Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
system capability zwave_scene_controller
I've just tried a Fibaro Roller Shutter 2 module and as suspected it says: zwave_scene_controller.scene_activated? (missing)
So cannot setup these wall switches for double and triple click events till its mapped.
For future reference, this is the Scene Activation information for the Fibaro Roller Shutter 2 module.
Something strange with these Fibaro Roller Shutter 2 modules.
I've updated the vera_devices.json file for the mapping and restarted MSR.
When I Double Click UP (S1) the sl_SceneActivated changes to 4, so that is OK and works.
However when I double click DOWN (S2) sl_SceneActivated remains at 0 its value doesn't change to anything. (Note I am setting them to 0 as part of the Set Reaction)
Same when I triple click DOWN (S2) sl_SceneActivated remains at 0.
PLEG is really using LastSceneID instead of sl_SceneActivated and they are the numbers above in that screen shot 14, 24 and 25 etc They are the numbers in PLEG I monitor for.
However we cannot see LastSceneID in MSR so I cannot use those numbers in my rules.
I have tried two different wall switches that are Roller Shutter 2 modules and they both behave exactly the same as I just described.
Which is somewhat confusing. So as it stands I can't use these Fibaro Roller Shutter 2 modules in MSR with scene activation.
I will test some more and maybe check their user manual and parameter settings or something.
The Fibaro Dimmer 2 modules on the other hand they are all working great with MSR no issues with any different types of clicks.
EDIT:
It says 0 in Vera GUI as well after just doing a double click down.
Can you confirm that the value of
sl_SceneActivated
behaves the same way on the Vera alone, without looking at MSR? Look at the state variables in Advanced > Variables for the device. Turn off your MSR rules or stop MSR to keep it from doing anything while you're testing, so the test is clean. To see changes accurately on Vera, you'll need to hard-refresh your browser after every test attempt, or alternately, click the "Edit" link on the state variables (you don't need to change them, just bring them into the editor, as this populates the correct current value when it opens; confirm the value and then just close the editor and move on to the next variable). -
FYI, I threw in the towel last night and admitted defeat. Fibaro has once again claimed a victim. There's a new extended capability that has the
last_scene_id
andlast_scene_time
values.I have a dozen scene controllers in my house. Leviton, EnerWave, ZRC-90s, and Hank. Not a one of them defines those two variables, and they're not declared in the service (and as I said, the service isn't even declared on the device type -- Fibaro support is kludged, apparently). I hope the new dev team over there, for everyone's sanity, takes a strict approach to consistency in handling devices. Between scene controllers and thermostats, this is a horrible legacy in current Vera firmware.
Sorry for the late reply I've been feeling unwell today.
I've not done the last test yet, where I disable the MSR rules and then look to see if the sl_SceneActivated value changes from 0 in the Vera web GUI ? When doing double and triple clicks on the switch etc.
I've not installed any new version of MSR either today. So we can now see the last_scene_id values now instead in MSR ?
Thanks for your efforts on this.
@cw-kid said in system capability zwave_scene_controller:
Thanks for your efforts on this.Yes. I tried to stick to standards, but since Vera really didn't, there's nothing I can do if I want it to work at all. I think we did a good job of pursuing every avenue before taking that step, but at the end of the day, we can't make something out of nothing, and have to use what we have available.
P.S. Sorry to hear you're not well. Rest up; hope you're on the mend soon.
That sl_SceneActivated variable does change OK for the Fibaro Dimmer 2 modules, as I said I have all those scene activations working and setup now in MSR.
But for the Fibaro Roller Shutter 2 modules it only correctly changes that sl_SceneActivated variable for double clicks UP (S1).
For double click down (S2) and triple click down (S2) it doesn't appear to be changing at all. Which is weird.
I wonder what the Fibaro Relay Switch modules do also? I do have some of those, but I am not using them with scene activation. I saw in the vera devices .json you also had a mapping for the Fibaro Relay Switch modules.
Yes, but no mapping yet, so when you get around to it....
