  3. New to the forum
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
New to the forum
81 Posts 6 Posters 53.8k Views 6 Watching
  • Q Offline
    Q Offline
    Quixote
    #43
    I see nothing running on that port. Also, it still doesn't work even after using "http://172.25.26.14:3480/data_request?id=exit" and attempting to initialize the program again afterwards.
    I'm starting to think this may be firewall related, though I'm unsure as to how that would just manifest itself out of nowhere when I had it running fine last week.
    Update 1: After rebooting, it just gives me this message:
    rm: cannot remove '/www/altui/altui*': No such file or directory
    and then hangs.
    Update 2: Ok, so I tried running the install again and it seemed to work, but opening the IP address did not. I went and browsed the web for a good hour and then tried again for the hell of it and, lo and behold -- it worked. It no longer has VeraBridge installed or any devices that I had imported last week. AltUI still refuses to load.
    Interesting.
    Q akbooerA 2 Replies Last reply
    • Q Quixote
      and then hangs.
      Interesting.
      Q Offline
      Q Offline
      Quixote
      • Q Offline
        Q Offline
        Quixote
        #45
        • Q Quixote
          and then hangs.
          Interesting.
          @quixote said in New to the forum:
          An absolutely standard, if confusing, message from AltUI. So it must, at least, have started running.
          Is there something special about the VM environment which requires some configuration, perhaps? Way out of my league, there.
          But if you have access to the openLuup console menu, there’s much we can do to diagnose the system.
          • logs, both the standard one and the startup one.
          • openLuup > Scheduler pages, particularly startup and plugins pages
          • openLuup > Servers, particularly the http page.
          This should gives us some clues.
          Q 1 Reply Last reply
            Q Offline
            Q Offline
            Quixote
            #47
            @akbooer I have no idea about configuring WSL in Windows. All I did was install it along with Kali Linux, and then Lua 5.1 and the other dependencies from the Bash prompt. I'm guessing that therealdb would probably have mentioned any setup procedures specific to this particular arrangement that I may have missed, but it seemed fairly straightforward. Here are the logs:
            logs/LuaUPnP_startup.log
            2020-12-10 05:10:17.519   :: openLuup STARTUP :: /etc/cmh-ludl
            2020-12-10 05:10:17.519   openLuup.init::        version 2020.05.01  @akbooer
            2020-12-10 05:10:17.527   openLuup.scheduler::   version 2020.01.25  @akbooer
            2020-12-10 05:10:17.531   openLuup.wsapi::       version 2019.08.12  @akbooer
            2020-12-10 05:10:17.531   openLuup.servlet::     version 2020.01.29  @akbooer
            2020-12-10 05:10:17.531   openLuup.client::      version 2019.10.14  @akbooer
            2020-12-10 05:10:17.532   openLuup.io::          version 2019.11.29  @akbooer
            2020-12-10 05:10:17.532   openLuup.server::      version 2020.03.20  @akbooer
            2020-12-10 05:10:17.533   openLuup.scenes::      version 2020.03.16  @akbooer
            2020-12-10 05:10:17.534   openLuup.chdev::       version 2020.03.07  @akbooer
            2020-12-10 05:10:17.534   openLuup.userdata::    version 2020.03.31  @akbooer
            2020-12-10 05:10:17.534   openLuup.requests::    version 2020.04.15  @akbooer
            2020-12-10 05:10:17.535   openLuup.gateway::     version 2020.03.08  @akbooer
            2020-12-10 05:10:17.535   openLuup.smtp::        version 2018.04.12  @akbooer
            2020-12-10 05:10:17.536   openLuup.historian::   version 2020.02.12  @akbooer
            2020-12-10 05:10:17.536   openLuup.luup::        version 2020.03.21  @akbooer
            2020-12-10 05:10:17.537   openLuup.pop3::        version 2018.04.23  @akbooer
            2020-12-10 05:10:17.537   openLuup.compression:: version 2016.06.30  @akbooer
            2020-12-10 05:10:17.537   openLuup.timers::      version 2019.05.03  @akbooer
            2020-12-10 05:10:17.537   openLuup.logs::        version 2018.03.25  @akbooer
            2020-12-10 05:10:17.537   openLuup.json::        version 2020.05.20  @akbooer
            2020-12-10 05:10:17.537   openLuup.init:: Cjson not installed - using openLuup.json.Lua.decode() instead
            2020-12-10 05:10:17.548   luup.create_device:: [1] D_ZWaveNetwork.xml / I_ZWave.xml /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
            2020-12-10 05:10:17.552   luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json   (openLuup)
            2020-12-10 05:10:17.552   openLuup.init:: loading configuration user_data.json
            2020-12-10 05:10:17.552   openLuup.userdata:: loading user_data json...
