  3. Caller ID in HA workflow
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
8 Posts 3 Posters 1.5k Views 3 Watching
    Has anyone successfully incorporated incoming call(er) information** within an automation workflow?
    I'm talking about having Alexa speak out the name and/or phone number of a caller, or activating a routine/scene based on that info.
    Always been a dream of mine. Wouldn't know how to achieve it! Do they make an Ethernet/WiFi-connected CallerID box?
    **from a LANDLINE, not a MOBILE PHONE (although in the case of my Google Voice #, both lines ring, and if my smartphone is home and turned on, I could see invoking Tasker somehow)
    REFERENCES:
    NCID - Network Caller ID
    [Please file under proper category, as you see fit]
      As a proof of concept, I rustled up the following workflow, and it works fantastically!
      ON VERA:
      Created a virtual sensor (dev #365) of type "Generic" using the Virtual Sensor plug-in by @toggledbits
      ON SMARTPHONE:
      Created new Tasker Profile that activates when Phone is Ringing > Runs task: HTTP Request (GET) > payload =
      http://<my_vera_ip>:3480/data_request?id=variableset&DeviceNum=365&serviceId=urn:toggledbits-com:serviceId:VirtualSensor1:SetValue&Variable=newValue&Value=%CNUM
      where the built-in Tasker variable %CNUM automatically substitutes the caller's 11-digit phone number.
      Works a charm! Now, I can have MSR simply monitor the 'New Value' variable on the VS and react accordingly.
        I have something similar to get the status of my home office PC when in a VOIP call. It will trigger a virtual switch that's driving a BusyLight oustide my office, sending a notification to my TVs and running a couple of scenes based on the time, to turn on a couple of lights automatically when I'm in a videocall.
          For funsies, I took things a step further using Pushover (recommended by the creator of MSR). After setting up a Desktop notification endpoint in Pushover, I simply instruct MSR to send a push notification to my browser whenever a phone call comes in.
          The process starts, as mentioned above, in Tasker. I modified the value= component of the GET URL so that it sends more than just the phone number; now, it passes %CNAME, %CNUM, 'Libra cell' as a comma-separated list of three items: the caller's name, number and the name I assign to my mobile device.
          In my Caller ID Log rule in MSR, that information (as explained above) gets routed through a virtual sensor on Vera, then pulled into an Expression with:
          callerNum  :=  getEntity( "vera>device_365" ).attributes.x_vera_svc_toggledbits_com_VirtualSensor1_SetValue.newValue
          and turned into a 5-element array using:
          callerArr  :=  split( "IN," + timeStamp + "," + trim(callerNum), "," )
          // yields [ "IN", <call_time>, <caller_name>, <caller_number>, <device_label> ]
          // NOTE: timeStamp is a Global Expression that I defined separately in MSR
          from which MSR can easily pluck the pieces needed to compose a Pushover notification.
            For anyone into formatting phone numbers using MSR's built-in Regex engine, here's one possible Expression to try. It takes an 11-digit U.S. phone number string, extracts the digits using capture groups, and formats them with dashes, all in one go:
            phNum  :=
            a="+12345678901",
            b=substr(replace(a,"(\\d{1})(\\d{3})(\\d{3})(\\d{4})","$2-$3-$4"),-12,12),
            b
            // yields (string) "234-567-8901"
            • parkercP Offline
              parkercP Offline
              parkerc
              Slight tangent, but I’ve been using sipgate voip service ( https://www.sipgate.co.uk/ ) for years, and I’ve never really explored its API..
              There seems to be a wealth of capabilities in there.. - https://api.sipgate.com/v2/doc
              If it’s of interest to you or any others, my initial attempt to authenticate / use it is below..
              #!/usr/bin/lua
              print("start of whole code")
              local https = require "ssl.https"
              local mime = require "mime"
              local json = require "dkjson"
              --local http = require "socket.http"
              local data = ""
              local username = "sipname"
              local password = "sippass"
              local function collect(chunk)
                if chunk ~= nil then
                  data = data .. chunk
                return true
              local ok, statusCode, headers, statusText = https.request {
                method = "GET",
                url = "https://api.sipgate.com/v2/history",
                headers = {
                  ["Accept"] = "application/json",
                  ["Authorization"] = "Basic " .. (mime.b64(username ..":" .. password)),
                sink = collect
              print("data = ", data)
              local sip = json.decode(data)
              print("---------")
              for k, v in pairs(sip) do
              	print(k, "\t", v)
              print("---------")
              for n, a in pairs(sip.items) do
              	print(n, "\t", a)
              print("---------")
              for p, k in pairs(sip.items) do
              	--print(n, "\t", a)
              print("---------")
              for d, e in pairs(sip.items[p]) do
              		print(d, "\t", e)
              print("---------")
                So many of the Callback / VOIP / SIP / SMS / etc. services also provide code templates to use against their API, which is awesome. But you bring up an interesting point, @parkerc ... I've never seen "Lua" among the languages they offer, lol!
                Nice to see you rolling your own. And if it works, perhaps send the company a copy for them to add to their library?
                parkercP 1 Reply Last reply
                  parkercP Offline
                  parkercP Offline
                  parkerc
                  @librasun said in Caller ID in HA workflow:
                  Exactly !, I noticed that too, no one seems to promote Lua
                  It took me a while to just get that working, I don’t think those types of companies will want to use my pieced together bits of code 🙂
                  • Time series documentation
                  • Reset a delay
                  • Single protocol?
                  • HDMI oddness
                  • Oh the joy of pairing
                    836
