  4. Preview of Multi-System Reactor
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
58 Posts 11 Posters 27.5k Views 11 Watching
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    Happy New Year to everyone as well 🙂
    Looks like you have given us all a belated Christmas present.
    A couple of questions, will/can it run with multiple Vera's (Vera Lite UI5) and Edge UI7?
    Haven't noticed anyone has asked about Homeseer integration, which would be my missing link.
    None the less it's a quantum leap in our world of Automation.
    Lastly, you will have your hands full now keeping everyone up to date with developments, which forum do you intend to use as the Primary means of communication?
    aka Zedrally
    • toggledbitsT Online
      toggledbitsT Online
      Unfortunately I haven't run any UI5 in years, so I don't have anything around to play with. Technically, however, there's no reason it could not be made to work.
      For any interface, the only requirement is some kind of API where device information can be gathered. I can't imagine HomeSeer not having one, but it's not a system I've ever had contact with.
      For the moment, if there's no objection from the owner, I'd rather communicate in this forum rather than the Vera Community forums, and maybe a category can be set up just for that, to help thread the discussions a bit better. I've also got Discord, but I don't know how many people really use that or would be interested in trying; but I like the more immediate flow of messaging for some things. As I said in the video, there's an entire ecosystem that has nothing to do with building the project that needs to come together, so I'm sure it will evolve.
        Black CatB Offline
        Black Cat
        I'm surprised that you never looked at Homeseer as a Vera replacement, it appears to have a huge US (local to you) user base, may I ask why?
        Do you have a timeline for release, perhaps a Beta; I know that there will be many chopping at the bit for a test drive.
        aka Zedrally
          @toggledbits said in Preview of Multi-System Reactor:
          Sounds like a good idea to me. This forum has always been platform independent, so what better place?
            If the idea is to create a top automation layer - what about including some of your other automation luup plugins? I think i.e. Delaylight, SiteSensor and AutoVirtualThermostat would fit nicely as Automation templates that can be quickly configured?
            Automation templates is something i've been missing in Reactor, what i mean by that is simply a good way to copy the structure of a good automation i have running in one room to another room (Today I have a Reactor sensor in each room, and one for "House" automation).
            Example: I have two guest rooms set up with identical sensor and actuator layouts, so the automation i want would be identical for those rooms.
            Another side note, i think some sort of room organization would be nice in the entities list?
            I'm not entirely sure about how to implement either of these, or the scope of the work it entails, just throwing out some ideas. 🙂
              [Possibly split the following feedback into its own thread if seeking input on MSR Dashboard UI]
              As a Dashboard n00b, I'd benefit from knowing exactly where on a particular Dashboard tile to tap for "Dim+", "Dim-", "On/100%" and "Off/0%". So I created two examples, linked below, despite knowing full well that others have created much better examples than this on other platforms. I also fully acknowledge that this kind of feedback is premature, as the official roll-out of MSR's Dashboard feature has not yet happened.
              ON: https://drive.google.com/file/d/1kWPtPa2HQ5GExBIi45QNJGyEvsz5QVZu/view?usp=sharing
              OFF: https://drive.google.com/file/d/1EIZK1BggsDtNWm8mfBT605N7-cnkeSQ_/view?usp=sharing
                SUGGESTION
                In the text fields used under "Rulesets", instead of having "Add your rule's triggers here" guidance text pre-populate the object (which requires users to click-drag-delete before typing), could you instead use the object's .placeholder attribute?
                I know this is a controversial stylistic choice among CSS designers, but the Placeholder approach carries with it some immediate benefits:
                • Help text disappears upon clicking into field;
                • Help text reappears if user empties the field;
                • Can appear in different font style (e.g. greyed, italic) from input text;
                • Not apt to be misinterpreted as filled text, nor read by a screen reader app;
                Minutiae, yes, but still worth my mentioning IMHO.
                COUNTERARGUMENT: https://www.smashingmagazine.com/2018/06/placeholder-attribute/
                  SUGGEST (I'll happily move these suggestions elsewhere, such as the Mantis, if instructed to do so)
                  Assuming that "==0" and "is FALSE" will both match the condition of a device being turned OFF (the MSR UI seems to prefer "false" to "0" when referring to POWER_SWITCH.STATE, for instance), could you also add "is ON" and "is OFF" to the drop-down list of comparators?
                  However redundant, this seems a natural language-y thing to have in place for novice users, who may not think in binary 0/1.
                    toggledbitsT Online
                    There are a bunch of hints in the capabilities data that I'm not making use of yet. This is exactly that kind of thing.
                        "power_switch": {
                            "attributes": {
                                "state": {
                                    "type": "bool",
                                    "values": {
                                        "true": "on",
                                        "false": "off"
                      By now, you understand I'm reluctant to add an "Issue" to the Mantis when I'm merely thinking aloud, so here goes with another set of MSR thoughts:
                      (1) Should each Ruleset have its own top-level DISABLE flag/button/status? (i.e. above even 'Triggers' and 'Constraints')
                      (2) Would it be useful to be able to "enable/disable" a Ruleset from another Ruleset? (this may already be possible, I haven't checked deeply)
                      (3) Does MSR possess the same "Throttling" feature as Luup Reactor, to stem circular references and flapping? I'll be interested to learn whether the reset mechanism is also similarly employed.