            2020-12-10 05:10:17.553   luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
            2020-12-10 05:10:17.553   openLuup.userdata:: loading rooms...
            2020-12-10 05:10:17.553   openLuup.userdata:: ...room loading completed
            2020-12-10 05:10:17.553   openLuup.userdata:: loading devices...
            2020-12-10 05:10:17.554   luup.create_device:: [1] D_ZWaveNetwork.xml / I_ZWave.xml /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
            2020-12-10 05:10:17.557   luup.create_device:: [3] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json   (urn:schemas-upnp-org:device:AltAppStore:1)
            2020-12-10 05:10:17.557   openLuup.userdata:: loading scenes...
            2020-12-10 05:10:17.557   openLuup.userdata:: number of scenes = 0
            2020-12-10 05:10:17.557   openLuup.userdata:: ...scene loading completed
            2020-12-10 05:10:17.557   openLuup.userdata:: loading installed plugin info...
            2020-12-10 05:10:17.557   openLuup.userdata:: [openLuup] openLuup (20.5.22)
            2020-12-10 05:10:17.557   openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
            2020-12-10 05:10:17.557   openLuup.userdata:: [VeraBridge] VeraBridge (not.installed)
            2020-12-10 05:10:17.557   openLuup.userdata:: [8246] Alternate UI (not.installed)
            2020-12-10 05:10:17.557   openLuup.userdata:: [Z-Way] Z-Way (not.installed)
            2020-12-10 05:10:17.557   openLuup.userdata:: [Arduino] MySensors (not.installed)
            2020-12-10 05:10:17.557   openLuup.userdata:: ...user_data loading completed
            2020-12-10 05:10:17.557   openLuup.init:: running _openLuup_STARTUP_
            2020-12-10 05:10:17.557   luup_log:0: startup code completed
            2020-12-10 05:10:17.557   openLuup.init:: init phase completed
            2020-12-10 05:10:17.557   :: openLuup LOG ROTATION :: (runtime 0.0 days)
            logs/LuaUPnP.log
            2020-12-10 05:10:17.557   openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x55cccfabb738
            2020-12-10 05:10:17.557   openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x55cccfb272f8
            2020-12-10 05:10:17.557   openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x55cccfa9c848
            2020-12-10 05:10:17.557   openLuup.historian:: starting data historian
            2020-12-10 05:10:17.557   openLuup.historian:: using memory cache size (per-variable): 1024
            2020-12-10 05:10:17.557   openLuup.scheduler:: starting
            2020-12-10 05:10:17.557   openLuup.scheduler:: [2]     openLuup device startup
            2020-12-10 05:10:17.557   luup_log:2: v20.5.22
            2020-12-10 05:10:17.557   luup_log:2: sync in 102.4 s
            2020-12-10 05:10:17.558   luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode
            2020-12-10 05:10:17.558   luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local
            2020-12-10 05:10:17.558   luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local
            2020-12-10 05:10:17.558   luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local
            2020-12-10 05:10:17.558   luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local
            2020-12-10 05:10:17.558   luup.chdev.append:: [AltAppStore] Alternate App Store
            2020-12-10 05:10:17.558   luup.chdev.sync:: [2]     openLuup, syncing children
            2020-12-10 05:10:17.558   luup_log:2: 2Mb, 0%cpu, 0.0days
            2020-12-10 05:10:17.558   openLuup.scheduler:: [2]     openLuup device startup completed: status=true, msg=sync in 102.4 s, name=L_openLuup
            2020-12-10 05:10:17.558   openLuup.scheduler:: [3] Alternate App Store device startup
            2020-12-10 05:10:17.558   luup_log:3: AltAppStore : starting...
