  3. MyCroft: The localized voice assistant
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
11 Posts 4 Posters 2.1k Views 4 Watching
    Open Source Conversational AI Community
    The Open Source Conversational AI Development Community Forum for the Neon AI platform and applications. Supporting the Mycroft AI legacy, Mark II users, the OpenVoice Operating System, and more.
    I have been following this project with great interest and am thinking about testing it. Eventually, I believe this is the way to go and will eliminate all the GH and Echo ecosystems.
      Cool name as well!
        Yeah, big Sherlock fan here... 😊
          Cool name as well!
          @CatmanV2 said in MyCroft: The localized voice assistant:
          Cool name as well!
          Darn, yes. That was the name I had picked for my personal "Jarvis" / "Orac" / "Hal" / ...
          "My Computer Remote Operation Functions Technology"
            Orac. Or Zen
              Here is a very concrete and fairly easily implementable project... Hmm this may replace Alexa.
              GitHub - rhasspy/rhasspy: Offline private voice assistant for many human languages
              Offline private voice assistant for many human languages - rhasspy/rhasspy
                Ooh! Good find!
                  Well that'll give me something to play with 😉
                    of all the thing it doesn't make sense to have a cloud nature, voice assistants are the ones it makes a lot, imho. sometimes I wish local control were better supported, instead of going thru the cloud every single time, but the advantages of having others working on utterances, training and engines is priceless*.
                    • part of my job is to work on those things and, believe me, you can't compete with the resources they have.
                      What I want is Alexa in my pocket.....
                        @therealdb
                        I tend to have mixed feelings about this. The voice processing I think could definitely be localized with even more customized functions like voice recognition. This would greatly improve privacy and security.
                        There are however a lot of things these devices do which makes a lot of sense for them to reside in the cloud. At the end it is really about design purpose. If it is only for home control, I think localized is better. If it is to go much further then, cloud makes more sense.
                          102.3k
                        • Integrations and 'Loaded'
