folks here. It is a pretty long list compared to the previous incremental release.
For all systems backup is a vital part of the long-term usability.
I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all.
I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked.
The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages.
In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files.
From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras.
It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge?
In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop
By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups.
I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. 🙂
The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often.
//ArcherS
Have found these videos very informative as a zway(ve) novice ....
Z-Wave Network Diagnostics with Z-Way controller Z-Way webinar series: Z-Way Advanced Usage Z-Way webinar series: Introduction to Z-Way Home AutomationHave a number of TKB plug switches (TZ68) that are not reporting to the controller. Believe they should be associated to Z-Way in Group 1 but am not able to get the devices to report groups in the interview/call for NIF process and so there are no associations possible. Thermosat is telling them to come on/off (hurrah!) but they don't report their on/off status in the gui.
In Associations tab: Can not configure associations: groups were not reported by the device. Do interview.
(Solved - presume pijuice hat was upset battery wasn't connected. Took out the plastic protector and UZB now showing. Next - upgrade UZB firmware)
Have I missed something? UZB not showing up in Zway ...
Downloaded Raspberry Pi Imager and used to set up os (Buster) on an 8gb SD
Raspberry Pi Ltd Raspberry Pi OS – Raspberry Pi Raspberry Pi OS – Raspberry PiFrom industries large and small, to the kitchen table tinkerer, to the classroom coder, we make computing accessible and affordable for everybody.
Then installed Zway from Terminal
wget -q -O - https://storage.z-wave.me/RaspbianInstall | sudo bash
Plugged in UZB
Changed port to /dev/ttyACM0 in menu/apps/ZWave network access in basic UI
This arrived today - hope it has enough juice for the uzb.
52.79 GBP PiJuice HAT – A Portable Power Platform For Every Raspberry Pi PiJuice HAT – A Portable Power Platform For Every Raspberry PiDESCRIPTION RETIRED PRODUCT - We’ve stopped stocking this product or it has been retired by the manufacturer and is no longer for sale. This page remains available for its resources and as a source of potential interest. As one of the smallest systems around there are so many amazing things you...
Shame the cases are sold out everywhere.
Just upgraded to 3.1.0 and am happy to report that it has not impacted the z-way bridge for openLuup.
I am now seeing the SDK version for firmware 5.39
Does anyone know if the UZB supports Long Range already? I can't find which chip is in there.
Probably @rafale77 will jump on this question first 😉
I'm using the new model of GE/Jasco switch (they replaced the dead one I got) and the new model is having also S2 security and send instant status update BUT,
And probably @rafale77 will say yes, is it possible that interference can do that I'm missing some instant update status ?
Often, I'm having the wrong status in the zwave.me web interface...and even clicking the icon, the status didn't changed to right one.
I also try to do some "On/Off" using the web interface, and the device itself physically, toggle without a problem, but the web interface is still no correct.
I'm trying to monitor the indicator command class of a 5 button scene controller in Z-Way so openluup can properly create and track it.
seems like Z-Way COMMAND_CLASS_INDICATOR (0x87 or 135) are not being monitored by the ZWave module as I couldn't find anything for this command class in (/z-way-server-path/automation/modules/ZWave/index.js)
When a Get or Set Indicator command class request is sent to the controller. ZSniffer picks up the request and response just fine although this packets are not being monitored by the zwave module
Example:
the answer looks like:
[2020-04-24 19:59:36.261] [I] [zway] Waiting for job reply: Indicator Get [2020-04-24 19:59:36.281] [D] [zway] RECEIVED: ( 01 0B 00 04 00 02 03 87 03 01 B6 00 C2 ) [2020-04-24 19:59:36.281] [D] [zway] SENT ACKI’d like to store the Indicator response “RECEIVED” correctly. I believe by modifying the index.js of the zwave module could do the trick and once the module start tracking the indicator command class values as a metric then openluup's z-way plugin would properly track any changes as well.
I'm wondering if anyone around here could share any thoughts or comments that could make it easier...
Posting here, as the z-wave.me forum seems desolated..
I have two multisensor 6 sensors, and one of them is not sending motion sensor updates?
Looking at the configuration, they are both registered as battery sensors for som reason, even if they are USB powered. They respond quickly to parameter changes, except for parameter 100 and 110, that will not update.
Any clues? How do i convince the controller that they are USB powered?
First Post . . .
Good to "see" y'all here!
Last week, I purchased the Z-Wave.me UZB1 dongle and also purchased the Z-Way license.
Knowing in advance that the combination (Windows 10 and the Z-Way server) was lacking, I wanted to install anyway on a Windows 10 machine, and include a few spare z-wave devices to see how things worked. Pretty well, for the most part.
@rafale77 had written that the UZB stick works well in the RPi compared to the RaZberry card (which I also purchased but is still in it's packaging), I would like to plug this UZB1 into my Pi running openLuup/ALTUI (then hopefully installing the Z-Way plugin)
I'm not confident enough yet to plug the UZB into my Vera3 (UI5) and transfer my existing z-wave devices to the stick.
Without creating a new Buster image downloaded from Z-Way, could I possibly . . .
Plug the UZB1 into the Buster Pi3 From the terminal, run, wget -q -O - razberry.z-wave.me/install | sudo bashthen, if I can reach the :8083 port (as quoted by PoltoS) "go to Settings -> Apps -> Active -> ZWave and change /dev/ttyAMA0 to /dev/ttyACM0"
and expect that my UZB1 will now run on the Pi ?