            2020-12-10 05:10:17.558   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0
            2020-12-10 05:10:17.558   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was:  now:  #hooks:0
            2020-12-10 05:10:17.558   luup_log:3: AltAppStore : v20.3.30
            2020-12-10 05:10:17.558   luup.set_failure:: status = 0
            2020-12-10 05:10:17.558   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
            2020-12-10 05:10:17.558   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
            2020-12-10 05:10:17.558   openLuup.scheduler:: [3] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore
            2020-12-10 05:10:17.816   openLuup.io.server:: HTTP:3480 connection from 172.19.112.1 tcp{client}: 0x55cccfa9e8f8
            2020-12-10 05:10:17.817   openLuup.server:: GET /w3.css HTTP/1.1 tcp{client}: 0x55cccfa9e8f8
            2020-12-10 05:10:17.817   openLuup.server:: request completed (23661 bytes, 2 chunks, 0 ms) tcp{client}: 0x55cccfa9e8f8
            2020-12-10 05:10:17.820   openLuup.server:: GET /icons/openLuup.svg HTTP/1.1 tcp{client}: 0x55cccfa9e8f8
            2020-12-10 05:10:17.820   openLuup.server:: request completed (458 bytes, 0 chunks, 0 ms) tcp{client}: 0x55cccfa9e8f8
            2020-12-10 05:10:17.821   openLuup.io.server:: HTTP:3480 connection from 172.19.112.1 tcp{client}: 0x55cccfaade28
            2020-12-10 05:10:23.085   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55cccfaade28
            2020-12-10 05:10:29.799   openLuup.server:: GET /openLuup?page=system HTTP/1.1 tcp{client}: 0x55cccfa9e8f8
            2020-12-10 05:10:29.799   openLuup.wsapi:: using openLuup/console.lua for openLuup
            2020-12-10 05:10:29.799   openLuup.wsapi:: using REQUIRE to load CGI openLuup/console.lua
            2020-12-10 05:10:29.807   openLuup.server:: request completed (11022 bytes, 0 chunks, 7 ms) tcp{client}: 0x55cccfa9e8f8
            2020-12-10 05:12:00.085   luup_log:2: synchronising to on-the-minute
            2020-12-10 05:12:00.085   luup.call_timer:: interval: time=2m, days={}
            2020-12-10 05:12:00.085   luup_log:2: 2 minute timer launched
            2020-12-10 05:12:00.085   luup_log:2: 3Mb, 0%cpu, 0.0days
            2020-12-10 05:12:03.091   openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x55cccfa9e8f8
            2020-12-10 05:14:00.124   luup_log:0: 2Mb, 0%cpu, 0.0days
            2020-12-10 05:15:13.997   openLuup.io.server:: HTTP:3480 connection from 172.19.112.1 tcp{client}: 0x55cccfc0ffa8
            2020-12-10 05:15:13.998   openLuup.server:: GET /openLuup?page=startup_log HTTP/1.1 tcp{client}: 0x55cccfc0ffa8
            2020-12-10 05:15:13.998   openLuup.server:: request completed (11674 bytes, 0 chunks, 0 ms) tcp{client}: 0x55cccfc0ffa8
            2020-12-10 05:16:00.088   luup_log:0: 4Mb, 0%cpu, 0.0days
            2020-12-10 05:16:44.180   openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x55cccfc0ffa8
            2020-12-10 05:17:16.830   openLuup.io.server:: HTTP:3480 connection from 172.19.112.1 tcp{client}: 0x55cccfb14ab8
            2020-12-10 05:17:16.831   openLuup.server:: GET /openLuup?page=log HTTP/1.1 tcp{client}: 0x55cccfb14ab8
            I'm assuming that logs .1 to .5 are just previous sessions being pushed through the line?
