ZWaveJSController 0.1.23254
Home Assistant:
Core 2024.2.5 Supervisor 2024.02.1 Operating System 12.0Expressions and LuaXP Functions
Expressions have a lot of power, as you've often pointed out, but they also remove some of the shielding that the rest of the interface has from system-specifics, and add a big learning curve. I'm grateful for all the hard poking and questions you are asking here, as these things are either bugs or facts that need to be memorialized in the documentation and these forums.
By the way, you had mentioned in the test script for lexpjs the
Xxpect
error, and I replied that it was intentional because there was no object/array comparison by which the test script could compare a complex object/array result with a complex array/object expectation. That has now been remedied in the test script; I don't know if you noticed. You motivated me to get that done, especially since we were accumulating too many results that required manual review, and manual review is in itself error-prone. I suppose I could port that into lexpjs for equality, at least on objects/arrays; I can't really do much about floating point comparison, because they can be much more complex. Maybe lexpjs needs a "~=" operator that means approximately equals? That would take some careful definition... not sure how much use it would get... -
Tough call. I would say no to new features like that unless and until a recognizable minority of users requests them, which I doubt will ever happen. Diminishing returns on your time.
I also doubt most people will be writing complex expressions of the types I've been testing lately, but I was merely trying to flush out any incipient engine problems.
I'm glad these submissions have been equal parts entertaining and instructive, rather than an annoyance.
Agreed. I think that comparison of objects would be rarely used. Mostly, it seems, the expression language is used for access data in structures (like HTTP responses and entity attributes), and moving that around; simple calculations (like random delays) seem to be common; and finally, although I haven't seen it come up in MSR, is going to be time-series stuff. I've not seen a case in either MSR or RFV for object/array comparison.
Now, float equality, yes, I have seen that, but generally speaking, they have been involved in magnitude comparisons (
and>
with or without=
), and that makes the round-off errors less consequential. So agree no pressing need there, either.To reiterate, everything you have thrown at me here is valuable, turning either into documentation changes, or a bug fix and an additional regression test.
PRO TIP (inspired by preceding reply):
WHEN PERFORMING EQUALITY TESTS among Float (high-precision) Expressions (variables) in MSR, use this format:
- First, create a Global Expression such as
epsilon
with value0.001
(or any smaller positive value sufficiently close to 0); - Rather than the test
(A==B)
, where at least one of the variables is a Float, use(abs(A-B)<epsilon)
instead.
This avoids the chance of a phony
FALSE
due to mantissa rounding by the calculation engine. - First, create a Global Expression such as
QUICK CONVERSION FROM DECIMAL (number) TO BINARY (string)
If your workflow demands a binary representation (e.g. you're using Switchboard plug-in's bit-masking features to control multi-switch status) and you really want to see 0's and 1's instead of MSR's always-decimal output, try this Expression on for size:
binConvert
:=b=13, res=[1&b>>3,1&b>>2,1&b>>1,1&b], join(res,"")
Result:
1101
NOTE: Here I've used only 4 "bits" but the concept generalizes to arbitrarily many bits, to accommodate larger inputs.
BONUS: if you want to round-trip a binary string into its decimal numeric equivalent, this Expression will get you there:
decConvert
:=B="001101", binStr="0b"+B, 0b111111 & binStr
Result: 13 (decimal)
In this case, I've chosen 6 bits, but you could employ more or less to suit the length of your input string.
@toggledbits , I notice that the expression
A = [1,2,3], push(A,A)
does not generate an error (it should, since
push(a,b)
expects a non-object in b), nor does it generate a result. Just limbo. -
This will fall into the categories of "don't do this" and "will not be fixed". The reason is objects (which arrays are) pass by reference so that (in more typical usage)
push(A, 55)
can fulfill its definition: modifying A in place by appending 55 to it. An attempt to fix it would result in having to pass copies of the arguments (pass by value), which means the first argument then is not A, but rather a copy of A, and thenpush()
is modifying the copy in place and not the original array, so the original array never changes, defeating the purpose of the function. -
Forging ahead with more newfangled expressions...
