  4. Can't see VeraPlus and Hubitat (config question)
21 Posts 3 Posters 9.6k Views 2 Watching
    Matteburk
    ok here itr is4c80c375-ddea-4ade-9c31-4797be86e60e-Skärmavbild 2021-02-23 kl. 19.10.20.png Skärmavbild 2021-02-23 kl. 19.10.20
    Skärmavbild 2021-02-23 kl. 19.10.00
    - id: hubitat
      enabled: true
      implementation: HubitatController
      name: A Hubitat Elevation system
        source: 'http://192.168.68.145'
        access_token: "4421ed2b-4d85-4686-a104-23b3632a7824"
      OK. I see the issue. I assumed something about the structure of their URLs that apparently I can not, so I'll need to fix that. Today's daily build will have a fix.
        Matteburk
        ok great!
          Matteburk
          Here is the rest of the Maker API below5fda3003-ebd6-4fcb-947b-b5816c08a472-Skärmavbild 2021-02-23 kl. 19.38.54.png Skärmavbild 2021-02-23 kl. 19.38.54
            OK, so when you upgrade to 21054 later today or tomorrow (should be published tonight my time Eastern US), you will just copy-paste the "Get Device Info" URL given there, or you can right-click the "Get All Devices" link above it and then paste that into your configuration. The updated HubitatController will just take that URL apart to get the information it needs. You should not even need to specify access_token any more (if it's on the URL, it will grab it). Coming soon...
              Matteburk
              ok perfect. that's the way other Maker API apps works , uses the hole url string with token.. Good work Patric!
                Yeah, what I got wrong was that number in the middle. I assumed, very incorrectly apparently, that is was a universal application ID or an API version number, something relatively static. Well, it's an application ID, but not universal, or static--it's apparently going to be different on every Hubitat. Teething pains. And cheesus ghost, their documentation is horrible.
                Speaking of documentation, and forums, on their forums is much discussion about the Post URL magically vanishing, or not working. So that's the next thing to watch out for.
                  Matteburk
                  Not just the documentation.... their Rulemachine can be soooo annoying! Speaking of documentation Whats the easiest way to update the msr?
                    Easiest way? I think... read the documentation! 😉 Look at the "Installation" page. You can use the "Manual" link in the left navigation of MSR, or click the link below:
                    MSR docs: Installation
                      Matteburk
                      #21
                      Ok.... here we go! All hubs online in MSR :). ,Vera Plus and HUBITAT!..... Thanx for the help!..... Lets test!
                        162.2k