            Scheduler: Startup
            Plugin Startup Jobs CPU usage (in startup order)
            # 	date / time 	device 	priority 	status 	hh:mm:ss.sss 	job # 	info 	notes
            1 	2020-12-10 05:10:18.058 	2 	1 	Done 	0.000 	1 	plugin: openLuup 	sync in 102.4 s
            2 	2020-12-10 05:10:18.058 	3 		Done 	0.000 	2 	plugin: Alternate App Store 	OK
            Scheduler: Plugins
            Plugin CPU usage (0.0% system load)
            # 	device 	status 	hh:mm:ss.sss 	name 	message
            1 	2 	-1 	0.001 	openLuup
            2 	3 	-1 	0.000 	Alternate App Store
            Servers: http
            request 	#requests 	status
            /openLuup 	26 	200
            icons/openLuup.svg 	1 	200
            w3.css 	1 	200
            I hope this will help!
              Under WSL you must use localhost (or 127.0.0.1) with the port. I usually go to http://127.0.0.1:3480/ and it's enough.
              The beauty of WSL is that it's running a Linux kernel along the Windows one, and it's transparently sharing disk and network resources between the two.
              Let me know if you want to add a paragrah for this in the guide @akbooer, since I think it's the best setup if you want to develop plug-ins for openLuup on a Linux box.
                @therealdb said in New to the forum:
                Yes, happy to do that – thanks. The documentation really does need a bit of updating and restructuring, it simply got paragraphs and chapters added as functionality increased.
                Yes, thanks. You're running a (very) bare-bones system – even less than you would get with the standard install. But it is enough to bootstrap from. We really do need to get AltUI running (licensed, or not) first.
                • Tables > Plugin Tables. Type 'master' into the Update box on the Alternate UI line and click the refresh button in that box.
                • This will take a little while (~20 seconds?) and if you quickly switch to the devices page, you should see that the Alternate App Store plugin has started to load AltUI.
                • if you refresh the devices pages, you should see that the uploading proceeds (or has finished.)
                This should leave you with a running copy of AltUI, so you can try to access that again. You may need a Luup reload from the openLuup > Utilities menu.
                Yes, the .1, .2, ... logs are previous versions. If AltUI access doesn't work, I'd like to see the log for the period when you were trying to get it downloaded.
                Your next step would be to reconnect to your Vera, but we can leave that for a bit later.
                WSL wasn't my idea, and I know nothing about it, so any help needed there will have to come from others.
                • Q Offline
                  Q Offline
                  Quixote
                  #50
                  @therealdb thank you, I'll try that.
                  @akbooer The download fails every time. It'll hit 3%, maybe 12% once, then fail.
                  Sorry, but WSL is my only option at present. I did have the VeraBridge functioning (at least in part) because I could see devices from the Vera in openLuup. Don't ask me what the heck happened overnight the other night, though! I swear, I have some sort of technology curse!!
                  How about using the github repository with the icon? Is that possible and how?
                    Is there anything shown in the log when the download fails?
                    Clearly, the download code does actually work in most environments, but not in yours. This is one reason that VMs are more of a problem to diagnose.
                      Q Offline
                      Q Offline
                      Quixote
                      @akbooer Here are the log entries:
                      2020-12-11 01:16:03.648   openLuup.io.server:: HTTP:3480 connection from 172.19.112.1 tcp{client}: 0x55cdaf32ae08
                      2020-12-11 01:16:03.649   openLuup.server:: POST /openLuup? HTTP/1.1 tcp{client}: 0x55cdaf32ae08
                      2020-12-11 01:16:03.649   luup.call_action:: 3.urn:upnp-org:serviceId:AltAppStore1.update_plugin
                      2020-12-11 01:16:03.649   luup_log:3: AltAppStore : starting <run> phase...
                      2020-12-11 01:16:03.650   luup_log:3: AltAppStore : downloading amg0/ALTUI [master] to trash/AltAppStore/
                      2020-12-11 01:16:03.650   luup_log:3: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=master
                      2020-12-11 01:16:12.565   luup_log:3: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=master
                      2020-12-11 01:16:16.980   luup_log:3: AltAppStore : getting contents of version: master
                      2020-12-11 01:16:16.980   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine1 was: Downloading... now: Downloading... #hooks:0
                      2020-12-11 01:16:16.980   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI failed now: Alternate UI #hooks:0
                      2020-12-11 01:16:16.982   luup_log:3: AltAppStore : scheduling <job> phase...
