  4. Almost there!
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Almost there!
13 Posts 10 Posters 3.2k Views 9 Watching
  • K Offline
    K Offline
    kfxo
    Spinning up a dedicated VM on my synology right now in anticipation of the first preview. Can't wait!
    • MatohlM Offline
      MatohlM Offline
      Matohl
      Dusting of my RPi 4 to test it out 🙂
        Cool! I'm currently on the Docker path, so i'll be setting up one for this. Ubuntu or debian? mabye Alipne, as VWout used for Openluup?
          I like Alpine. It's tiny. "Less is more."
            I plan to switch from PLEG to MSR.
            I've never used Reactor before ever.
            Can't be any harder than PLEG right? 😁
            • Black CatB Offline
              Black CatB Offline
              Black Cat
              @cw-kid ^^^ It's actually easier but it isn't the same. I haven't abandoned PLEG entirely as it is rock solid and use Reactor for new automations.
              MSR is entirely different from what I see as it ties in different systems, for instance I'm looking at tying a Vera Lite, Vera Edge, Homeseer 3 & Homeseer 4 into one system.
              aka Zedrally
                So MSR is very different to the current Reactor in Vera?
                I guess as I'll be starting from scratch with MSR it's the right time to start learning it and skip the current Reactor in Vera
                  MSR will be very familiar to users of Vera Reactor. There are changes, for sure, but conceptually it works very much the same, and many of the displays have a similar look and feel. The systems are close enough that I have been able to craft an importer to read a Vera Reactor backup file and create MSR rules and reactions (they still need review and adjustment, but at least it's not starting from a blank slate). The biggest difference is that Vera Reactor's device model is determined by Vera/Luup, where I had to invent a model for MSR. In doing so, I borrowed concepts from other available controllers and services like MQTT, choosing what I thought were the best ideas and set the stage for the broadest reach platform-wise, and the most extensibility. I would say that if you have something you want to get done today in Vera Reactor, go ahead and do it. It will only smooth the path for you starting with MSR.
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    Hi @toggledbits - QQ: where do I register to use MantisBT, the link you shared just takes me to a page with a logo and a username box, there are no other menu options on the page I can see? (FYI - I’m accessing it from an iPad)
                      When I have an abundance of extra time, and when the MSR Dashboard feature is fully fledged, I plan to make a "Lights Out game" using NxN virtual switches, that operates just like this online version: http://bz.var.ru/comp/web/js/floor.html ✌
                        163.3k