If it is mostly that simple, would my license transfer?
Should I exclude the (3) z-wave devices I had running on the Windows 10 Z-Way server first?
If I'm oversimplifying, tell me to "shut up" and read some more! 😕
Thanks again,
DCMChrissy
So i just received a UZB stick from a US seller.
Part number ZMEUUZB1
Serial number 4.19.01
Firmware 5.27
Firmware update options:
5.27 => 5.36
5.27 => 5.23
Has anyone successfully updated the firmware on one of these or is it brick material? Any vendors with up-gradable sticks?Update: Tried to update from the GUI and it never recovered. No lights and will not detect.
Yep, our UZB is upgradable.Black Cat UZB Z-Wave Smart 6 Static controller
https://www.blackcatcontrolsystems.com.au/Black-Cat-UZB-Smart-6-Static-Z-Wave-ControllerUZB sometimes can be unbricked, I don;t have the link for this but Raf might remember where it resided.
FWIW, the ZWBCUZB might also be flashable to other frequencies, I've never tried it but the FW is available for other regions.
I got my stick from eBay I think but I think amazon one here should be upgradable. The non upgradable ones are more rare I think:
@rafale77
I have bricked two of them, Could I be doing something wrong when trying to upgrade the firmware? I am Using Z-way v3.0.6 GUI expert settings. Update firmware button, Putting "all" in the token field and click the button on update firmware 5.27 to 5.36. After the page reloads the the device is not accessible and no blue lights. It does not show up in the /dev folder any more. Reboot of the Pi does not help. -
Have you tried unplugging and plugging it back to power cycle the stick? I screwed up the firmware upload quite intensively on the last upgrade (>50x) due to some memory indexing issues and never managed to brick it. The process has it load the entire firmware image on the non volatile memory first and then after checking it is corruption free, it does the upgrade. I found it much more difficult to brick than say the vera firmware. The 3rd party vendor stick is unknown to me as I don't have one but I see some people struggling with upgrading those.
I am running on 5.39 at the moment... -
Yes, unplugged multiple times, The link you sent is the same vendor that I bought from directly. I have read your posts so that is why I thought I might be doing something wrong.
I looked at the CLI tool. Very confusing of the correct bootloaders and version of files. I thought the GUI would be safer.
True, it is a bit dissuasive at first... And the firmware map is kind of mind-blowing and takes some time to understand how it works. Well sorry you got these 3rd party buggers.
This I am pretty sure where I got mine from. I would recommend returning those amazon ones if you still can. -
Thanks for the info. Does your stick have a "true" serial number? Mine has the same serial number of other peoples that bricked on the z-way forum "04.19.01"
3rd UZB and it appeared to upgrade. (Via GUI) I upgraded from 5.27 to 5.36. Then upgraded to 5.36 to 5.39. @rafale77 , Since you are on 5.39, does your show anything in the SDK Version line? Mine did before the upgrade to 5.39.
On the firmware upgrade page it shows this now. But they do nothing.
Hi @rafale77 or any others in this coMmunity who might be able to help., I‘m looking to upgrade my UZB USB module, - which is plugged into to a USB hub on my PI - to the latest firmware..
Using the guide here..
https://z-wave.me/zmeserialupdater-manual/I’ve so far done the following..
wget https://z-wave.me/download/ZMESerialUpdater.tgz tar -zxvf ZMESerialUpdater.tgz cd ZMESerialUpdater/arm/ chmod +x ZMESerialUpdater
To be sure the software is working and also to check what FW I currently have - I ran the following command.
pi@raspberrypi:~/ZMESerialUpdater/arm $ sudo ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyACM0
Which gave me this...
Z-WAVE Serial API Tool Version:LWE0.9 by Z-WAVE>ME --> Device ready in:1.01568007469 seconds FULL INFO Openning port .............................. OK SERIAL INFO VERSION: 05 05 VENDOR: 01 15 ZME_CAPABILITIES UID: 7B 93 21 D8 62 1E C2 2B 4F 6E 8B 94 A3 05 01 36 VENDOR: 00 00 NODES: FF FLAGS: 05 00 00 00 00 00 00 00 00 00 00 00 00 FIRMWARE CRC BOOT: BB BB FW: 75 7B MISC FREQ: EU NVR Content -------------------------------------------------------------------------------------------- Prog/erase lock : FF FF FF FF FF FF FF FF, Read back lock: FF Rev 01, Cal 06, TXCal 17 13, SAW FF FF FF FF, Pin FF, CRC 3E CE NMV: CS 15, TYPE 02, SIZE 01 00, PSIZE 01 00 (EEPROM M25PE20) USB: VID FF FF, PID FF FF, UUID FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF -------------------------------------------------------------------------------------------- FACTORY ID: WEEK 51, YEAR 16, CHIP 00 01, SER 0B D2, WS 1, HWREV: 00 01, CRC8 04 elapsed 3.09909391403 seconds
The next steps seems to be to find the latest firmware, and that’s where things get a little confusing, as it basically tells you to go and find it via this - https://service.z-wave.me/expertui/uzb-stats/versions-graph.html. and that’s where I get lost ..
It seems to be suggesting that I need to build my own url (using the following construct below) to download it..