                      2020-12-11 01:16:16.982   openLuup.requests::
                      2020-12-11 01:16:16.983   openLuup.server:: request completed (16694 bytes, 0 chunks, 13334 ms) tcp{client}: 0x55cdaf32ae08
                      2020-12-11 01:16:24.034   luup_log:3: AltAppStore : starting <job> phase...
                      2020-12-11 01:16:24.034   luup_log:3: AltAppStore : download failed, status: wantread
                      2020-12-11 01:16:24.034   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI failed #hooks:0
                      2020-12-11 01:16:24.034   openLuup.server:: GET /openLuup?page=devices HTTP/1.1 tcp{client}: 0x55cdaf32ae08
                      2020-12-11 01:16:24.035   openLuup.server:: request completed (9499 bytes, 0 chunks, 1 ms) tcp{client}: 0x55cdaf32ae08
                      2020-12-11 01:16:24.379   openLuup.server:: GET /icons/zwave_default.png HTTP/1.1 tcp{client}: 0x55cdaf32ae08
                      2020-12-11 01:16:24.379   openLuup.server:: request completed (0 bytes, 0 chunks, 0 ms) tcp{client}: 0x55cdaf32ae08
                      2020-12-11 01:16:24.379   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55cdaf32ae08
                      2020-12-11 01:16:29.954   openLuup.io.server:: HTTP:3480 connection from 172.19.112.1 tcp{client}: 0x55cdaf4dbe78
                      2020-12-11 01:16:29.955   openLuup.server:: GET /openLuup?page=log HTTP/1.1 tcp{client}: 0x55cdaf4dbe78
                      Yes, this setup is showing itself to be quite problematic. I'll try for a while longer before giving up. That would be really disappointing. I was getting really hyped to get back into automating things around here, and Alexa routines just don't cut it.
                        My suggestion is to reinstall it again. It’s somewhat corrupted. From a technical perspective, WSL is just a Linux vm. I’m running Ubuntu, try with it. WSL can run different distro side by side.
                          Q Offline
                          Q Offline
                          Quixote
                          @therealdb Hi, sorry, could you spell it out for me so that there's no way I'll mess it up? I'd like to delete the files I've installed and wipe the Kali installation before I give this one last go with Ubuntu. I only initially installed Kali because I thought it could come in handy were I to install Wireshark, etc.
                          Thanks for your assistance
                            For my part, I’m going to do a fresh install on a Windows machine, and see how that goes.
                            The only different thing from my previous experience is installing a stand-alone Lua, rather than my usual development environment.
                              Q Offline
                              Q Offline
                              Quixote
                              #56
                              @akbooer Thanks!
                              I imagine that will be quite easy from my past experience (with Lua for Windows, I mean). My worry is only that running plugins, etc. may not translate well when ported from a Linux/Unix environment. Guess there's only one way to find out!
                                It should be enough to delete the distro from start menu and start again. As I said, it’s just a windows app from this point of view. A command line to install and manage distros is available, just google for it.
                                    • Q Quixote
                                      This looks like an OpenSSL error. Does that need updating somehow?
                                        #61
                                        Oh, I got sidetracked by investigating WSL...
                                        I now have openLuup and AltUI running under WSL (Alpine, because I'm a fan of minimalist things, and that's the image I run in Docker.)
                                        I can supply detailed instructions if required (although you're probably just as able as I to do that.)
                                        • Q Offline
                                          Q Offline
                                          Quixote
                                          #62
                                          Ok, this is getting ridiculous.
                                          I uninstalled Kali as a Windows app, installed Ubuntu 20.04 LTS instead, reinstalled Lua 5.1 and all dependencies, reinstalled openLuup.
                                          After all that, I try to open http://172.22.154.28:3480 as prompted and get nothing but "No handler for data_request?id=lr_ALTUI_Handler" at the top of the page.
                                          aaaarrrrgh!!! No idea what I could be doing wrong here.
                                            165.2k
