  3. Vera watch variable / startup LUA how ?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
I run a B&B and am looking for a way to turn the lights off whenever a room is unoccupied for X amount of time. The guest should still be able to turn the lights on and off manually, but should not be able to disable the auto turn off feature if the room is unoccupied. I guess I am looking for a light switch with a built in presence sensor? I guess a presence sensor would be better as if it is a motion sensor, the lights may go off unwanted if the guest fails to make sufficient movement e.g. if the guest is lying down watching a film. Are there any products on the market that would work for my application?
Looking for Bluetooth device for smartphone audio transmission
Hello, I am in search of a device capable of using Bluetooth to connect with a smartphone and serve as its primary sound source on demand. This device should function similarly to conventional Bluetooth headphones, which automatically become the phone's sound output upon activation. However, this device should differ in that it transmits the audio signal to an amplifier via a jack, SPDIF, or similar connection. Alternatively, it could be an integrated amplifier that directly sends the signal to passive speakers. The control of this process should be manageable through an API such as MQTT, REST, MODBUS, or similar. Are you aware of any devices that operate in this manner? The concept is as follows: upon entering the bathroom, I would press a wall-mounted switch. This switch would send a signal to the Bluetooth device, prompting it to connect to my smartphone and seamlessly continue playing the audiobook I am currently listening to. Instead of using the phone's speakers, it would seamlessly start playing through ceiling-mounted speakers. Many thanks
Beginner assistance
Hi folks, I currently have some cheap Zigbee hub and some Amazon Alexas running my smart home which mostly consists of Zigbee power strips and Zigbee battery powered switches. It all worked OK originally, but now whenever I press a Zigbee switch the light in the corresponding plug switches on then immediately off again. If I ask Alexa to turn the light on it works fine. Likewise if I switch it on from my phone. Any ideas what the issue could be? I've tried unplugging the hub a number of times but that doesn't seem to fix it. I was thinking about getting a Homey Pro 2023 to speed things up (tmas the Zigbee hub seems to be really slow now as well, for some reason) but I'm not sure about that either. Any suggestions greatly appreciated!
12 Posts 3 Posters 784 Views 3 Watching
    I want to set something up natively if possible on Vera, so a virtual motion sensor device is tripped / not tripped by following the tripped variable state of a real device.
    This LUA code works if I run it manually but I don't know how to have this running all the time and watching for that "tripped" variable to change ?
    local istripped = luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", 100) --Real Device
    luup.variable_set("urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", istripped,101) --Virtual Motion Sensor Device
    return true
    How do you add something like this in to Vera's startup LUA feature ?
      I've already posted in the old place, so I'll post here again and save to my GitHub, for future reference:
      devices = {
      	[61] = {sensorID = 89},
      	[65] = {sensorID = 94},
      	[63] = {sensorID = 95}
      function copyVariable(dev_id, service, variable, oldValue, newValue)
      	if tonumber(oldValue) ~= tonumber(newValue) then
      		luup.log(string.format("Setting %s - %s for #%s to %s", service, variable, tostring(deviceID), tostring(newValue)))
      		local deviceID = devices[dev_id].sensorID
      		luup.variable_set(service, variable, newValue, deviceID)
      for deviceID, _ in next, devices do
      	luup.variable_watch("copyVariable", "urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", deviceID)
      Where 61, 65 and 63 are the master and 89, 94 and 95 are the children. I've just included a version that could work with more then one device, but you could just remove the other two and it'll work anyway.
        devices = {
        @therealdb Thanks, so you just copy the code in to the Vera Startup Lua area ?
        I never understood properly how the Startup Lua thing worked? Presumably you can't just keep pasting code snippets in to it for various different things ?
        This is what I have in there currently:
          If I run this in the test code area in Vera, it does not trip the virtual motion sensor (290) the real device (696) is currently tripped.
          devices = {
          	[696] = {sensorID = 290}
            yes, but you could just add to VeraScenes as a function, and call it. remember that in this case, copyVariables should be initialized in startup code as follows
            VeraScenes = require("VeraScenes")
            copyVariable = VeraScenes.copyVariable
            VeraScenes.startWatches()
            ... other code...
            and in your VeraScenes, add
            devices = {
            function startWatches()
            cw-kidC 2 Replies Last reply
              ... other code...
              devices = {
              @therealdb said in Vera watch variable / startup LUA how ?:
              I will try and do that for me.
              However I am writing a user guide for a particular Z-Wave device for others to follow on the forum and I am stuck on this part of the setup.
              So I need to make this as generic as possible.
              So I can just post the code directly in to the Startup Lua window ?
                @cw-kid Yes. Code is here, if you just want to point to it 😉 https://github.com/dbochicchio/vera/blob/master/Scripts/CopyVariables.lua
                  @therealdb OK its working ! I just pasted the raw code in to the startup LUA area and the virtual motion sensor now follows the real devices tripped status.
                  I am writing a user guide for the Everspring EH403 Floodlight device, as it doesn't configure correctly after pairing with Vera.
                  I will credit you for your code in the guide when I publish it on the forum.
                    ... other code...
                    devices = {
                    OK I am trying to add this code in to the VeraScenes.lua file now for myself.
                    This is what my startup looks like:
                    I have just pasted the LUA code in to the end of my VeraScenes.lua file and uploaded it again to Vera
                    However I am getting an error in the blue banner in the Vera gui.
                    "ERROR : Error in lua for scenes and events"
                      @cw-kid Looks like you forgot to declare the function in VeraScenes
                        as @crille noted, I posted a specific version for the libs, in my second reply.
                          Thanks guys that's all working OK now
                          • 🎉 My very first MSR controller: OpenSprinkler
                            621
                            Freemanator
                            37.3k
                          • Z-Wave Future....
                          • Can´t restart or upgrade/deploy MSR
                          • [Solved] Limit HA Entity in MSR
                          • Disaster recovery and virtualisation
                          • Remote access of Zwave stick from Z-wave server