I've done the last test on these Fibaro Roller Shutter 2 modules.
Its as I have said before. The sl_SceneActivated does not change value for S2 Double click or S2 Triple Click it remains as 0 in the Vera web GUI.
This is S1 Double click this does change to 4.
So there's no way this would of worked fully with MSR without also being able to see the Last_Scene_ID numbers.
In the new version of MSR this is what I see now:
I think I am going to switch all my rules to use the last_scene_id instead as its these numbers that are in the fibaro user manuals for scene activation.
I guess to reset the rule so I can repeat a double click I will have to reset the last_scene_id if possible ?
Changing this:
To this:
I will test it and see if it works.
EDIT:
Initial tests say everything is working as expected now using the lastsceneID numbers instead of sl_sceneactivated.
Thank you very much for enabling this functionality in MSR.
I can't wait to map all my Nodon battery-powered remote buttons to MSR routines once able. Mine can do single-, double- and long-press as well as the "release" action, netting me 16 possible actions. It even has an LED with programmable behavior (which I've never succeeded in altering; it just remains off).
Have you noticed that controlling scenes with MSR is far faster than MFL on Vera?
@librasun said in system capability zwave_scene_controller:
I've noticed that everything is faster. They appear to have considerable overhead in setting up and calling plugin code when it needs to happen. Their job scheduling can also delay the plugin's response when the system is busy doing other things. Luup is trying to be very defensive around plugins, but that comes at a performance cost. They made similar decisions (not surprisingly) in the new firmware that I warned them about early on, in some ways worse. We'll see how that turns out. I've heard they've reversed themselves, but since I'm not playing with that stuff any more, I haven't confirmed it myself.
I think these scene activations with my Fibaro modules are slower on MSR running on the Pi, than they were with PLEG running on Vera.
But that is to be expected I guess. I have about a 2 or 3 second delay after doing the clicks on the switch to when the action is run. Sometimes longer delays.
But its working which is the main thing.
Can you send me a log? I'd like to see if there's some obvious delay going on in MSR. And just to make sure, you're not using any condition options on the scene variable test, right?
I am not using any Constraints if that is what you mean.
Yes I can do some logs at some point.
There was one particular Fibaro Roller Shutter 2 module in the Kitchen, that was being very slow with the action running after the clicks.
I'll test that module again and look at logs.
As for all the others, 2 seconds seemed to be about the time it takes after clicking, for the action to run. Some of my actions are calling existing Vera scene I had in place, I can probably tidy that up a bit and control devices directly via MSR in the action maybe that may help.
OK. In case you want to poke at it yourself, and for the benefit of other readers... if you modify the level in
logging.yaml
forRule
to 6 (that is, find the line in the file that readsRule:
and change the level on the line below that one to 6), you'll get some deeper debug from all rules. Then restart MSR and activate your Fibaro device in whatever way you want to test.At that level, you should be able to find a logged entry in
reactor.log
with the string "launching evaluation for" that references your Fibaro device. This is the detection of the change on the Fibaro. That causes the rule to be evaluated, and you'll see that happening shortly after. Follow that along, and you'll see "Enqueueing" followed by the name of the set or reset reaction that is to run based on the rule's result state. That will be followed by the execution of the reaction, which comes mostly from the Engine, so you'll see it report "Starting reaction" (followed by the reaction name), and then the steps. The reaction is finished executing when it logs "all actions completed". If you note the timestamps on all these, you'll get a feel for how fast its responding in the three major phases: detection -> evaluation -> execution. -
I want to start moving ReactorOpenLuup to MSR and have the following problem. In Reactor OpenLuup I have set up below. Update does not show in de list in MRS. @cw-kid @ cw-kid What kind of setting do you use to use double click in MRS with roller shutter 2?
I am just using the LastSceneID
Here is an example for S2 Double Click which has a number of "24"
You also need to reset the LastSceneID back to 0 in the "Set Reaction".
The different SceneActivation numbers can be seen from the Fibaro Roller Shutter 2 user manual:
