  3. pointpubmedia.com
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
pointpubmedia.com
9 Posts 3 Posters 1.2k Views 2 Watching
    I noticed this forum has a good response time, loads fast. who is pointpubmedia.com ?
    • DesTD Offline
      DesTD Offline
      DesT
      It's us 😉
        Where is it hosted?
        • DesTD Offline
          DesTD Offline
          DesT
          It's our own datacenter (2) located in Canada! We are not "sublet" anywhere! We own everything and we managed our self the "hardware" and the setup!
            wrote on last edited by Elcid
            I'm impressed. Do you have price plans in english?
            DesTD 1 Reply Last reply
            • ElcidE Elcid
              DesTD Offline
              DesTD Offline
              DesT
              @Elcid yeah I'm really sorry for the english part of our website. It's one thing in our agenda for 2020 😉
              For the pricing, it's complicated. We are not providing a control panel, like cPanel, to our client as we are taking care of everything for them here.
              We are not dealing with clients that are self-managed.
              The forum is fast 'cause it's behind our cluster setup that it's very hard to give acces for our client, there's not FTP/FTPS/SFTP/cPanel/whatever that give access from the outside.
              We are also able to provide "container (lxc)" and VM (qemu) to our client that give them access to do what they want, except, we managed incoming traffic through our clustered firewall to make sure our environnement is under tight security as we are dealing with sensitive "data" for our clients.
              If you need something, feel free to talk to us in private and I can check what we can do!
                I will keep you in mind. I am really impressed with the response time. I was so quick it made me flinch.
                • DesTD Offline
                  DesTD Offline
                  DesT
                  Happy to see that our setup is fast outside our "country" 😉
                  • propheadP Offline
                    propheadP Offline
                    prophead
                    good day, eh
                    • Time series documentation
                    • Tuya Wifi to Tasmota flashing
                    • Reset a delay
                    • Single protocol?
                    • HDMI oddness