                      (4) Since lexpjs is normally evaluated at compile-time, would it be possible to (i) perform syntax checking during Expression entry, (ii) provide a drop-down 'helper' (APK-esque pick-list) from which users can select from a menu of possible functions, and/or (iii) generate daily alert summaries advising user of non-working Expressions (or other error conditions within MSR)?
                      I included (4)(iii) because I'm always uncovering old Reactor recipes that have "issues" resulting from obsolete references. And I love the way, for instance, Synology NAS units email their owners to notify them of system status, security concerns, updates needed, etc.
                        toggledbitsT Online
                        toggledbitsT Online
                        @librasun said in Preview of Multi-System Reactor:
                        I could probably add this is a macro-instruction in the UI, but Rule Sets are only an organizational structure for the benefit of the user and have no inherent relationship to the Rule for purposes of logic. Such a feature would simply loop over the list of rules in the set and enable or disable them. The Rule Set itself would not have an enabled or disabled state.
                        This will definitely not be happening, for the same reason I don't allow enabling/disabling a Rule from another rule: this could quickly create a situation in which a user's logic is completely unsupportable, because at any given time you don't know what is enabled or disabled, or who enabled or disabled, or when or why. IMO, the less users understand about how to structure their logic (e.g. elusive boolean algebra), the more likely a kludge like this would be used, as well; it would become the crutch from he**. I'm all for choices and giving users a little rope that they might hang themselves with, but this seems like a guaranteed highway to pain.
                        My evidence of this, by the way, is how quickly people went to various modes of the "Reset Latched" action, rather than structuring their logic so that latched conditions would reset naturally. MSR has only natural unlatching.
                        It does indeed, although MSRs version is a little software. In MSR, when the threshold is breached, it simply delays further performance on that rule. It literally throttles it back, rather than cutting the gas off entirely.
                        lexpjs is fully portable between the different versions of JavaScript that run within a browser and that which runs in nodejs. So it's very possible to have "test compiles", and it's a pretty light-weight thing to do. Of course, this won't catch runtime errors, like referring to an entity that doesn't exist, or an attribute on an entity that doesn't exist, but I agree it would make editing smoother. Little UI tweaks like this are fine for bug reports. I like them as reminders. I think this (as in, what is happening right here, right now) is a good workflow: discuss, and when we find the consensus on what needs to be done, open a PR to memorialize it.
                        Now, getting really fancy and having a bunch of drop-down pickers/assistants, should probably be a separate second PR. I think the first level problem is to get more dynamic syntax checking, and then we start thinking about assistants.
                          Dang, I just jetted back here to declare my idea #1 as "dumb" but thankfully you beat me to it. Individual Rules already have their own (manual) enable/disable anyway. Dunno what I was talking about. 🙂
                            USER NOTE: Whereas in MFL I followed your prescribed paradigm of naming Reactors after individual Rooms (e.g. "DINING ROOM", "PORCH", etc.), with MSR I'm leaning toward naming Rulesets after their meta-function (e.g. "LIGHTING", "SECURITY", "ENVIRONMENT", etc.) instead.
                            Dunno if you've made a conscious decision to promote one naming schema over another, but wanted to toss this idea in the ring.
                              toggledbitsT Online
                              toggledbitsT Online
                              I don't think that's at all dumb, and it makes a lot of sense, depending upon, as you said in your follow-on post, what schema you choose for your rules. So far, I've gone with one rule set per room, just leaving the mapping established by the importer. Particularly when getting the rules moved from RFL to MSR, I often had to disable an entire room's (rule set's) rules until I got something fixed.
                              It's not a bad idea at all.
                                May I also just add that I appreciate how a Reaction can "Stop" itself? Could be a powerful debugging tool when needed.
                                  #23
                                  LEARNED SOMETHING TODAY
                                  1. You can click-and-drag Rules to reorganize them in Rulesets. Who knew?
                                  2. You cannot, however, click-to-highlight the Rule ID of an expanded rule, in order to copy that text.
                                  3. Setting an Expression := away is entirely different from := "away". The first evaluates to (null) if no such named Global exists; the second evaluates to the string "away".
                                  #2 would be hugely helpful for times when you need to troubleshoot the Reactor.log. (I understand CSS and HTML, but don't know the correct term for "object not swipable" -- is this a side-effect of, say, a very high z-index on that block element?).
                                  As for #3, I foolishly thought MSR's expression parser, lexpjs, was meant to typecast unknown objects (away ► "away") but that was a n00b miscalculation.
                                    toggledbitsT Online
                                    Looks like #2 is a limitation of "sortable" objects in jQuery UI. The sortable takes over all clicks and drags. I'll keep poking for workarounds, but don't get your hopes up.
                                      re: #2 it might then be helpful to replicate the Rule ID within the Edit view of each Rule?
                                        toggledbitsT Online
                                        toggledbitsT Online
                                        You can do the same with Rule Sets... organize them in any order you wish.
                                          toggledbitsT Online
                                          toggledbitsT Online
                                          Why do you need the rule ID?
                                            164.0k
