  3. replacing SDC on Raspi with SSD
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
2 Posts 2 Posters 863 Views 2 Watching
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    I picked up a new WD SSD for practically next to nothing (wow, have prices on storage dropped) and want to replace the SDC in omy HS4 Pi that I added Node Red to.
    I know that a thread existed on this, perhaps on the Vera forum before it was censored. I can't find it here can anyone point me in the right direction.
    Thks
    aka Zedrally
      There is a whole thread on this on the H-A forum depending on what version of the rPi you have, it is more or less difficult.
      May 27, 2020
      Error - Native USB Boot without SD card for the Raspberry Pi4 (SSD Boot)
      Hi guys, I am trying to boot home assistant in Raspberry PI 4 from a SSD. I installed raspbian in the SD, I followed the steps in these posts - post 2 and got the same result after executing the vcgencmd bootloader_vertion and bootloader_config. The diference is that I am not using the same...
        164.4k
