  3. Incrementing an outside awning with Reactor/MSR
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
14 Posts 4 Posters 3.3k Views 4 Watching
    A. There's nothing Reactor cannot do!
    B. I think you'll want to open the ▼ chevron (in Reactor for Vera) or ... button (in MSR) next to one of your AND conditions.
    C. Use "Pulse" to have them momentarily go TRUE (for, say 1-2 seconds) every 120 seconds.
    D. The pulsing will automatically cease once either condition stops being TRUE.
    I hope this helps!
    Black CatB Offline
    Black CatB Offline
    Black Cat
    @librasun said in Incrementing an outside awning with Reactor/MSR:
    I hope this helps
    It certainly does ( and implemented), any idea how to tie this in with my original idea of following the sun's position?
    aka Zedrally
      My only idea involves using trigonometry and time to compute an angle, then scale everything to the travel extents of your awning. Hardly practical!
      Probably a much easier way. Will chew on this a while.
      Hints:
      • https://api.sunrise-sunset.org/json?lat=36.7201600&lng=-4.4203400&date=today gives free JSON responses that include solar noon
      • You can compute that just as readily by knowing sunrise and sunset times, and your latitude.
      • In my "SiteSensor" thread, this formula would likewise provide Solar Noon for the specified lat/lon location:
        Sn := openWx.sys.sunrise + floor((openWx.sys.sunset - openWx.sys.sunrise) / 2)
      I'll expand on how you could use this to modulate the awning position tomorrow.
        You know about the Heliotrope plug-in that tracks the sun’s position...?
        GitHub - a-lurker/Vera-Plugin-Heliotrope: Update of Futzle's Heliotrope plugin
        Update of Futzle's Heliotrope plugin. Contribute to a-lurker/Vera-Plugin-Heliotrope development by creating an account on GitHub.
        It’s in the Alt App Store.
          Incidentally, all the same calculations are done natively in openLuup in order to compute sunrise/set times.
            MSR also has native sun calcs. I guess I need to expose some of those features more, eh?
              No matter which source you use (MSR's built-in sunrise/sunset feature is probably optimal!), here's some back-of-the-napkin thoughts on how to calculate when and how to adjust your awning throughout the morning, assuming you start the process at Sunrise:
              Rule Expressions:
              shade_range = (<shade_max> - <shade_min>)
              elapsed_time = floor((<sunset_time> - <sunrise_time>) / 2)
              shade_move_per_cycle = N
              cycle_interval = floor(<elapsed_time> / (<shade_range>/N))
              Then in your Rule's Set Action:
              [INTERVAL] [EVERY] [<cycle_interval> seconds]
              [ENTITY ACTION] [MOVE SHADE] [N steps]
              NOTE: THIS IS ALL PSEUDO-CODE. I leave the actual formulae as an exercise for the reader.
                Sun angle is now part of a new "Sun Information" entity that will be published by the System Controller.
                Black CatB 1 Reply Last reply
                  Whoa, sweet! I know my out of left field suggestions might be a bit too much at times, but is there any chance that MSR will track statistics such as how often a particular rule runs during a given time span?
                  And how will users ultimately be notified if circular logic causes a rule to run excessively? Perhaps it is premature to be asking about that.
                    Black CatB Offline
                    Black CatB Offline
                    Black Cat
                    @toggledbits said in Incrementing an outside awning with Reactor/MSR:
                    All great replies and food for thought. I played around with the heliotrope plugin with PLEG, as I mentioned previously but couldn't make it work - but reactor is a different beast.
                    Any chance of exposing the sun & moon functions ( I assume that Moon functions are also present) in Reactor as well as MSR?
                    aka Zedrally
                      It doesn't have moon functions yet. Tell me how you want to use them.
                      • Black CatB Offline
                        Black CatB Offline
                        Black Cat
                        Full Moon and exterior lights - (deleted witty reply 😉)
                        aka Zedrally
                          Sounds good. When you figure out what your logic inputs need to be to make it work the way you want, let me know and we can talk about maybe getting those implemented.
                            376
                            151.4k