@toggledbits what would you expect from:a=["a","b","c"], b=["d","e"], each val in b: push(a,val)
My money was on:
["a","b","c","d","e"]
but instead I got:
[["a","b","c","d","e"],["a","b","c","d","e"]]
EDIT: Ah, here's the magic sauce:
a=["a","b","c"], b=["d","e"], each val in b: c = push(a,val), c
Result:
@toggledbits , I see the immediately-above situation has been rectified with 21090, so I'll edit accordingly.
I also see that you've instantiated some of the array- and text-handling functions you mentioned earlier, so THANK YOU!
For example:
concat( [1] , [2] )
now yields[1,2]
slice( [1,2,3] , 1 , 2 )
now yields[2,3]
pop( [1,2,3] )
now yields3
push( [1,2,3] , 5 )
now yields[1,2,3,5]
shift( [1,2,3] )
now yields1
unshift( [1,2,3] , 5 )
now yields[5,1,2,3]
// NOTE: currently only permits a single addend; for instance,unshift( [1],2,3,4 )
results in[2,1]
not[2,3,4,1]
This one has me scratching my head a bit:
b = [ ] , each i in a = [ 1 , 2 ] : do push( b , i ) , push( b , i ) done
// yields
[[1,1,2,2],[1,1,2,2]]
// expecting[1,1,2,2]
while this modified version:
b=[],each i in a=[1,2]: do push(b,i) done
// yields
[[1,2],[1,2]]
// expecting[1,2]
The result of push is an array.
@toggledbits said in Expressions and LuaXP Functions:
But if you
push ( [ ] , 1 )
shouldn't you get
[ 1 ]
? And not[ [ 1 ] , [ 1 ] ]
It depends on what the complete expression is. Remember that the value of
each
is every non-null expression result during the iteration. So an array of arrays is a very possible response. -
@toggledbits Unless I'm mis-reading the way
each
works, I had anticipated the underlying interpretation of:b=[],each i in a=[1,2]: do push(b,i) done
to be as follows:
"Start with an empty array namedb
. For each item in the array nameda
, starting with1
, append that value into arrayb
. First, you would get[ 1 ]
, and the next iteration, using the2
froma
, append that tob
to yield[ 1 , 2 ]
."Any I missing an important piece of the puzzle? (I do recognize that
do
/done
is not necessary here, but I left it in for direct comparison with the expression immediately preceding.)Thanks. Sorry to give you grief over these operations.
If you want to see what b looks like at the end, you need to do this:
b=[],each i in a=[1,2]: do push(b,i) done, b
If you don't (which is how you've done it so far), you are seeing the result of
each
, which is an array, and since each expression within theeach
has resulted in an array, the result of thateach
is therefore an array of arrays, and referring to the same array by reference. -
This one seems to evade the purpose of
isnull()
somehow:isnull(1/a) // returns false
whereas
isnull(a) // returns true, as expected
In both cases,
a
is undefined.I also cannot seem to create an expression that results in true for
isNan()
, no matter what I throw at it.Finally, why would
bool(null)
return TRUE? -
null coerces to zero (0) for arithmetic operations, so
1/null
is infinity which is not null.int("abc")
results in NaN which will returnisNaN(int("abc"))==true
bool(null)
should return false and I will fix it.Edit: just to follow up, I've added
Infinity
as a keyword/value to the grammar, with a supportingisInfinity(value)
test function (you can also test viavalue === Infinity
), and added that to the documentation for the next release/build. Andbool(null)
is fixed. FYI,bool()
takes a slightly deeper view of "truthiness" than JavaScript natively: the values (number) 0, null, empty string ("") and NaN are false as in JavaScript, but so additionally in lexpjs/Reactor are string "0", string "no", string "off", and string "false"; any other value of any type is true (including empty arrays and objects).
